Can’t find your valuable email messages on your iPhone? Apply these 6 simple solutions in this article to recover disappeared email messages.
Emails are one of the best messaging systems to share data and information on the net as it lets you connect with families, friends, or relatives effectively. You can also use it for official purposes, such as to create promotional texts, marketing campaigns and more. It allows you to send and respond to messages without operating system limitations.
When compared to other messaging systems, emails are a better option because of the capability to store exchanged messages and data files. However, there are reports about the sudden disappearance of emails on iPhones. The reason for this is unknown to many iOS users. So our team decided to create a guide that explains why emails could disappear from your iPhone and how to fix it. Read on!
Also Read: You can recover other data disappeared on iPhone with the following tips.
As earlier reported, emails are designed to store exchanged data. Unless you tamper with the shared data/information, it cannot disappear. However, if it does, here are some reasons such an error occurs:
Choose from the six solutions below to fix the emails disappeared from iPhone issues you are facing:
Should the emails on your iPhone suddenly disappear, we advise you to reboot the device to refresh the system. By rebooting, we mean that you switch off your iPhone and turn it ON after a couple of minutes.
With the stepwise guide below, you can reboot your iDevice to fix emails disappeared from iPhone issues:
Choose General and Click Shut Down
Your iDevice will go off by showing a blank screen. After a while, hold the appropriate buttons to restart it. When the device comes up, go to your email account and check for the missing messages.
By simply signing out and back into your email account, you can quickly fix email disappeared on iPhone error. This solution helps you refresh your email account, and restores unseen messages. To re-add your email account, apply the below step-by-step instructions:
Step 1. Head to the Settings menu page and click Mails. You will get the response page below:
Step 2. Tap on the Accounts tab, then select the faulty email account by clicking on it.
Step 3. Next, tap on Delete Account to sign out of your profile.
Tap on Delete Account
Step 4. Once the step above is completed, head to the Accounts page and click Add Accounts.
Step 5. Now select the appropriate mailing service from the list provided.
Step 6. Enter your account details correctly to re-login.
You can learn to delete emails here: How to Delete All Emails on iPhone/iPad >
Emails are supposed to sync automatically without limits. However, if you’ve tampered with this setting in the past, your emails may disappear suddenly. You can fix this by readjusting the settings. Here is the detailed instruction to automatically sync emails without limitations:
Step 1. Open the Settings tab. Head to where the Mail icon is located, click on it, and select Accounts on the page that follows.
Step 2. Click on your email account, locate the Mail Days to Sync button and click on it.
Step 3. A new interface labeled Mail Days to Sycn appear just as seen in the image below.
Mail Days to Sync
Step 4. Select No Limit, and try checking your email again. All unseen emails should appear without further delay.
PhoneRescue-powerful iPhone Data Recovery tool is one of the most reliable data recovery solutions you can use to retrieve data on iOS devices. This tool recovers almost all iOS data types such as contacts, emails, photos, videos, call history, App data, etc. without erasing or overwriting your original data. The software retrieves disappeared emails in 3 modes: directly from iPhone, iCloud, and iTunes. It’s one of the easiest data recovery solutions as it offers a sleek interface for smooth navigation. Whether you use a Windows PC or Mac, you can access PhoneRescue as it connects with both operating systems. Here are some other wonderful features of PhoneRescue.
Now free download PhoneRescue and learn how to recover disappeared emails on iPhone with it.
Step 1. Open PhoneRescue for iOS and select Data Recovery. Some options will immediately appear underneath. Choose Recover from iOS Device, and hit the arrow button at the bottom of the screen.
Recover from iOS Device without Backup
Step 2. You can see several data types, and please select Mail, and click on OK. Then PhoneRescue will analyze your device for disappeared emails.
Select Data Type You Want to Recover
Step 3. When PhoneRescue is done, select what to recover and export the emails to your iPhone or computer by clicking on the appropriate buttons. After that, you can disconnect the iPhone from the computer and recheck for disappeared emails.
iOS Data Recovery Completed
System errors may also cause this problem, so you need to fix them immediately. Aside from data recovery, PhoneRescue can also repair multiple iOS system issues. All the system issues, such as emails disappeared from iPhone, frozen screen, stuck in recovery mode, won’t turn on, etc. can be repaired by this system repair solution at a remarkably high speed. And all you need to do is just tap on the buttons in order. It boasts a high success rate as it fixes your device without erasing your data. PhoneRescue is compatible with all iOS models. So whether you use an old-generation iOS device or the latest one, you can count on PhoneRescue.
The guide required to fix email disappeared issues using the PhoneRescue system repair tool is pretty simple. Check it out below:
Step 1. Download and run the PhoneRescue for iOS on your computer and connect your iPhone to it via a USB charging cord. Select Device Rescuer > Repair iOS System. Tap on the arrow button pointing to the right to access the next screen.
Click Device Rescuer and Choose Repair iOS System
Step 2. Next, choose Advanced Mode as your preferred option to fix your iDevice. Once done, locate and click on the arrow button at the lower right corner of the software page.
Choose Advanced Mode
Step 3. A new screen describing how to enter recovery mode on your iPhone will appear. Follow the guide accordingly.
Enter Recovery Mode
Step 4. After that, PhoneRescue will scan your iPhone and recommend a firmware package to repair it. Check the information of your device and click on Download.
Click Download to Get Firmware
Step 5. Then it will repair system errors automatically. When the repair is over, your iPhone will reboot. Once it comes on, disconnect it from the computer.
iOS Repairing Completed
Updating your iOS fixes common issues like software bugs and minor glitches that are affecting your iDevice, and causing your emails to disappear suddenly. A quick guide to update your iOS is given below:
Step 1. Connect your device to a stable data network, either mobile data or WiFi.
Step 2. Locate and click on the Settings tab to open the menu page.
Step 3. Next, tap on the General icon and select Software Update. Wait for your iDevice to scan for available updates.
Step 4. Should it find one, you will get a prompt with the Download and Install icon. Click on the icon and the update will begin immediately.
Update iOS on Your iPhone
Once the update is over, your device will automatically restart. Now, recheck the email, you should find the missing messages or data files.
Now you know why emails may disappear from your iPhone. Also, we provided a detailed guide with six solutions to fix the issue. Choose from the solutions to repair your iPhone today. PhoneRescue is our best option among the solutions introduced. The software helps you fix emails disappeared from iPhone issues and also retrieves lost email files. It’s an incredible iOS system repair and data recovery solution. So just give PhoneRescue a free try now!
