This article will explain how to manage iCloud storage. We have provided various methods with a step-by-step guide to help you understand better. So, if you are always confused about what to delete and keep to free up iCloud storage, this article is for you.
Are you tired of seeing that “iCloud Storage Full” notification on your iPhone? It’s frustrating when your phone storage gets full, leaving no room for your pictures, apps, and important files.
How to Manage & Free Up iCloud Storage
But don’t worry! In this article, we are going to show you how to manage iCloud storage. Whether you are an iPhone photographer or a busy professional juggling with documents, we have you covered.
Say goodbye to the days of unwillingly deleting cherished memories or buying iCloud storage. We will walk you through effective tips on how to free up iCloud storage while keeping your important stuff. Let’s get started!
Further Reading: How to Transfer Data from iCloud to iCloud >>
If you’re an Apple user, then you probably know that every iOS user gets about 5GB of free iCloud storage. iCloud storage is like a virtual storage space for all your digital stuff. It’s where you can keep your photos, videos, documents, and other important files. Think of it as a giant cloud attic for your digital belongings.
The amazing part is that you can access your stuff from any of your Apple devices, like your iPhone, iPad, or Mac. It’s like having your own personal locker in the sky!
What is iCloud Storage
But like a real attic, your iCloud storage can fill up over time. When that happens, you might get annoying notifications telling you you’re running out of space. Not fun, right?
There are ways to manage and free up your iCloud storage. We’ll show you simple tips to clear the clutter and make room for new memories and files. Let’s see how!
You can start by looking at what’s taking up your memory when managing your iCloud storage
How to see iCloud storage? Go to Settings > Apple ID > iCloud > Manage Storage to see your iCloud storage on your iPhone.
iCloud Storage on iPhone
Managing your iCloud storage doesn’t have to be a daunting task. Just by following a few straightforward steps, you can take control of your storage space and keep things running smoothly. Here’s how to do it:
Follow the instructions given below to manage iCloud storage on your iPhone effectively:
Start by understanding what is taking up the most space in your iCloud storage. Go to your iCloud storage, as shown earlier, to see a breakdown of your storage usage. You will see and get to know where most of your space is being used.
Breakdown of iCloud Storage on iPhone
Photos and videos often occupy a major amount of iCloud storage. Review your gallery and delete any duplicates, blurry, or unwanted images. You can also export your media to your computer or an external hard drive.
Some apps can use up a major amount of iCloud storage. Check the apps using iCloud and consider disabling those not crucial to your daily use. Go to the iCloud Storage menu. From there, tap on an app to see the data it’s storing and choose whether to delete or disable iCloud backup for that app.
iCloud automatically creates backups of your device’s data. However, these backups can take up a significant amount of storage. Regularly review your backups and delete any old or unnecessary ones. You can manage your backups through the iCloud settings on your device.
We saw how to manage iCloud storage on iPhone. Now, let’s move towards freeing up the space.
If your iCloud storage is running low, it’s time to free up some space by removing things you don’t need. There are different ways to do that. Let’s explore some effective ways to clean up your iCloud storage.
While clearing the iCloud storage space, the mailbox is one of the first areas to tackle. An average person can receive a lot of promotional emails every day. Over time these emails can start to pile up and occupy a significant amount of storage in iCloud.
iCloud Mail storage on iPhone
Following the above steps, you can clean up your mailbox and free up iCloud storage. Or you can try the next way.
Another way to clear iCloud storage is by transferring your data to a PC. You must think of it as a hassle, but let us introduce AnyTrans – iPhone Data Manager, which will make the job easier for you. With AnyTrans, you can back up all your iPhone data to your PC in just a few simple steps.
This powerful tool is not just limited to data transferring. It has many other features as well. If you are an iOS user and need an app to manage, transfer, and back up your data easily and quickly, just getting AnyTrans will be enough! Let’s check what it can do for you:
Step 1. Download and launch AnyTrans on your computer > Select the iCloud Manager option, and then sign in to your iCloud account.
Sign in iCloud Account in AnyTrans
Step 2. Click Connect to PC option on the right. Now Anytrans will load all the files on your iCloud storage.
Click Connect to PC.
Step 3. Select the files or categories you want to export to your PC and click Next. Your iCloud data will start to export to your PC.
Select the files you want to export
Once the export process is completed, you can click view files to locate exported data on the computer.
One more effective way to free up iCloud storage is deleting files from iCloud Drive. Sometimes plenty of documents you no longer need are saved on iCloud Drive. Deleting them will allow you to get rid of unnecessary files and free up valuable space.
iCloud Document and Data
In this way, you can effortlessly reduce your iCloud Storage usage. But if you don’t want to delete your files, go for another method.
Whatsapp is the most common medium of communication nowadays. No doubt, text messages won’t take up much space, but the media, such as photos, videos, and audio, can. You need to delete them to reduce iCloud Storage. Otherwise, there is an option to back up all of your WhatsApp data to your PC with AnyTrans.
As a professional data management tool, AnyTrans not only provides an easy and safe way to manage your files on iOS devices but also allows you to transfer WhatsApp Messages from your iOS device to your computer.
Step 1. Free get AnyTrans on your computer > Connect your iPhone via USB cable.
Step 2. Once your iOS device is recognized, you will see the main interface. Select Social Messages Manager and then click Back Up WhatsApp.
Back up WhatsApp Files with AnyTrans
Step 3. You must turn on Enable Backup Encryption to keep your backup safe and private. Then click Back Up Now to proceed.
Click Back Up Now
AnyTrans will start the backup process. Once it’s done, you will see the below interface, you can tap on View button to locate the backup on your computer.
Sometimes, you may notice you don’t have much media on your iPhone, but iCloud Storage is still full. In that case, storage may be occupied by apps. To solve this issue, you need to restrict apps from using iCloud Storage. It will stop them from backing up their data to iCloud, ultimately making storage space.
iCloud Storage
You can save significant storage space by restricting apps from using iCloud for backup.
You can easily increase the storage capacity if you run out of iCloud storage. Go to your device’s Settings, tap your name, and select iCloud > Manage Account Storage.
Upgrade to iCloud+
Choose “Upgrade to iCloud+” and pick the plan that suits your needs and budget. It’s a hassle-free way to get more space for your files, backups, and everything else you want to store in iCloud.
We hope the methods explained in this article have helped you find out how to free up iCloud storage on your iPhone. Now you don’t have to take it on your nerves if your storage gets full; you can follow any suitable way and free your iCloud storage.
However, AnyTrans is an all-in-one manager for your iPod, iPad, iPhone, iTunes, and iCloud content. If you find it daunting to back up the data to your computer, download AnyTrans. This tool will help you manage your iCloud storage hassle-free.
