Why will my iPhone not let me erase all content and settings? Here in this post, we have put together the reasons why you might be facing this issue, in addition to several ways to fix this issue and alternative methods to reset your device.
Whether you’re facing a software glitch or any other system-related issue on your iPhone, resetting your device is the most common method to attempt to fix it. However, sometimes you may face the “Erase all Content and Settings” option not working!
In such instances, you will either receive a server or validation failed error or won’t see any response even after tapping “Erase all Content and Settings” numerous times. Why do you get this error? Why iPhone won’t erase all content and settings? And how to erase an iPhone? You will find the answers to all these questions as you read on.
There can be several reasons why your iPhone won’t let you erase all content and settings:
No matter what the reason, you can always fix the issue with some tried and tested quick fixes.
Following, we have discussed a few ways in which you can fix the “Erase all Content and Settings not Working” issue:
If your iPhone won’t erase all contents and settings, the first thing you can do is restart your device using the side buttons. Here’s how to restart different iPhone models:
Force restarting your iPhone is known to solve most iOS glitches and issues. However, if it doesn’t work, you can check whether the internet on your device is turned on or not.
There is a possibility that you may have turned off the internet connection on your device knowingly or unknowingly. Therefore, check your iPhone’s internet connection to rule out this possibility. To check whether the internet connection is turned on:
Check WiFi Connection
If turning on the toggles doesn’t work, or they were already on, it’s time to check for the SIM card.
If you’re getting the “Server Error” when trying to erase or reset your iPhone, it might be due to your SIM card not being present in the iPhone. Insert your SIM card into the slot on the side of your iPhone to fix the issue. If it doesn’t work, or the SIM card is present, and you’re still getting the error, try the next quick fix.
Here are some useful tips to fix some SIM card errors on an iPhone:
One of the most common reasons behind your iPhone acting up or some of its features not working is a possible software bug. Therefore, updating your iOS usually fixes these bugs. To update your iOS:
Download and Install New iOS
Also Read: How to Fix iPhone Stuck on Verifying iOS Update >
Another solution to fix the “Erase all Content and Settings not Working” is to reset your network settings. This will remove all network settings from your device and disconnect you from Wi-Fi and mobile data. When you connect back to the internet, hopefully, you’ll be able to reset your iPhone without an issue. To reset network settings:
Once your network settings have been reset, you can enter them again from scratch and try to erase all content and settings again. In case this method also doesn’t work, you can try turning off the “Find My iPhone” feature.
The “Find My iPhone” is a useful feature by Apple that lets you locate, lock, or remotely erase your iOS device in case it’s lost or stolen. If you have this feature turned on, it could be causing a hindrance in erasing all content and settings. Therefore, try turning it off. Here’s how:
After turning it off, try erasing all content and settings and see if it works. If it doesn’t help, try signing out of Apple ID.
Try signing out of your Apple ID and resetting your iPhone if nothing else works. To sign out:
Sign out of Apple ID
Once signed out, try erasing all content and settings again. This method will probably fix the issue, and you will be successfully able to erase and reset your iPhone. However, if the issue persists, we have some alternative methods to erase all content and settings.
While it is quite worrisome if your iPhone won’t erase all content and settings, you can always reset it using iTunes on your PC. Here’s how to erase all content and settings on your iPhone with iTunes:
This will erase all content and settings from your iPhone and reset it. You will be able to set it up again as a new device.
If you’re using macOS, you can erase your iPhone using it directly from Finder. Here are the steps for it:
And that’s how you erase all content and settings from your iPhone using Mac. After resetting it, you can set it up as new.
If you are selling your iPhone, giving it away, or are trying to fix an issue with the system, we recommend resetting it by erasing all content and settings. However, when you erase all content and settings, it removes all data from your iPhone, including:
Therefore, if you want to keep your data safe, we suggest creating a backup of your iPhone before erasing all content and settings.
Yes, erasing all content and settings is the same as a factory reset because it deletes all the settings, apps, and media from your device and restores it to its original state when you first switched it on.
There can be numerous reasons to reset your iPhone, including experiencing a software error or when you’re giving away your device to someone else. However, you may sometimes face the “Erase all Content and Settings not Working” error. Therefore, we have shared some tips and tricks to fix this issue that worked for many users. We have also included how you can reset it using alternative methods. Hope this article will come in handy if you encounter this issue.
