6 Best iPhone Repair Software to Fix iOS System Issues
Want an iOS system repair tool but don’t know how to choose? Here we will 6 popular iPhone repair software to fix 150+ iOS system issues. Check them out and get your preferred one!
Author Avatar Joy Taylor Last Updated: Oct. 09, 2024
AnyFix – Best iOS System Repair Tool 2024
Download AnyFix to fix 150+ iPhone/iPad/Apple TV system issues easily. No technical skills required. No data loss. Support the latest iOS 18 and iPhone 16.
Before introducing some available iOS repair tools, you’d better learn the features of such software and how to choose a proper one.
What Does iOS Repair Software Do?
The iOS repair tool helps to fix various iPhone system issues, including iPhone stuck on Apple logo, iPad boot loop, iPhone frozen, and more. It provides a way to fix iOS without data loss, which is more convenient than iTunes. Generally, iPhone repair software can be used to upgrade or downgrade iOS if you are not satisfied with the current system. In addition, some iOS repair tools support entering or exiting the recovery mode in one click.
Please note that the iPhone repair software doesn’t fix hardware problems. Then you can check how to choose a proper repair tool.
How to Choose the Best iPhone Repair Software?
To find the most available iPhone repair software, we’ve done a long-time test and research, then based on the functions, success rate, security, and repair speed of iPhone repair software, we finally choose the 6 best iPhone repair software for you, respectively are AnyFix, PhoneRescue for iOS, Dr.Fone, Fixppo, UltFix and TunesKit.
Notably, all of them are easy to use and function well. But there are still a few differences among them. Now, based on the different functions of iPhone repair software, we will respectively introduce their advantages and disadvantages to you. After reading, you can choose one that fully meets your needs.
1. AnyFix – iOS System Repair
AnyFix is a powerful iOS system repair tool that offers solutions for more than 150 iOS/iPadOS/tvOS problems. This includes iPhone problems such as iPhone won’t turn on, iPhone is frozen, iPhone is disabled connect to iTunes, iPhone stuck on iOS 18 update requested, iOS 18 update failed error, etc. It is an iOS system repair tool that gives you a one-stop solution to fix various iPhone issues and brings your Apple devices back to normal.
Main Features:
  1. Cover 150+ system problems. AnyFix lets you fix most iPhone problems, including both common and uncommon ones.
  2. The highest success rate with 3 repair modes. It provides 3 different repair modes, Standard Repair, Advanced Repair, and Ultimate Repair. Each mode covers different iPhone problems, ranging from the most common ones to the most comprehensive problems.
  3. The fastest repair speed. No matter how serious and complex your iPhone problem is, AnyFix will solve it within only a few minutes at most.
  4. Simple to use. Your iPhone problems can be repaired with a one-stop solution. You can fix iPhone software at home by yourself.
  5. Full compatibility. It works for almost all models of iPhone like the latest iPhone 16 and iOS 18.
  6. No data loss. A standard repair to fix those common iPhone problems won’t erase existing data on your iPhone.
  7. Free to upgrade iOS. Except for iOS system recovery, AnyFix allows you to fix iTunes issues, 1-click reset devices, upgrade iOS, enter recovery mode, etc.
How to repair the iPhone system with AnyFix?
Step 1. Download and install AnyFix on your computer and click System Repair. Here you can see the problems that AnyFix supports to solve.
AnyFix Main Screen
AnyFix Main Screen
Step 2. Choose the category that most suit your needs and click Start Now. Let’s take Screen Stuck as an example.
Step 3. Then you can choose from the 3 modes to fix your iPhone system problem. The standard mode will not cause data loss, while the other 2 modes will erase data on your iPhone. You can decide to choose one according to your system status.
AnyFix Standard Repair
Then you can just follow the instructions to finish system repair with AnyFix.
Pricing: $35.99 for 3-month plan, $39.99 for 1-year plan. Get AnyFix with a big save today!
2. PhoneRescue for iOS – iPhone Data Recovery & iOS System Repair
Another effective iPhone repair software in the market is PhoneRescue for iOS, which is capable of helping you fix a wide range of iPhone issues like iOS upgrade failure, iPhone stuck in white Apple logo, iPhone unable to start iOS, and so on.
Except for iOS repair, PhoneRescue for iOS is a complete iPhone solution for iOS data recovery and iOS lock screen removal. Thus, even if data loss happens while repairing iPhone, you can get iPhone data back with PhoneRescue for iOS easily. For more outstanding advantages of PhoneRescue for iOS, you can refer to the following tips.
Main Features:
  1. Fix a wide range of iPhone issues. PhoneRescue for iOS can fix your iPhone iPad iPod touch from any type of breakdown like being stuck on a white Apple logo, continuous reboot loop, or black screen, etc.
  2. 2 repair modes. PhoneRescue for iOS provides you with Standard Mode and Advanced Mode. The former is mainly used to fix iPhone stuck on the Apple logo, recovery mode loop, black screen, etc. And the latter is aimed at fixing other system errors, and black screens without data loss. You can choose one for your needs.
  3. Compatibility. It works for almost all models of iPhone like the latest iPhone 16 and supports iOS 18.
  4. Easy to use. It’s easier and safer than ever to revive your dead iPhone and iPad from any iOS crash.
  5. No data loss. With the Advanced iOS Repair mode, you can fix all iPhone issues without removing any data on your iPhone.
  6. High successful repair rate. Up till now, hundreds of thousands of users have successfully fixed their iPhone software issues with PhoneRescue for iOS.
  7. Rapid repair. With only several minutes, you can repair all iPhone problems with PhoneRescue for iOS.
  8. The most comprehensive solution for iOS. It provides you with iOS system repair, iOS data recovery, iOS lock screen removal, etc.
Now you can get this iOS repair tool downloaded on your Mac or Windows PC, go to Device Rescuer, and choose Repair iOS System to repair your iPhone to normal.
Click Device Rescuer and Choose Repair iOS System
Pricing: $49.99 for 1-year plan, and save up to 30% for PhoneRescue NOW!
3. WonderShare Dr.Fone
Wondershare’s dr. fone is another iPhone repair software we are going to introduce to you. This iOS toolkit is most often used to fix iPhone won’t turn on the issue. Besides, it also excels in handling other iPhone issues like iPhone stuck in recovery mode and in a boot loop. It is very easy to use, you just need to get your iPhone connected to the computer and launch the Dr.Fone software, then you can repair your iPhone to normal by following the instructions. Now there are some advantages and disadvantages of Dr.Fone’s repair.
Advantages:
  1. Safe repair. It can help you fix your iPhone to normal without data loss, you don’t need to worry about losing important data.
  2. Fix various iOS problems. stuck on the white Apple logo, black screen of death, stuck in a boot loop, stuck on connecting to iTunes, iPhone frozen, iPhone is disabled connect to iTunes and stuck in recovery mode, and so on.
  3. Fix iTunes errors. It can help you fix various iTunes errors like iTunes error 4013, error 27, error 9, and so on.
  4. Compatibility. It works for almost all models of iPhone, iPad, and iPod touch. iOS 15 is supported.
  5. Downgrade iOS. It also gives you more solutions like downgrading the iOS version.
Disadvantages:
  1. The functionality of the free version is limited. If you want to experience more functions, you need to pay for them.
  2. Sometimes, it cannot recognize your iPhone.
  3. A jailbroken iPhone will be updated to the non-jailbroken version.
Pricing: $59.95 is needed to use Dr.Fone – System Repair (iOS)
While repairing your iPhone with Dr.Fone, your device will be updated to the latest version, if you want to downgrade it to the previous iOS version, just read How to Downgrade iOS with/without iTunes to make it.
4. iMyFone – Fixppo
iMyFone’s Fixppo is the next iPhone repair software that will be introduced. It is designed to fix various iOS issues, for example, iPhone stuck on the white screen, Apple Logo, Recovery/DFU Mode, restarting loops, getting bricked with a frozen screen, or simply won’t start. It also comes with 3 modes, each of them is designed to help you repair your device to normal. If you want to know more about it, just read the following text to get its advantages and disadvantages.
Advantages:
  1. Fix almost all iPhone problems. Almost all iPhone problems are covered by Fixppo like white/black screen of death, iPhone frozen/boot loop, iPhone update/restore failure, iPhone stuck in recovery mode/spinning circle, won’t turn on, etc.
  2. Without data loss. You are offered 2 modes: Standard Mode and Advanced Mode. The former one is mainly designed to fix problems like “iPhone stuck on frozen”. And the latter enables a disabled device, and repairs the iPhone problems that the Standard Model cannot fix.
  3. Downgrade iOS. iMyFone’s Fixppo enables you to downgrade your iPhone to the previous version without jailbreak.
  4. Enter/Exit recovery mode with ease. You can enter/exit recovery mode with one click.
  5. Fix iTunes errors. It can help you fix various iTunes errors like error 2.
Disadvantages:
  1. The Advanced Mode will cause data loss.
  2. It can not be used to unlock a locked iPhone.
  3. Many functions cost.
Pricing: $29.95 for 1-month plan, $39.95 for 1-year plan.
iMyFone Fixppo iPhone Repair
5. Joyoshare UltFix
Joyoshare UltFix is an iOS System repair tool, that is designed with dual repair mode. It can repair 150+ possible iOS issues such as iPhone stuck on the black screen, the white Apple logo and iPhone keeps restarting, etc. It is easy for you to independently complete the whole system repair process in 3 steps no matter which problem is. You can choose Standard Mode or Advanced Mode as you need.
Advantages:
  1. Fix various iOS problems. Repair more than 150 kinds of iOS/iPadOS/tvOS issues.
  2. Without data loss. Recover iOS System without Causing Data Loss.
  3. Compatibility. It works for almost all models of iPhone. The latest iOS 16 is supported.
Disadvantages:
  1. The trial version has limited features.
Pricing: $49.95 for Family License.
Joyoshare UltFix iPhone Repair
6. Tuneskit iOS System Recovery
Tuneskit iOS System Recovery is another iPhone repair software that will be introduced. It can help you to recover your iOS/tvOS to normal at home with no data loss. No matter whether your iOS device stuck in recovery mode/DFU mode/white Apple logo, or becomes black it will get you out of the trouble and recover your device back to normal quickly.
Advantages:
  1. Fix iOS/tvOS with 2 Modes. Provide 2 different modes, including Standard Mode and Advanced Mode for you to fix most common iOS or tvOS errors.
  2. Without data loss. Recover iOS System in standard mode without Causing Data Loss.
  3. Compatibility. Work well with Windows and Mac. It works for almost all models of iPhone. The latest iOS 16 is supported.
Disadvantages:
  1. The trial version does not permit saving the files.
Pricing: $29.95 for 1-month plan, $39.95 for 1-year plan, $49.95 for lifetime license.
Tuneskit iPhone Repair
Q&A to iOS System Repair Tool
Three frequently asked questions and the answers to them are listed below.
1. Does iPhone repair software really work?
Absolutely the answer is YES. As we introduced several top iOS system repair tools above. All of them are able to repair iPhone software to put your iPhone into normal. Although they are different in cost, functions, repair speed, how many problems they can fix, etc., you can check the details above and choose the best suitable one for your iPhone.
2. How much does it cost to fix a software issue on iPhone?
AnyFix – iOS system recovery
  • Functions: 150+ system repair issues; 200+ iTunes repair issues; Enter/exit recovery mode; Upgrade/downgrade iOS; Reset device with or without password.
  • Cost: $39.99 for Windows or Mac.
PhoneRescue for iOS
  • Functions: Rescue iOS back to normal; Recover data from iOS (iTunes backup, iCloud backup, with no backup); get into locked iPhone/iPad.
  • Cost: $49.99 for Windows or Mac.
Dr.Fone – system repair
  • Functions: Repair iOS system issues; Fix iTunes errors; Downgrade iOS.
  • Cost: $59.95 for Windows, $69.95 for Mac.
Fixppo iOS system recovery
  • Functions: iOS system repair; Downgrade iOS; Enter/exit recovery mode.
  • Cost: $39.95 for Windows and Mac.
3. Does Apple fix software issues for free?
No, Apple won’t repair software. But you can check what will you cost for what’s happening with your iPhone: https://checkcoverage.apple.com/. And, you can also get the newest iOS version installed to fix software bugs.
That’s all the iPhone repair software we want to recommend. As you can see, the advantages and disadvantages of repair software vary from each other. However, to get better service, you need the purchased version without limited functionality. Weighing all the advantages and disadvantages, we recommend you download AnyFix, which helps you out of various iPhone problems, 200+ iTunes issues, free to reset device, free to upgrade iOS, free to enter recovery mode, etc.
