Is your restore from iCloud paused? You must be wishing to know how to fix the Restore from iCloud Paused issue, and here, you’ll find the right solutions!
I upgraded my iCloud Storage from 50GB to 200GB and now my photo album says “Restore from iCloud Paused” so I have just a few photos in my Library and I don’t know what to do, can anybody please help me? I have an iPhone 11 if that helps.
Many Apple consumers appreciate the convenience of iCloud backups and restoring the backup to a new iPhone. It’s a simple process that can be done from any location. No need to connect your iPhone to a desktop computer via a USB connection and then start iTunes anymore, thanks to this feature. However, there have been concerns that the iCloud restoration is often paused.
iCloud restore takes around 2 to 3 hours to complete in routine according to backup storage. Most people don’t know how to pause the process and get an iPhone to finish restoring from iCloud backup. In this article, you’ll discover some of the finest ways to fix restore from iCloud paused. Let’s get going!
If you have upgraded to a new iPhone 14, you may need to restore an iCloud backup to the new iPhone. Or, when you restore your old phone to its factory settings and lost all of your data, you may use your iCloud backup to retrieve the lost data.
However, there are certain bugs in the procedure that iCloud uses to restore data. One of these problems is that the iCloud restore function sometimes stops working.
In that case, some primary factors that contribute to iCloud restoration being paused are:
If your iCloud restore is paused and you can’t get it running, you must be frustrated. To unpause iCloud restore on an iPhone, follow the below methods:
Turning off your iPhone is the typical way to resolve your restoring from iCloud paused trouble. Restart it after a time, and perhaps the iCloud restore will continue. When you turn off your iPhone, all background applications are closed. If another software causes the mistake, it will be corrected.
Step 1: To begin, hold the Side button down for a few seconds until a slider displays. Then, to turn off your device, move the slider to the right.
Step 2: Wait a few moments before restarting your smartphone. After some time, press down the Side button until the Apple logo displays.
Slide to Power Off and Restart
To Restore iCloud Backup Again:
Step 1: Now, open Settings, go to General, and click on Reset.
Step 2: Press Erase All Content option. After that, set up your iPhone, tap Restore from iCloud Backup, and then pick a backup to restore your iPhone.
If, after restarting the iPhone, it still gets paused in restoration from iCloud, you need to use a professional third-party tool to restore your data from iCloud. PhoneRescue for iOS. It allows you to recover data from your iCloud easily and efficiently. Moreover, you can also fix various iOS/iPadOS problems to resume iCloud restoration.
To restore data from iCloud using PhoneRescue, follow these steps:
Step 1: Download and install PhoneRescue to your PC and launch. Go to the Data Recovery section and click on Recover from iCloud.
Click Recover from iCloud Mode
Note: Ensure that your phone is connected to your PC via a USB cable.
Step 2: Sign in to the iCloud account.
Enter Apple ID and Password to Sign in
Step 3: Click on iCloud backup on the next screen.
Choose iCloud Backup
Step 4: Click on the backup you wish to restore your iPhone to, and click on Next. A pop-up will appear; click on Only Scan Backup. It will scan all the backup files and display them on your screen.
You can Recover Notes to Device or Computer
Step 5: Select the files you wish to restore, and click on To Device in the bottom right corner. The restoration process will start and take up to 2-3 hours.
Now that you’ve successfully restored your iPhone, you wouldn’t wish to have this error in the future. To make sure that you don’t get this error again, follow the below methods:
Low storage space may potentially cause restore from iCloud paused not enough storage issue. Although iCloud restores your data, if you’re running short on storage space, it may halt and get paused on your iPhone. That’s why it’s important to examine your iCloud storage to determine whether that’s the source of your issue. To do so, follow the instructions below:
Step 1: Click on your iCloud account at the top of the Settings app.
Step 2: Then, choose iCloud.
Step 3: Next, look at your iCloud Storage bar and see how much of the storage space is being used and how much is available. If your iCloud space is full, you may need to clear up some space or purchase more iCloud storage.
Check iCloud Storage
To rule out the possibility of restoring from the iCloud issue, you need a professional system recovery tool to resolve your iOS issues. If you want such software, you won’t get a better tool than AnyFix iOS system recovery. It allows you to solve the restore from iCloud paused, iTunes backup failed, upgrade/downgrade the iOS, and many other iPhone issues with ease. Moreover, the tool is easy to use and provides 100% data security.
To solve restore from iCloud paused issues using the AnyFix iOS system recovery tool, follow these steps:
Step 1: Download and install AnyFix and launch it on your PC. After that, click on the System Repair option.
Choose System Repair on the Homepage
Step 2: After that, choose iPhone Problems and click on Start Now to proceed.
Select iPhone Problems
Note: Ensure that your phone is connected to your PC via USB cable.
Step 3: Select Standard Mode on the next screen. The tool will provide the information about the package you need to solve the issue. Check your device’s information, and after validating, click on Download.
Firmware Download Completed
Step 4: Once the package is downloaded, click on Fix Now to get your restore from iCloud paused issue resolved. The recovery process will start and can take up to a few minutes.
Repair Completed
If you are trying to upload photos to iCloud photo library but your phone stopped and says “paused”, you can get it to start uploading again with the below steps:
Step 1. Make sure your iPhone has enough power, trying to connect to charge.
Step 2. Stop syncing and resync: Settings > [your name] > iCloud > Click Photos > Toggle off Sync this iPhone and choose Download Photos & Videos. Then resync.
Toggle Off Sync This iPhone
The most common issue iPhone users get while restoring data from an iPhone is it gets stuck, which can be quite frustrating. But we hope that you know how to fix Restore from iCloud Paused after reading this article. Moreover, we recommend using PhoneRescue tools to carry out the restoration process and ensure that it won’t happen again.
