Cannot connect to the App store to update or download an app either on your iPhone or iPad? Looking for the methods to fix this issue? Here, you will get to know 9 methods or tips that you can try on your iPhone/iPad to fix the App store related issue.
iPhone Cannot Connect to App Store
New apps are updated on the App Store regularly which makes iPhone or iPad users inquisitive to download them. However, in recent days, many iPhone and iPad users have reported that they got a message on their iPhone iPad when trying to connect to the App Store: “Cannot connect to the App Store” or “Unable to connect to the App Store”, and they don’t know what is happening.
Undoubtedly, it is one of the most annoying problems that iDevice users may face. But don’t worry about that too much. There are several methods to fix this iPhone iPad that cannot connect to App Store problem. We have posted this guide with 8 methods that users can try for the proper working of App Store.
You may also like: How to fix iPad won’t download apps
There could be many reasons to get this error “cannot connect to app store” on iPhone or iPad. It may be a software or hardware problem that makes you go through this problem. Here, we have mentioned why you can encounter this issue:
There are 8 effective methods to resolve App Store not connecting problem and you can try them one by one on your iPhone/ iPad.
First of all, check if your iDevice is connected to either a Wi-Fi or a mobile network connection. Make sure that the Internet connection is enabled. Moreover, you need to have a reliable and stable network connection to download or update apps from the app store. Otherwise, the app store will not work properly which causes to face the problem while accessing the app store. You can check both Wi-Fi and cellular connection from settings on your iPhone.
If you have a stable Internet connection, but still facing an “iPhone cannot connect to app store” error, then sign out and sign in again to iTunes & App Store. Sometimes, it helps you solve minor problems. So, to sign out and in with Apple ID, here are the simple steps.
Step 1. Open the “Settings” app on your iPhone and then, navigate to the “iTunes & App store”. Then, tap on the “Apple ID”.
Step 2. Now, tap on the “Sign Out” option. Then, again sign in with your Apple ID by tapping on it.
Now, access the App Store again and see if you are still facing the error. If yes, then move forward toward the below methods.
Fix: iPhone/iPad Cannot Connect to App Store – Log out Account
It may be the reason that the App Store server is down and no one can access it. That’s why before moving forward make sure that there is no problem with the App Store server. You can go to the Apple system status official page to check it and the first one that will be listed is “App Store”. If the dot next to it is green, then it means nothing is wrong with the app store. You are facing the problem App Store not connecting due to your iDevice software issue.
Fix: App Store Not Connecting – Diagnose System Status
If your iPhone has got next software update, but you have not installed it, then it can be the reason why you are facing the problem. Therefore, first, check and update your iPhone to the latest iOS version and then, again connect to the app store.
Step 1. Open the Settings menu on your iPhone and then, move to the “General” menu.
Step 2. Now, tap on “Software Update” and if the next update is available and then, download & install it on your iPhone.
Fix: iPhone/iPad Cannot Connect to App Store – Update iOS
If your iPhone date and time are not right as your country’s time zone, then you can not connect to the app store error. Hence, you need to make sure that you have set the right date and time. You can check the right time for your country on the Internet. To check and set it, follow below simple steps below on your iPhone.
Step 1. Navigate to the Settings app and then, open the “General” settings.
Step 2. After that, tap on the “Date & Time” and if it is wrong, then you modify it.
Fix: iPhone/iPad Cannot Connect to App Store – Check Time and Date
Not clearing your App Store cache for a long time can also put you facing the error. So, a simple way to resolve the error is to clear the cache. Just go to the “App Store” app and then, tap on the “Featured” item or any tab item 10 times. It will automatically clear the App Store cache.
Still facing an error, then it’s time to restart your device as restarting an iPhone can solve many small problems related to software.
Press and hold the Side button and either volume button until the slider appears > Drag the slider to turn your device completely off > Press and hold the Side button again until you see the Apple logo.
Restart iPhone X and Later
Press and hold the Top (or Side) button until the slider appears > Drag the slider to turn your device completely off > Press and hold the Top (or Side) button again until you see the Apple logo.
Restart iPhone 8 and Earlier
If none of the above-mentioned can fix iPhone cannot connect to app store error, and then, go for reset all the settings on your iPhone.
Go to “Settings” > “General” > “Reset” > Tap on “Reset All Settings”.
Fix: iPhone/iPad Cannot Connect to App Store – Reset All Settings
If none of the above methods work and you are here, the last way you can try to fix iPhone cannot connect to the App Store is to repair iOS system. AnyFix is a professional program for 150+ system issues repairing. It will go through your iPhone status quickly and point out the problems. Then make a corresponding fix for your device. To repair iOS system with AnyFix:
Step 1. Download and install AnyFix.
Step 2. Launch AnyFix and use a USB cable to connect your iPhone or iPad.
Step 3. Choose System Repair and then click Start Now.
AnyFix System Repair Option
Step 4. Choose App Issues and then go to the repair mode page.
AnyFix System Repair App Issues
Step 5. Click Standard Repair to fix your iPhone system. There is no worry about data loss with this mode. Then follow the instructions to download a firmware and finish system repair.
AnyFix Standard Repair
After repairing, you can relaunch your App Store on iPhone or iPad and check if it is connected normally.
Hence, we have compiled every method for iPhone iPad users who are facing problems while accessing the App Store. Users can also refer to the above-mentioned methods to fix iPad cannot connect to the App Store and will be able to download or update apps seamlessly. Among all the methods, AnyFix is worth trying without technical skills. Download AnyFix and repair your iOS system now.
