Are you looking for a method on how to connect iPhone to PC without iTunes? In this post, you will get to learn how you can connect your iPhone to Windows PC to transfer files without relying on iTunes.
Apple iTunes is an official to connect an iPhone to PC for data transfer. But, there are many iPhone users who want to get an iTunes alternative for iOS data management, or iTunes doesn’t recognize your iPhone/iPad.
Here, in this guide, we got several proven ways to connect iPhone to PC without iTunes. Users can now transfer images, videos, documents, audios, ringtones, etc. Keep reading and select any method as per your choice.
How do I connect my iPhone to a Windows computer? First, you can simply connect via the USB cable. And Windows’ Autoplay will help you import photos, videos from iPhone to PC. Steps to connect iPhone to Windows 10:
Transfer iPhone Photos with Windows Photos
If you found that iPhone Autoplay is not working on Windows PC, searching for an efficient way to connect your iPhone to PC without iTunes, we highly recommended AnyTrans. It is a simple yet powerful software designed for users to transfer data from iPhone to computer, and vice versa. And below are its features on iPhone to PC data transfer.
Now, Free Download AnyTrans on your PC, and next, follow the below steps on how to transfer data from iPhone to PC:
Connect your iPhone to PC with the help of a digital cable. After that, tap on the “Device Manager” option from the software main interface, click Content to PC.
Go to Device Manager and Click Content to PC Button
Choose the file types you want to transfer from your iPhone to PC (here we take photos as examples). And, you can add photos from PC, or transfer them between devices.
You Can Choose Export Path and Photos Category
AnyTrans can help you to transfer data selectively. Below are the steps on how to do it:
Free Download AnyTrans on your PC and connect your iPhone to PC via USB cable. From the software main interface, go to the file category page, and here, choose the file type you want to transfer, for instance, photos.
Choose Device Manager mode and click on the Photos category
You can preview files, and choose the files you want to transfer. Eventually, click on “To PC” button to start the transfer process.
Select Photos and Send to PC
Another way to connect iPhone to PC without iTunes is using iCloud Drive. It allows users to sync their data across different devices. With its help, you can access your iPhone data on PC. To take advantage of this service, you need to enable iCloud Drive option on your iPhone. You can do this from your iDevice iCloud settings.
Next, follow the below steps on how to connect your iPhone to PC, and move files with the help of iCloud Drive:
Step 1. To begin the process, download and install iCloud from Apple official site on your PC. Next, run iCloud and log in to your iCloud account.
Step 2. After that, go to iCloud Drive, and here, you can download or simply copy and paste files you want to transfer to your PC.
How to Connect iPhone to PC with iCloud Drive – Step 2
Except for the above methods, you can also connect your iPhone to computer wirelessly. Once you enabled WiFi sync, when your iPhone is charging and connected to the same Wi-Fi with your computer, you can transfer data from iPhone to PC immediately.
Here are the steps to connect iPhone to computer via WiFi:
That’s how to connect iPhone to PC without iTunes. Give a try to AnyTrans as it is the simplest and most effective way to transfer files from iPhone to PC. Also, share the guide with your friends to make them aware of the easiest way to manage and transfer data between iOS devices and PC.
