How to AirPlay from iPhone? (Update 2024)
If you wish to use the AirPlay feature on your iPhone but you do not know how, the following post will teach you how to AirPlay from your iPhone. It explains how you can enable the feature and make it work with your Apple TV. Read on to learn more.
Author Avatar Roger Smith Last Updated: Aug. 21, 2024
The AirPlay feature on the iPhone has gained popularity recently thanks to the amazing things it does with minimal effort. The feature lets you quickly mirror the contents of your iPhone screen to your Apple TV, Airplay on your Mac computer, or any other device that can receive AirPlay content. Most of the time, though, it is only used with Apple TV as the TV has built-in support for it.
AirPlay from iPhone
AirPlay from iPhone
If you own one of the latest iPhone models,  you may want to learn how you can utilize this feature on your device. Although AirPlay is pretty easy to use, there is no harm in learning the proper way to use it on your devices. The following guide sheds light on this feature you get with your iOS device and tells you how to use it.
Where is AirPlay on iPhone?
Before showing how to use AirPlay on iPhone, here will first tell you where is AirPlay. AirPlay feature was first introduced in 2004, at that time, it was called AirTune. In 2010, AirTune was renamed AirPlay. Starting in 2011, Apple used Screen Mirroring to refer to AirPlay.
If you’re wondering where is AirPlay on your iPhone, it might be because you want to find an icon such as Settings or Camera. Actually, there is no such an icon for AirPlay. This feature is embedded in the Control Center.
For iPhone with Face ID: Swipe down from the top-right of your screen, you can open the Control Center. Here you will see a bunch of icons, the one with two stacked small squares is the AirPlay icon.
For iPhone with Home Button: On iPhones with the home button, you need to swipe up from the bottom of your screen to open the Control Center.
Find and Click on the AirPlay Icon (aka Screen Mirroring)
How to Turn On/Off AirPlay on iPhone
The first step towards using the feature on your latest iPhone is to turn on AirPlay on your iPhone model. Like any other feature, it first needs to be turned on and then you can use it however you want. The steps below will work regardless of what iPhone model you have with yourself.
Step 1. Open the Control Center of your iPhone. You can use the method introduced above to go to the Control Center.
Step 2. Find and tap the AirPlay icon in the Control Center. On relatively new iPhone models, such as iPhone 14/13/12, the AirPlay icon is called Screen Mirroring.
Tap the “AirPlay/Screen Mirroring” Button and Choose the Name AnyTrans_XXX
Tap the “AirPlay/Screen Mirroring” Button and Choose the Device Name
Step 3. On the device list, choose the TV or Mac you want to mirror your iPhone screen to. Wait for a few seconds to connect, and you will see your iPhone screen on the target device.
When you have finished using AirPlay on your iPhone, you may want to turn it off. Well, turning it off is as easy as turning it on. Simply open the Control Center and tap on the AirPlay option again. This time your iPhone will turn the feature off instead of turning it on (as it is already turned on).
How to AirPlay iPhone to Apple TV
The above section teaches you how you can turn AirPlay on your iPhone. But what about using it? How do you go about using the feature to mirror your iPhone contents to your Apple TV? We have you covered in this section of the guide.
Using AirPlay on an iPhone is as easy as turning it on your device. You simply need to select the device you want to connect to and the connection is established. If you are completely new to the thing, the following steps will teach you how to use AirPlay on your iPhone with an Apple TV.
Step 1. The first requirement of the feature is both your devices should be connected to the same WiFi network. Connect your iPhone and your Apple TV to the same network.
Step 2. Reveal the Control Center on your iPhone by swiping upwards from the bottom of your screen. When the menu appears, tap on the option that says AirPlay.
Step 3. Once you tap on the option, you will be presented with a list of devices you can connect to. These are all AirPlay-enabled devices available on your network. Tap on your Apple TV in the list to make the connection.
Once the connection is established, you will see your iPhone’s screen on your Apple TV screen. If this happens, it means everything went well.
What to Do if AirPlay Not Working on iPhone
AirPlay is not without any problems or issues. There are a few issues that almost every AirPlay user faces but knowing how to tackle these will help you out. When you find AirPlay is not working on your iPhone, you are suggested to try the following fixes.
Fix 1. Reboot Your Phone and TV
Rebooting both your Apple TV and your iPhone will fix all the temporary issues you may be facing on your devices. Do this first and see if it helps resolve your issues.
Fix 2. Restart the Router
The router is the second thing that helps make the connection. Restart it as well so that it gets a chance to fix any minor issues.
Fix 3. Use a Single Device
Ensure there are no other iPhones or iPads trying to connect to your Apple TV at the same time as you connect. If this happens, your TV will deny the connection and you will not be able to mirror your screen.
Bonus Tip: Best AirPlay Alternative – AnyMiro
AirPlay is a convenient and well-received feature in the Apple ecosystem, but it’s not perfect. It only supports mirroring through WiFi, and only works between iPhone and Mac. If you want to mirror an iPhone screen to a Windows computer, then AirPlay can’t help. That’s why it is recommended you try an AirPlay alternative.
The criterion of a good AirPlay alternative includes compatibility, ease of use, various connection methods, and great screen mirroring quality. Among hundreds of screen mirroring tools, here recommends you the best AirPlay alternative – AnyMiro.
AnyMiro only works for iPhone and Android users to mirror the screen to the computer. Compared with iPhone built-in AirPlay, AnyMiro outperforms in the following aspects:
  • More connection methods: You can use both the USB cable and WiFi to start a screen mirroring. And screen mirror via the USB cable will provide a more stable experience.
  • High resolution: Many AirPlay users have complained about the blur and laggy mirroring quality. AnyMiro promises every user with an up to 4K resolution, level up your screen mirror experience.
  • Supports audio mirroring: AnyMiro can cast your iPhone’s background audio, including game sounds.
  • Integrates with streaming tools: If you want to live stream your iPhone content to YouTube on PC, AnyMiro can help. It can integrate with popular live streaming tools such as OBS and Streamlabs.
As a screen mirroring tool, AnyMiro may not be the best. But as the AirPlay alternative, it is your must-be choice. If you need to live stream from iPhone or want to play iPhone games on a bigger screen, download AnyMiro now and enjoy the best screen mirroring quality.
Mirror iPhone to Computer
Learning how to AirPlay from your iPhone is extremely useful as it lets you show the content of your iPhone’s small screen on a large Apple TV. We hope the above guide teaches you how to do it.
Work for iMobie team for 5 years as well as an Apple fan, love to help more users solve various types of iOS or Android related issues.
