If the photos and videos are not fully loading in camera roll on your iPhone, the following guide offers some of the fixes to help you get rid of the issue and for you to load and view your photos and videos on your iPhone. Read on to find out how.
iPhone captures some amazing quality photos and videos and perhaps that is the reason many users prefer to use it as their primary camera. And it’s natural to show your friends some wonderful photos or videos. However, sometimes you open the album, only to find the photos and videos not loading on your iPhone. Why did it happen and how can I load them? Check this post and learn how to fix iPhone photos and videos not loading issues.
Before you jump onto the actual fixes and get rid of the issue from your iPhone, you may be interested in finding out the cause of the issue on your device. There could be various factors playing a role in the problem and the following are some of the common reasons why your photos and videos are not loading on your iPhone.
You may also like: Find hidden photos on iPhone
This is the most common reason why your content is not properly loading in the Photos app on your device. The optimized storage option saves your content on iCloud and only shows the thumbnails of your content on your device. Therefore, when you tap on the content, it keeps on loading and does not show anything.
If your photos are saved on the cloud and your Internet is not working, your iPhone will have trouble downloading and showing your content. Your Internet has to be active and stable for your iPhone to fetch content over the cloud.
If your iPhone does not have enough memory space available to load your content, you will have trouble viewing the content as it simply can’t load the content due to the lack of memory space. This happens to a lot of users who have an iPhone with the less storage options.
Now that you know the reasons behind the issue, this section will teach you how you can get rid of the issue using various methods on your iPhone. None of these methods will cost you a penny and these can easily be performed on your iPhone without much technical knowledge.
So if you are ready to fix the photos and videos not loading issue on your iPhone, let’s jump onto the fixes below:
As we mentioned before, the main reason for the issue could be that you have turned on the optimize storage option on your iPhone. When this option is enabled on your device, all of your media content is saved on iCloud. Therefore, when you request to view content, it loads up from your iCloud so takes a bit longer than usual. And sometimes it does not load the content at all for a variety of other reasons.
The best thing for you is to just disable the optimize storage option on your iPhone and the following shows how:
Step 1: Launch the Settings app from the springboard of your iPhone.
Open the Settings menu on your iPhone
Step 2: Open Settings, then tap on your name in the banner that appears at the top. It will open the iCloud panel for you.
Step 3: On the iCloud panel that appears on your screen, tap on the option that says iCloud to open the iCloud settings panel.
Access iCloud settings on your iPhone
Step 4: The following screen will offer several iCloud-related options. Tap on the option that says Photos to launch the photos settings panel.
Launch iCloud Photos settings menu
Step 5: Tap on the iCloud Photo Library. Then, ensure the Download and Keep Originals option is tick-marked on your screen. Tap on it if it is not already.
Disable the Optimise iPhone Storage Option
There you go. What is going to happen now is your iPhone will download all of your photos and videos from your iCloud account on your device. Wait for it to do that and then you should be able to access your content in the Photos app on your device.
Sometimes it could be a minor software glitch causing your photos and videos to not load on your iPhone. In that case, your best bet is to load at least one video in your collection and it will trigger all the other photos and videos to load up. The following is how you do it.
You will find that you are now able to access all other files as well as they have all loaded up properly on your iPhone.
If you are one of the users who has kept your content on a cloud-based service, you must make sure you have an active Internet connection when you try to get access to your content. All the cloud-based services require you to connect to them using the Internet to allow you to access your content.
Check if your Internet connection is working and is stable. If there are any issues with your Internet, you may want to reach out to your Internet service provider and ask them to help you fix the issue. Once the issue is fixed, you should be able to access your photos and videos on your iPhone.
People normally use the optimize storage option when their iPhone is running out of memory space and if that is the case with you, then you may need to free-up some memory space on your device.
There are so many users out there who have a lot of unused content lying on their devices. If you have any apps, photos, videos, or anything else that you don’t use anymore, you may want to get rid of it from your device to free-up memory space and to allow for your photos and videos to load on your device. The following teaches how to find out what’s occupying the memory space on your iPhone so you can remove it:
Step 1: Launch the Settings app from the main screen of your iPhone.
Step 2: When the settings app launches, tap on the option that says General and then select the Storage & iCloud Usage option.
Access storage settings on your iPhone
Step 3: On the following screen, tap on the option that says Manage Storage under Storage to view your storage data.
Manage storage options on your iPhone
Step 4: You should be able to view the list of your apps along with how much memory space each app is using information on your screen.
View and analyze storage information for each app
If you find an app in the list that you don’t use but is using a large amount of your memory space, you should uninstall it on your device to free up memory.
Having tried the above settings or fixes to solve the iPhone photos and videos not loading issue and nothing works for you, then you may consider to fix iPhone system with an iOS system repair tool. AnyFix is recommended as a powerful and easy-to-use program for 150+ system issues on iPhone, iPad, iPod touch and Apple TV. You can check its full features in the following:
Follow the steps and fix photos and videos not loading on iPhone.
Step 1. Download and install AnyFix on your computer.
Step 2. Launch AnyFix and click System Repair from the main page.
AnyFix System Repair Option
Step 3. Choose App Issues and click Start Now.
AnyFix System Repair App Issues
Step 4. Choose Standard Repair and then follow the instructions to finish system repair with AnyFix.
AnyFix Standard Repair
After repairing, enter the Photos app and load your photos and videos normally.
If you don’t want to use an iOS system repair tool for iPhone photos and videos not loading issues, you can also try some ways to load them on a computer. iCloud is convenient for iPhone users to sync and view photos when they have trouble accessing them. You can then transfer the content from your computer to your iPhone using various ways.
The following is how to do it:
Access your photos on the iCloud website
You can now view all of your downloaded photos on your computer. You can use a content transfer app to transfer photos to your iPhone should you wish to do that.
Besides iCloud, AnyTrans provides a faster and easier way to view photos and videos on the computer. It takes just seconds to load your photos and videos. Moreover, AnyTrans can download and transfer multiple photos and videos if you want. You can quickly load photos and videos on the computer without effort.
Here’s how to load photos and videos on your computer:
Step 1. Free download AnyTrans and install it on Windows or Mac.
Step 2. Use a Cable to connect your iPhone to the computer.
Step 3. Wait for AnyTrans to load your photos and videos.
Choose Device Manager mode and click on the Photos category
Then you can just view the photos or send them from the computer easily. AnyTrans can also help you transfer photos quickly from iPhone to computer or vice versa.
Photos and videos not loading on iPhone is frustrating but it’s easy to fix this issue. The above 7 ways are suggested to try one by one. Among all the methods, you are recommended to fix iOS system with AnyFix or use AnyTrans to load photos and videos on your computer. These 2 tools are efficient for iPhone photos and videos not loading issues.
