OK, got it
How to retrieve blocked messages from iPhone? This post will tell you with details. Check it to see the easy way of recovering iPhone message, whatever have a backup or not.
Free download PhoneRescue for iOS to recover data from your iPhone with or without backup.
In the daily lives, you may block someone on your iPhone temporarily, but regret not seeing his or her messages. Then you may wonder if you can recover blocked messages on iPhone.
A user from Apple communities asked the question “How do you retrieve blocked texts on an iPhone 8?” He or She is not the first and the last to ask such a question. Will you receive messages after unblocking iPhone? The answer is No. So, lots of iPhone users looking for a method to recover blocked messages on the iPhone after they regret blocking someone or just wonder what kind of messages the blocked one might send them. Then, how to retrieve blocked messages from your iPhone?
Here are some WhatsApp guides for you:
If you wanna know the answer like can you see blocked messages on iPhone after unblocking? First of all, let’s talk about the possibility to retrieve blocked text messages on iPhone. The answer is NOT. Why? Once you block someone, you won’t receive any messages and phone calls from this number. Unlike some Android phones, there wasn’t a so-called blocked folder existed on your iPhone for data recovery. Just like another user commented that “Obviously they don’t a very good job of blocking texts if you still receive them.”
So, some data recovery software advocating they can help you get back blocked messages from iPhone, that is just a tempting chance but indeed useless. It’s a pity that there is no way to retrieve blocked messages on iPhone. But, if you want to retrieve deleted text messages from someone before they are blocked, or after unblocking, then Part 3 can help you recover without a backup, or from iPhone backups.
You can only see texts from a blocked number after unblocking it from your contact list. Here is how to do it:
Step 1. Go to Settings. Scroll down and find the Phone icon.
Go to Settings and Click Phone
Step 2. Select Call Blocking & Identification. Then you’ll see a list of the blocked contact list.
Check Blocked Contact List
Step 3. Tap on Edit or just swipe to left, and unblock it. After that, you can receive messages from that number again.
Unblock Text Messages on iPhone
Yes. If you unblock someone, you will get their text messages or calls on your iPhone. And, you can retrieve messages and call history after unblocking with the method below. No matter if you accidentally deleted messages, texts lost after an iOS update, etc., check the detailed steps below.
Below are some tutorials that tell you how to retrieve deleted messages on iPhone, you can choose one to follow based on your conditions:
If you want to retrieve deleted text messages before blocking, or just want to retrieve deleted text messages, iMessage, or WhatsApp messages, you can make use of some best iPhone data recovery software to make it with ease, even without any backup.
No matter you have an iPhone backup or not, you can have a try on PhoneRescue for iOS. It gives several efficient ways to help iPhone users retrieve data with great ease. And it supports previewing deleted messages on your iPhone and selectively recovers them to your iPhone or computer.
Now, get Phonerescue for iOS on your computer and recover messages without backup below:
Step 1. Install and launch Phonerescue for iOS> Connect your iPhone via USB cable > Click Recover from iOS device.
Recover from iOS without Backup
Step 2. Check the Messages type and continue.
Choose Messages to Scan
Step 3. View all the message data and choose the ones you need to recover.
Preview and Choose to Recover Texts
If you want to see the blocked messages on your iOS device, you can restore it via the iTunes backup you made before.
Step 1: Open iTunes on your computer and connect your iOS device to the PC.
Step 2: Click on the Device button when iTunes recognizes your device. Choose the Summary icon and select the option to back up the data on PC. Click on the “Restore Backup” button to recover blocked text message iPhone.
Make sure you have backed up your iPhone to iCloud, then you can retrieve the blocked or deleted messages from iCloud.
Step 1: Go to Settings > General > scroll down the screen and choose Reset > Erase All Content and Settings > Enter your password. Your iPhone will then restart. Then follow the on-screen instruction to proceed.
Restore iPhone from iCloud Backup with Resetting
Step 2. After completing the above settings, you will enter Apps & Data interface. Tap Restore from iCloud Backup on the Apps & Data screen > Sign in to iCloud > Proceed to Choose Backup and choose the one that contains the data you need to restore.
In a word, there is no way to retrieve blocked messages from iPhone. If you don’t want to miss some messages, you don’t have to block them. If you just don’t want to see someone’s texts for a while, you can ignore them. Hope this post is helpful to you. If you really miss the person, then I suggest that you can ask the person to allow you to check those messages on his or her phone, it’s silly, but it does work.
And, PhoneRescue for iOS is the top 1 data recovery tool that allows you to recover lost iOS data, repair the iOS system, remove iOS passwords. You can download it and have a try.
