The error “a device attached to the system is not functioning” occurs for multiple reasons. You can easily fix it with the 7 fixes mentioned in this article.
Have you ever encountered a popup “a device attached to the system is not working”? If yes, you will know how frustrating it is when the system fails to connect with the attached device. It may happen for multiple reasons ranging from connection issues to malfunctioning drivers.
Luckily, you won’t see this error again! Because this article will give a comprehensive guide about the causes and solutions to such a problem. Before we proceed to fix this error, let’s first have a glance at why it occurs.
“A device attached to the system is not working” appears for many reasons. The following are some of them:
The most common problem, however, is a connection issue between the device and the computer. Primarily it occurs when the USB wire or port does not function properly.
Are you curious to know about fixing these issues? If yes, it’s the right time to jump toward possible fixes.
The following 7 fixes will help you to get rid of the issue “a device attached to the system is not working.”
It is quite possible the USB cable/ port that you are trying to connect isn’t functioning correctly. You can try a different USB port just to check whether it makes a difference.
If the other USB cable works, it indicates that the last USB port had some issues. Hopefully! You won’t see again “a device attached to the system is not working.”
When your iPhone fails to send photos to the system, you may need to free up storage. It usually happens due to insufficient storage space. Follow the steps mentioned below to free up iPhone Space.
Select iPhone Storage
Sometimes the error “a device attached to the system is not working” occurs when the device fails to convert HEIC to a proper format. Though it’s not a big deal! Simply! Share original files instead of converting them to some other format. Just follow the steps mentioned below:
Step 1. Go to Setting on your iPhone.
Step 2. Scroll down and click on Photos.
Step 3. Search the “Transfer to PC or Mac” section at the bottom.
Step 4. Select Keep Originals.
It’s no more a problem to transfer data from iPhone to the system using AnyTrans – iPhone Data Manager. It is an all-round tool for iOS data transfer, backup, and management, and can help you transfer data from iPhone/iPad to iPhone/iPad/computer. Therefore, if you have encountered “a device attached to the system is not functioning iPhone” problem, AnyTrans must be a good solution for you. Below are some of the key features of AnyTrans.
In addition, AnyTrans can also allow you to restore data from local backups or iTunes/iCloud backups, so that you don’t need to worry about data loss. And if you want to move data from Android to an iOS device, it can also help you do that.
Just free download AnyTrans and follow the steps mentioned below to transfer your data.
Step 1. First, run AnyTrans on your Mac computer or PC. Connect your computer to the iPhone using a USB cable. Go to Device Manager > Select Photos.
Go to Device Manager and Choose Photos
Step 2. Then you can preview and select the photos you want to transfer to your PC or Mac computer.
Choose Photos You Want to Transfer
Step 3. Click To Mac or To PC button to copy photos from your phone to your Mac or PC. Once it is completed, all the exported photos will be saved in the right folder on your computer.
Transfer Photos to Computer Successfully
Outdated or malfunctioning divide drivers can also cause the issue “a device attached to the system is not functioning iPhone.” The following steps will help you to update the device drivers.
Step 1. Press Win + R to open “Run Dialog Box”.
Step 2. In the open file, type devmgmt.msc and press Enter.
Step 3. Then right-click on the malfunctioning or outdated device and select update driver.
Step 4. Choose Search automatically for drivers to allow windows to find and install the best device drivers.
Choose Search Automatically for Drivers
Windows’ built-in diagnostic tools can help fix the issue of corrupted or missing system files. So, you can fix the issue “ “a device attached to the system is not functioning.”
SFC (System File Checker) DISM (Deployment Image Servicing & Management) scans will automatically detect and replace any corrupted or damaged file with its cached version. Below is how it works.
Step 1. Press Win + X. Choose Terminal (Admin) from the given list.
Step 2. Select Yes as the UAC( User Account Controls) prompts appear on the screen.
Step 3. Paste Command: sfc /SCANNOW in the console, and finally, press Enter.
Step 4. After running the SFC scan, you can run the DISM scan. To run DISM scan copy and paste Command: DISM.exe /Online /Cleanup-Image /Restorehealth
Step 5. DISM will automatically detect the issue with the system image. After scan, DISM will connect with Windows Update online to fix the issues of the damaged files.
Step 6. It will either download or replace them. Finally, restart your Window and check whether the issue is solved or not.
Another fix to eliminate the error “ a device attached to the system is not functioning” is using windows safe mode. The following steps will help you to reboot your PC or Mac in Windows Safe Mode.
Step 1. Go to Setting. Select Update and Security.
Step 2. Tap on Recovery. Click on Restart now option.
Tap on Recovery
Step 3. Select Troubleshoot > Advanced options > Startup Settings > Restart.
Step 4. Select 4 to enter the safe mode.
Step 5. Now check the device connectivity in safe mode.
Step 6. If it works well in this mode, the issues were due to newly installed applications on the system.
Step 7. Identify the application causing the error and remove it from your system.
“A device attached to the system is not functioning” can appear when connecting the phone to the system. It can happen for many reasons, such as corrupted files, malfunctioning device drivers, insufficient storage space, etc. Though it’s not a thing to worry about! You can easily fix the issue “A device attached to the system is not functioning iPhone” by simply trying the abovementioned fixes. And if you want to transfer your photos or other data to another iOS device or computer quickly and easily, just get AnyTrans for free and have a try now.
