If you encounter the Apple ID sign-in request issue, you must find it very annoying but don’t know what’s causing it and how to fix it. So, in this article, you can get the cause of the problem and 5 tricks to solve it, as well as an additional method for the Apple ID verification keeps popping up with wrong email problem!
No doubt, the Apple ID feature is one of the most brilliant advanced technologies integrated into all Apple devices, including iPhones, iPad, and Mac. This feature lets every user create a unique identity on Apple cloud. Plus it grants you access to iCloud backup and iTunes storage facilities. In addition, it helps you secure your device.
Unless you log out of your Apple ID on your device, it remains logged in. However, the reverse has been the case recently as most users now complain of frequent Apple ID sign in request pop up. This article is for you if you also experience similar issues and need a solution. In this post, we will look at the top 5 official solutions to fix Apple ID sign in requests keeps popping up.
Apple ID sign in request keeps popping up on your device for several reasons. While this could be attributed to the device’s inactivity, as in when you do not use your iPhone for a long time, it can also be caused by outdated software versions and system glitches.
Another reason you may encounter this issue is when your Apple details are being logged in on another device. Additionally, it could be caused by wrong iCloud settings. Regardless of the reasons, you can fix the issue with the snap of a finger.
There are five (5) official ways and one ultimate solution to stop the Apple ID sign-in request error from popping up on your screen. We will start with the official solution. Read on.
Restarting your iPhone is the first step to fixing any issues or errors you encounter on it. This solution fixes your device by clearing the bugs causing it to glitch or malfunction.
It’s an effective solution, cost-free and straightforward to use. To restart your iPhone, select the appropriate procedure that suits your iPhone model:
iPhone SE (1st Generation)/ 5/ older generations
iPhone 6/7/8/ SE (2nd and 3rd Generations)
iPhone X/11/12/13/14 series
Restart Different Modes of iPhone
When your iPhone comes up, it should start functioning properly.
As earlier stated, improper iCloud settings can cause your iPhone to malfunction, such that you encounter Apple ID sign in request pop-up issues. If the aforementioned solution doesn’t work, then signing out of iCloud could solve the issue.
This solution is cost-free and simple to implement. It works for all iOS models, including the latest generations. To sign out of your iCloud, here is the detailed procedure you need to follow:
Sign Out Old iCloud Account
An outdated iOS version often causes an iDevice to misfunction. End-users may encounter issues ranging from non-responsive keys to frozen screens and more. You may even experience Apple ID sign-in request keeps popping up issues.
To fix this, updating your iPhone software is the best thing to do. Follow the detailed instructions below to update your iPhone:
Check Software Update
It’s a norm to alter the default settings on your iPhone. While this is done to suit your desire, it sometimes affects the device. Changing your iPhone can cause Apple ID sign-in request keeps popping up.
There’s no way to fix this besides resetting your iPhone settings. By doing this, your device resets to factory settings. This solution erases those settings causing your iDevice to glitch.
Follow the guide below to reset all settings:
Reset All Settings on iPhone
Here is another helpful solution to fix Apple ID sign in request error. When you reset your Apple ID password, hackers or intruders find it difficult to compromise your account.
Follow the instructions below to reset your Apple ID password:
Change Password from iPhone
If you get an error email address when trying to log in to your Apple ID or if you have forgotten your previous Apple ID and password, AnyUnlock – iPhone Password Unlocker is a great software program to accomplish that. With this tool, you can bypass the verification code stage and unlock your Apple ID
This tool is often considered the master key to all iOS devices because of its extensive unlock features. From bypassing screen time passcodes to bypassing activation lock to removing iTunes passwords to SIM unlock and more.
Key Features
Step 1. Install the latest version of AnyUnlock from the official website. Launch the software and select Unlock Apple ID.
Click Unlock Apple ID from the Homepage
Step 2. Connect your iPhone to the computer system with the aid of a USB cord. After your device has been detected, click Unlock Now.
Click Unlock Now Button
Step 3. Then AnyUnlock will remove Apple ID and iCloud account on iPhone automatically. Minutes later, you’ll see the Apple ID removed successfully page.
Apple ID Removed Successfully
Here are some extended knowledge questions and the appropriate answers to help you understand the topic better:
Yes, you will be notified when someone tries to access your Apple ID. Apple sends a notification to the email address you used in creating the Apple ID account, so you know your details have been logged into on another device. Sometimes you may get a 6-digit code if you enable 2FA.
Regardless of the notification option, if you carried out this operation, then no need to worry. But if you didn’t, we advise that you consider resetting your password. You can do that by following the guide given above.
There’s no way to see who tried to access or log into your Apple ID. However, you can find out which device was used to access your Apple ID and the exact location it occurred.
Check out the appropriate guide that suits the platform you want to use:
iPhone/iPad/iPod Touch or Apple Wristwatch
Mac
Not that you have our tutorial guide at your disposal, fixing Apple ID sign in request keeps popping up issues shouldn’t be a problem anymore. The guide shows 5 powerful solutions to fix the issue.
More than that, we also provide you a helpful guide on how to fix Apple ID verification keeps popping up with wrong email issue. If you are experiencing such problems, or if you are suffering from screen lock, mdm lock or activation lock, don’t hesitate to download AnyUnlock to help you get out of it!
