Have no idea how to restore iPhone in recovery mode without iTunes? Don’t worry, this guide will show you detailed steps of restoring iPhone in recover mode without iTunes, and guarantees no data loss. Let’s check it out.
It’s indeed very annoying when iPhone gets stuck in recovery mode. In that case, it just like a brick, you can’t access it, it becomes unresponsive even a call comes or message arrives. You must be eager to get it out of recovery mode, right? The most common way to make it back to normal is to restore your iPhone in iTunes. But, you know that restoring iPhone with iTunes will erase all content on your iPhone. So you’re looking for a way to restore iPhone content such as photos without iTunes in recovery mode.
It seems impossible to make it, nevertheless, here in this post, we’re going to show an easy way about how to restore iPhone in recovery mode without using iTunes.
Also Read: How to Backup iPhone in Recovery Mode >
For Mac users, Finder is certainly no stranger to Mac users. In fact, Finder and iTunes are the same, but Apple uses Finder instead of iTunes, so if you don’t mind using Finder, then you can follow these steps to restore iPhone.
Step 1. Connect your iPhone to your Mac via a USB cable and make sure your iPhone has been recognized.
Step 2. Open Finder and locate your iPhone.
Step 3. Go to General> Software > Restore iPhone to factory reset the iOS device and reinstall the system.
Unlike using Finder to restore your iPhone in recovery mode, this method can help you restore iPhone without erasing any data, all the data and settings on your phone will be kept the same like before. To make it, you need the help of a professional iOS restore tool – PhoneRescue for iOS. As one of the best iPhone restore software, it is one of the reliable and workable options for you to restore the iPhone in recovery mode. It assures you:
Download and install PhoneRescue for iOS on your computer afterward connect your iPhone to the computer with USB > Select the Repair iOS System mode and click the Right Arrow icon to continue.
Click Device Rescuer and Choose Repair iOS System
Choose the Repair iOS System mode and click on the Right Arrow icon to go to the next page. Notice that there are two repair modes – Standard Mode and Advanced Mode. After using Standard Mode, your iOS system will be updated to the latest version and all device data will be completely erased. If you choose Advanced Mode to repair your iOS system, the data won’t be erased. Select one mode to repair your iOS system. Here we suggest you choose Advanced Mode.
Select the Advanced Mode to Fix Your Bricked iPhone/iPad
Follow the 3-step instruction in the window to enter “Recovery” mode.
Follow the Steps to Enter the Recovery Mode
After entering “Recovery” mode, you need to check your device info. To repair the abnormal operating system, please click the “Download” button to download the firmware for your iPhone. It takes some minutes to download the package, so please just keep patient.
Check Your iPhone Model and Download the Corresponding Firmware
After downloading the firmware package, PhoneRescue will repair your iPhone to normal automatically. Please do not disconnect your iPhone until it restarts. Once the recovery process is complete, you will see the Complete page.
iOS Repairing Completed
AnyFix – iOS System Recovery is your one-stop solution to fix various iOS/iPadOS/tvOS issues in minutes, and bring your Apple devices back to normal without data loss. It is easy and efficient to restore your iPhone in recovery mode with AnyFix. Better still, AnyFix is more than an iOS repair tool, which can fix 200+ iTunes errors, upgrade and downgrade the iOS device to any available versions, reset iPhone without password, etc. Let’s firstly check how to fix restore iPhone in recovery mode with it in detail.
Choose System Repair on the Homepage
Select iPhone Problems
AnyFix offers you 3 modes to ensure that your iPhone will be successfully restored with the highest success rate. You can select any of them to repair the iPhone system issue.
Choose Standard Repair Mode
Then you will go to the firmware download interface. After you download the matching firmware for your iPhone, you can fix it in 1 click by clicking the Fix Now button. When the repair is completed, your iPhone will turn into the normal mode, AnyFix will show you the interface as below.
System Repair Completed
How long does it take to restore iPhone?
In fact, there is no exact time for this, so there are many factors that affect restore. For example, the stability of the network, the stability of the USB and the performance of the computer itself, etc.
How do I restore my iPhone without a computer or iTunes?
Under this situation, you can back up your iPhone data via iCloud at first. And then reset your iPhone to factory reset. At this time, your iPhone has been restored completely. But you don’t have to worry about losing your data, because you have used iCloud to back up your data before, now you just need to restore the iCloud backup data to your phone and you can use it normally.
As you can see from above, it’s easy to restore your iPhone in recovery mode without iTunes. Also, it’s the best way to avoid losing any data. Additionally, you can also use PhoneRescue for iOS to restore data from your iPhone backup without data loss. It’s a better iTunes alternative, why not give it a try now?
