How to Put Password on iPhone Photos?
Are you in search of effective methods on how to put a password on photos iPhone? If yes, then this guide has got you covered. In this guide, we’ll show you how to hide photos on iPhone with a password in just a couple of minutes. Read on and choose the method wisely!
Author Avatar Joy Taylor Last Updated: Aug. 27, 2024
iPhones are a great device when it comes to capturing high-quality pictures. The pictures shot on iPhone are automatically saved in the Photos app, but there are some pictures that you don’t want to be visible in your Photo Library. In such a case, you might hunt for workarounds that will help you with how to put a password on your photos.
Hide Photos with Password
Whatever the reason is, if you don’t want certain pictures captured on your iPhone to be visible in the Photos app, but you don’t want to delete them either, then you can easily hide the photos in just a few clicks. Here in this guide, we have compiled a list of effective solutions on how to hide photos on an iPhone with a password. No matter which way you adopt, you will surely be able to hide selected photos on your iPhone at the end.
You May Like: How to Transfer Photos from iPhone to Computer >
How to Put a Password to Hide Photos on iPhone
How to put a password on photos iPhone is a common query of most iPhone users, and here we are with an easy solution. You can effortlessly put a password to protect pictures or hidden photos in the Notes app. With the Notes app, all your selected images will be safely locked. And in case you wish to save the photos back to the Photos app, you can simply unlock the Note and save the images back into the Photos app.
So, let’s learn how to hide photos on iPhone with a password on the Notes application.
  1. Locate the photo in the Photos app on your iPhone.
    Locate the Photos App
  2. Click on the Share icon.
    Click on the Share Icon
  3. Choose the Notes icon. In case you don’t see it, tap on the three dots icon and then click on the Notes app.
    Click on the Notes App
  4. Here, you can add the text. If a new note does not have a name, then it will automatically set the initial few words of that particular Note as the name.
    Add a New Text
    Add a New Text
  5. Click on the Save to field at the top to select where to save the Note.
    Save Photos to the Note
  6. When you are done with it, click on the Save button at the top right corner of the screen.
  7. When you are done with it, click on the Save button at the top right corner of the screen.
  8. Click on Lock Note and enter the password and password hint for the Note.
    Lock the Note
    Lock the Note
  9. The copies of these photos are now safely locked in the Notes app, but the originals are still available and visible in the Photos app. So, you will have to return to the Photos app and delete them from there.
    Set Password
    Set Password
Make sure to delete the photos from the Recently Deleted album too.
This workaround related to how to put a password on photos iPhone is easy and quick. It just requires you first to add photos to a note, and then the password protects the Note that contains all your selected pictures. In this manner, no one can access the hidden pictures on your iPhone without knowing the password to unlock the Note that contains pictures.
Now, let’s look at another solution to hide photos and videos on iPhone with a password.
How to Hide Photos and Videos on iPhone with Password
When it comes to hiding the pictures on iPhone, there are a handful of great applications that serve this purpose best. On App Store, you will find plentiful applications that guarantee to offer you excellent results, but not all of them are worth trying. So, here we are with a great application that works perfectly to hide photos and videos on iPhone with a password.
Secret Key Lock Album is the best application that helps users to hide images and videos that they don’t want others to see. When you hide photos with Secret Key Lock Album, all your hidden photos will be saved just in your iPhone and will not be uploaded anywhere. Using this app is the safest way to protect your privacy. In the Secret Key Lock Album application, you can anytime open the photo locker with your pre-set passcode or Face ID/Touch ID.
So, if you wish to hide photos and videos on your iPhone and hunt for a reliable workaround to do so, then you must surely give Secret Key Lock Album app a try. It will definitely deliver you results that will be beyond your expectations.
Here’s a step-by-step guide on how to use the Secret Key Lock Album app to hide photos and videos on iPhone with a password.
Hide Photos on iPhone with Password
  1. Install and run the Secret Key Lock Album app on your iPhone.
  2. On the main interface, tap on the Passcode setting button at the bottom of your screen.
  3. Next, enter and re-enter the passcode that you wish to use for this app.
  4. After entering the password, you will receive a notification that will ask you if you Would like to use Face ID? You can click on the option of your choice here.
  5. On the next screen, tap on the Plus icon below to add pictures to the Secret Key Lock Album.
  6. Before allowing you to add pictures, Secret Key Lock Album will ask you to grant access to the photos app. So, tap on Select Photos or Allow Access to All Photos.
  7. Now, select the pictures and videos that you wish to hide in Secret Key Lock Album, and finally, your chosen images will be hidden in this application.
It was this easy to solve how to put a password on photos iPhone issue with the Secret Key Lock Album app. Make sure to follow each step appropriately for flawless results.
How to Disable Hidden Album from Settings
As you have learned above how to hide photos on iPhone with a password, now it’s time to get some idea about how to disable the Hidden Album from Settings. Most of the time, iPhone users enable the Hidden Album feature on their iPhone to hide the photos in the Photos app, but they don’t know the way out to disable the Hidden Album feature.
So, if you are the one who has enabled the Hidden Album feature on your iPhone and finding an effective way to disable it, then we’ve got your back.
Follow the brief step-by-step guide below to serve your purpose best!
  1. Go to the Settings app on your iPhone.
  2. Find and click on the Photos app.
  3. Scroll down a bit and locate the Hidden Album option.
  4. Finally, tap on the Hidden Album option and toggle it off.
That’s all! You have disabled the Hidden Album feature from Settings on your iPhone in just a few clicks.
If you don’t want someone to find your secret or personal photos in the Photos app of your iPhone, then hide them by following any of the ways stated above. All the methods above are pretty easy to use and hassle-free, but if you are looking for a reliable workaround, then Secret Key Lock Album app wins the game. With a unique list of features and a free-to-use pricing plan, Secret Key Lock Album wins the heart of many iPhone users when it comes to how to put a password on photos iPhone.
So, install the Secret Key Lock Album app on your iPhone now and live stress-free by hiding your personal photos in a safe place.
