If you are looking for the method on how to install IPA without jailbreak, then refer to this guide. Here, we have given 3 easy and simple ways to install IPA files on iPhone without jailbreaking it.
Want to install IPA files on iPhone without jailbreak? This article is intended to show you an alternative to iTunes to help you install IPA without jailbreak. Keep reading on this post to learn more.
What is a .ipa file in iOS? A file that has a “.ipa” file extension refers to an iOS App file. An iOS App Store Package file or .ipa file stores iOS apps. These files can only be installed on iOS devices, and not on the computer. These files are usually saved in a compressed format and you can uncompress them by unzipping or renaming the extension to .zip. The official way to install the IPA files on iPhone without jailbreak is using iTunes.
IPA Files on iPhone
However, iTunes 12.7 update canceled the Apps tab in Device option either so you can not manage your apps on iPhone/iPad. Here we will introduce 3 ways to install .ipa file without jailbreaking. Keep reading and you will find a suitable way to do.
Also Read: Why Tones/Ringtones Not Showing in iTunes >
There are a lot of tools available that allow users to install IPA files on the iPhone, but only a handful of them to do this without jailbreaking iPhone. AnyTrans is one of them that aid you to install .ipa App without jailbreak. The software is developed by iMobie to make it easy and fast for iOS users to manage and transfer their iDevice content to iPhone, Android device, and computer. Here are its main features:
Now, here is the detailed guide about how to install IPA on iPhone without jailbreak with the help of AnyTrans. In the beginning, download and install AnyTrans on the computer.
Step 1. Firstly, you need to save the .ipa files on your computer, then, launch Anytrans and connect your iDevice to the computer using a cable and then, click on the “Apps” icon as shown below.
Go to Device Manager and Click App Category
Step 2. Now, tap on the “+” button at the top-right and then, select the .ipa file you want to install on your iPhone and finally, click “Open” to begin the transfer process.
Click Add Button and Install it to iPhone
AnyTrans can help you get .ipa file on your iPhone/iPad. Besides, with this professional iOS manager, you can export .ipa files on your Mac or Windows computer easily. Now, you can continue to follow the simple steps to export the .ipa file and launch the app on your M1 Mac:
Step 1: Go to App Download from the homepage of AnyTrans > Sign in your Apple ID and password first > Search any app you want to download. Here we take Youtube as an example. Then click the download icon.
Sign into iCloud and Search the App you Need
Step 2: Click Download button, and when the process finished, click To Mac button. Then you can save the .ipa file on your computer.
Install the App to Mac
Step 3: Next, you can view the .ipa file on your computer, and also you can launch the exported app if you’re own an M1 Mac.
You can Launch the Downloaded App Immediately
After you get .ipa files on your computer, you may wonder if the apps are compatible for M1 Mac, which is the newly released silicon by Apple. Here is a free and professional M1 App Checker can help you, which can check if any one of the apps on your Mac/iPhone are M1 compatible. Then you can run the iOS apps on an M1 Mac by exporting .ipa files with AnyTrans.
Apple M1 Compatibility Checker for Mac and iPhone Apps
There is another choice for you to install .ipa files without jailbreak. This method doesn’t require any other software apart it to install the iOS app(.ipa) to a mobile device, just follow the steps below:
Install IPA Files with iTunes
The third way that you can use to install .ipa files is an online tool – Install on Air. It is a tool that can help iOS and Android users to download apps. You can also drag and drop the .ipa file to get a link. Then open it using mobile browsers (Safari on iPhone) and you will be enabled to download and install the applications with a tap. Here are the detailed steps that you can use:
Online IPA Files Installer
Some iPhone users have reported their iPhone got into trouble after install .ipa files without jailbreak. Like keeping restarting, stuck on the Apple logo, frozen, etc. But no worries! Here we’ll recommend a professional iTunes/iOS system issues troubleshooter, AnyFix – iOS system recovery, which is committees to getting iPhone/iPad/iPod users out of any system/iTunes issues. Give it a try, and you can successfully remove these annoying problems in just a few clicks.
Get the latest version of AnyFix and run it on your computer > connect your iPhone to the computer and then choose the System Repair or iTunes Repair.
How to Solve iTunes/System Issues via AnyFix
The above there methods can help you installing .ipa files on iPhone without jailbreak. And with AnyTrans, you can also install .ipa files on iPad. Also, it is malware-free software and that’s why it is safe to use on your computer. You can manage your iPhone content on the computer if you are tired of using a small iPhone screen. Still, if you have any queries or doubts, feel free to leave your comment below.
