5 Easy Ways to Import VCF to iPhone [Full Guide]
To find a proper way to import VCF to iPhone, you may need to read this tutorial thoroughly. Here, you can learn 5 proven methods to finish the task. Just choose one you like.
Author Avatar Joy Taylor Last Updated: Dec. 26, 2022
AnyTrans – Import VCF to iPhone
How to import VCF file in iPhone? It is quite easy with AnyTrans, a professional iOS data manager. With this tool, you can import contacts from VCF to iPhone only with 1 click. Just free download AnyTrans to have a try.
iPhone is one of the most common Smartphones that people own these days. Unlike Android, performing functions on iPhone is pretty much daunting, but in reality, it is not as confusing as it sounds. Now, when it comes to importing contacts from Gmail, iCloud, Outlook, or any other platform to your iOS device, you first export contacts from Outlook or Gmail to VCF and then move the VCF file to iPhone.
However, if you are trying to import VCF to iPhone, you may find you are unable to do that, because, in fact, there is no direct way to do so. Then, how to import VCF file in iPhone? So, if you are also wondering how to import contacts from VCF file in iPhone, keep reading this article, and you’ll discover easy ways to import VCF to iPhone.
Import VCF to iPhone in 2 Steps
How do I import contacts from VCF to Apple? The easiest way, for now, is to do it with AnyTrans – iPhone Data Manager. With this professional iOS manager, you can import vCard to iPhone in only 2 steps. And the whole process only requires you to click on buttons, so even the novices can complete importing VCF file iPhone at home. Whether you want to VCF to iPhone from Android or from iOS devices, it can do it all for you.
In addition, you can transfer also transfer photos, videos, call logs, WhatsApp data, App data, etc. from Android/iDevices to iDevices/computer in simple clicks with AnyTrans. And before using this tool to import VCF to iPhone, you may check some of AnyTrans’ main features below to get a better understanding.
  • Import contacts from VCF to iPhone with simple clicks.
  • Only a few minutes are needed. As fast as possible.
  • No data loss, leakage, or unreadable code, safe and clear.
  • Supports all iOS versions and iPhone models.
Now you can follow the steps below to import vCard to iPhone.
Import VCF to iPhone in 2 Steps:
Step 1. Free download and run AnyTrans on your computer > Connect your iPhone to the computer with a USB cable > Choose Device Manager > Click Contacts.
Connect Your iPhone to the Computer
Connect Your iPhone to the Computer and Choose Contacts
Step 2. Click the Import button > Pick up the file of contacts you want to transfer to iPhone > Click Open to transfer contacts from computer to iPhone.
Click Transfer to Device to Import VCF
Import VCF to iPhone with iCloud
How to open VCF file in iPhone and import it to iPhone? In fact, for most iOS users, iCloud provides a way to import VCF to iPhone. It is a platform that enables you to import the VCF file iPhone to cloud storage and then sync the contacts across your device through the same iCloud account. All this is done by enabling iCloud contacts. Don’t know the steps to import VCF to iPhone in this way? Here they are.
Import vCard to iPhone via iCloud:
  1. Open the browser and go to iCloud.com on your PC.
  2. Now, sign in with the Apple ID that you use on your iPhone and click on Contacts.
  3. Next, tap on Settings and select Import vCard.
  4. Here, select the VCF File and upload it to iCloud.
  5. Now, open your iPhone and go to Settings > Your Name > iCloud and turn on Contacts.
  6. Once you are done with syncing, navigate to the Contacts app and check whether the contacts are imported from the VCF file.
Sync VCF Files to iPhone via iCloud
And it’s done! Remember that, in order to use any cloud-based service, you need to make sure that there is enough storage and stable internet connectivity.
Import VCF to iPhone with Email
How do I transfer VCF files to iPhone without iCloud? If you don’t want to use iCloud, in addition to AnyTrans, another way to make iPhone import VCF is to use an email. By simply attaching the VCF files to an email and sending the mail to your iPhone, you can flawlessly VCF files to iPhone with ease. By this, you can access the VCF files and then import contacts directly to your iPhone within the Mail application. Here are the steps to import VCF to iPhone with Email:
  1. Create an email, add the VCF file to it as an attachment and then send the Email to your iOS device.
  2. Next, check the mail on your iOS device and click on the VCF file received.
  3. Now, click on Share > More > Contacts.
  4. On the next screen, tap on “Create New Contacts” to import contacts from the VCF file to your iOS device.
Import VCF to iPhone via Email
That’s it! Importing VCF to iPhone with Email is just a 4 step process, and it’s done.
Import VCF to iPhone Using Gmail
If the above method didn’t help you import VCF to iPhone, then try importing it by using Gmail. Before starting the process, make sure that you have the latest version of iTunes on your PC and an activated Google account. Once you are done with all this, you can then begin with the subsequent steps that involve to import contacts from VCF to iPhone:
  1. Open mail.google.com on your PC and enter your Gmail username and password to log in.
  2. Sync the VCF file to Gmail and then click on Contacts > More > Import > Choose file.
  3. Now, choose the storage path where you want to save the VCF files and then click the Import button again to upload the VCF file to your Gmail account.
  4. Next, run iTunes on your PC and connect your iPhone to the PC via a USB cable. Then, click the iPhone icon at the top left corner of the screen and tap Info.
  5. Here, check Sync Contacts with > pick Google Contacts from the options and hit the Apply or Sync button.
Transfer Contacts from Computer to iPhone
Now, wait for the syncing process to get completed, and finally, you will be successful in importing VCF to iPhone via Gmail.
Import VCF to iPhone via Outlook
Another choice to import VCF to iPhone is via Outlook. Outlook is basically a mail provider just like Gmail. So, if you are using a Microsoft Outlook account, then it will be pretty easy for you to move the VCF file to iPhone.
Follow the steps below to import VCF to iPhone via Outlook:
  1. Initially, set up your Outlook account with Exchange.
  2. Now, go to the Settings of your iOS device and click on Mail, Contacts, Calendars > Account > Add Account > Exchange.
  3. Here, enter your Outlook account and password to log in and hit the Next button to proceed.
  4. Your iPhone will now contact the Exchange Server. Wait for a couple of minutes and enter the Exchange Server address in the related field.
  5. Finally, switch Contacts on and click on the Save button.
Add An Account
Add An Account
Now, the Outlook contacts will automatically get synced to your iPhone within just a few minutes.
Here we’ve come to the end of this guide! You can now import VCF to iPhone with any of the methods stated above but make sure to go thoroughly through each method in order to get the best understanding of each. Also, no matter which way you opt for, you will surely get delivered with excellent results. But if you want to import contacts from VCF to iPhone in the easiest and fastest manner, or to transfer contacts to iPhone directly, AnyTrans is undoubtedly your best choice. So why not give AnyTrans a free try?
