Did you log in to your Google account and find your email disappeared from Gmail? In this article, we have discussed some easy ways to recover missing emails in Gmail.
With most of our work based online, our email inbox is like a second home. The moment you flip open your laptop at work, the first thing you do is check your email. What if one day you open your Gmail and find some emails missing?
We’re sure you’ll panic or have an anxiety attack, especially if those emails contain essential information. However, nothing is lost! You can quickly recover all your missing emails via the tried and tested ways we have put together in this article.
There could be a number of reasons for your emails disappearing from Gmail. For instance:
Regardless of why your email disappeared from Gmail, here are 9 methods to retrieve them.
If you ever find your emails disappearing from your inbox, try these methods to help recover them:
The first and most probable reason for your Gmail missing emails is that you or someone else accidentally deleted them. Therefore, check your Gmail trash bin to see if they are there. Here’s how to check the trash on Gmail:
Step 1. On the left menu panel, click on “More > Trash.”
Step 2. If you have accidentally deleted your emails, you’ll find them there. To recover your lost emails, simply right-click on the email, and click “Move to Inbox.”
Click Move to Inbox
Your deleted emails will appear in your inbox, and you can read them.
However, check the Spam folder if you did not delete them and they are not in the trash bin.
There’s always a possibility that Gmail detected spam in your missing emails. Therefore, they might go to your Spam folder instead of your inbox. To check your Spam folder:
Step 1. On the left menu panel, click “More > Spam.”
Step 2. If you find your missing emails in the Spam folder, mark them as “Not Spam” to prevent Gmail from sending them to the Spam folder. Right-click on the email you want to remove from Spam and click on “Not Spam.”
Click on Not Spam
If your missing emails are not in the Spam folder, they could be in the Socials or Promotions tabs.
Step 1. Click on the Social or Promotions tab under Categories on the left menu panel.
Click on Social or Promotions Tab
Step 2. If your emails are being redirected to these tabs by Gmail, you can select the checkbox next to the email and click “Not Social” or “Not Promotion” from the option at the top.
There’s also a possibility that you accidentally archived an email. While there’s no option to view archived emails separately, you can display all emails in one inbox, including the archived ones. Here are the steps to view all emails:
Step 1. Click “More > All Mail” from the left menu panel. This will display all your emails in one inbox, including archived, spam, promotions, social, etc. if you unknowingly archived your missing emails.
Click All Mail
Step 2. Select the checkbox next to the email and click “Move to Inbox” to unarchive them.
If nothing else works, you can always use the search bar in Gmail to find your missing emails because your missing email might be buried under hundreds of other emails.
Use Advanced Search
The search feature will go through your entire account to find the information.
As we mentioned above, Gmail can filter the emails in your inbox. Similarly, if you block an email address, you won’t receive any emails from it. You can check the filters and blocked addresses to see if that’s the reason your emails are missing.
Step 1. Click on the gear icon in the top-right corner of your Gmail inbox and select “See All Settings.”
Select See All Settings
Step 2. Now click on “Filters and Blocked Addresses” to see if the sender’s email address is accidentally blocked or filtered.
If the sender’s email address is blocked, you can click the checkbox next to their address and select “Unblock Selected Addresses” to remove them from the list.
Perhaps you’re running out of free storage space on Gmail. That could also be why new emails are not appearing in your inbox.
To check how much storage is used:
Step 1. Scroll down to the bottom of the inbox to view the total and used storage.
Step 2. If you’re out of storage, click on the arrow icon to get more storage from Google.
If you’ve tried all the methods mentioned above and can still not recover your missing emails in Gmail, it’s time to contact Gmail Support.
Simply visit Gmail Message Recovery Tool website and click “Continue” to try and recover your deleted emails from the last 30 days.
In addition to emails in Gmail, many iOS users may also lose voicemails due to various reasons, which may contain important information. So how to recover them? PhoneRescue for iOS, a data recovery software specially designed for iOS users, can help you recover all your lost data, including voicemails, easily. And the recovered files will not overwrite the original data, ensuring that every data on the device is safe and sound. So let’s take a look at its key features!
In addition, PhoneRescue can also help you fix some iOS system issues, like black screen spinning wheel, green line on the screen, stuck on Apple logo, stuck in recovery mode, etc.
Now free download PhoneRescue and follow the steps below to recover your data even without backup.
Step 1. Open PhoneRescue on your computer > Choose Data Recovery list > Select Recover from iOS device.
Recover from iOS without Backup
Step 2. Then you need to choose data types. Here you can only select Voicemail.
Choose Data Category to Scan from iOS Device
Step 3. It will show you all the data. Just preview and select what to recover. Tap on To Device or To Computer button to recover the selected data.
Get Back Deleted Voicemail to iPhone
It can be quite overwhelming if your important emails go missing from Gmail. However, the tips mentioned in this article will surely aid you in recovering your lost emails. And if you want to recover voicemails easily, you can also try PhoneRescue for free. Have you ever deleted your emails accidentally or due to a system glitch? How did you recover them? Share your experience with us in the comments.
