“I have an iPhone 14 Pro with iOS 16.4.1, and I still cannot get Focus/Do Not Disturb to actually work. It’s turned on, yet every call still comes through.” An iPhone user posted in the forum.
The “Do Not Disturb” (DND) feature on the iPhone is designed to silence calls, alerts, and notifications, helping users maintain focus and avoid interruptions. However, some users have reported issues where DND doesn’t work as expected, leading to unwanted disturbances. If you’re facing this problem, you’re not alone. This article provides detailed instructions on how to troubleshoot and fix the “Do Not Disturb” feature on your iPhone.
You may also like: How to fix notifications not working on iPhone
Sometimes, the issue may be as simple as incorrect scheduling of the DND feature. Here’s how to reschedule it:
Do Not Disturb in Focus
Schedule Do Not Disturb Time
By rescheduling the DND times, you can ensure it activates and deactivates at the right moments.
Your iPhone might still allow calls from certain contacts even when DND is enabled. Here’s how to adjust call settings:
Change Call Settings
Adjusting these settings ensures only the calls you want to receive come through during DND.
Resetting all settings can fix any misconfigurations that might be causing DND to malfunction. Here’s how to do it:
Reset All Settings on iPhone
Resetting settings can resolve conflicts that might prevent DND from working properly.
Repeated Calls allows calls from the same person within three minutes to bypass DND. Here’s how to turn it off:
Turn Off Repeated Calls
Turning off this feature ensures that repeated calls will not bypass DND.
If none of the above methods work, the issue might be caused by some system-related failures. Using a third-party tool like AnyFix iOS system repair can help fix the iPhone system:
Step 1. Download AnyFix and install it on your Windows or Mac computer.
Step 2. Launch AnyFix and connect your iPhone to your computer using a USB cable.
Step 3. Select System Repair from the main page.
AnyFix System Repair Option
Step 4. Choose App Issues and click Start Now to go to the repair mode page.
AnyFix System Repair App Issues
Step 5. Click Standard Mode which will not cause data loss and follow the guides to finish system repair with AnyFix.
AnyFix Standard Repair
AnyFix can resolve many system-level issues that might be affecting DND functionality. Besides, it works well on fixing iPhone boot loop, iPad stuck on verifying updates, and more than 150 system issues efficiently.
If the problem started after a recent iOS update, downgrading to a previous version might help. Before downgrading your iOS system, ensure you have a complete backup of your iPhone. Then you can use AnyFix to downgrade iOS without iTunes.
How to Downgrade iOS:
Step 1. Launch AnyFix and choose Upgrade/Downgrade iOS.
AnyFix Downgrade iOS
Step 2. Choose the downgrade option and choose the firmware package you prefer to download. When the firmware is downloaded, click Downgrade and your iPhone will go back to an older system.
Download Firmware to Downgrade
Downgrading can revert your device to a more stable version where DND works correctly.
Downgrade Completed Page
As a last resort, you can perform a factory reset to resolve persistent issues:
A factory reset will erase all data and restore your iPhone to its original state, potentially resolving the DND issue. Also, you can refer to this tip and learn how to factory reset your iPhone without passcode.
Several reasons can cause DND not to work, including incorrect scheduling, call settings, system glitches, or software bugs. Following the troubleshooting steps in this guide can help resolve these issues.
By default, texts and notifications are silenced during DND. However, if you have set certain contacts as favorites or enabled repeated calls, messages from those contacts might come through. Adjusting your DND settings can help manage this.
The “Do Not Disturb” feature is crucial for maintaining focus and minimizing interruptions on your iPhone. If it’s not working as expected, methods such as rescheduling DND times, adjusting call settings, resetting all settings, turning off repeated calls, repairing the iPhone system, downgrading iOS, or performing a factory reset can help resolve the issue. By following these detailed steps, you can ensure that your iPhone’s DND feature functions correctly, allowing you to enjoy uninterrupted peace.
