Are you trying to update the version of iOS to iOS 18 but unfortunately, iOS update stuck on terms and conditions? If yes, then you don’t need to fret anymore as this guide has got multiple solutions to fix your issue. Read the entire guide thoroughly and choose the method that fits your requirements!
Apple frequently introduces new iOS versions to offer an excellent iOS experience to iPhone and iPad users. Recently, an iOS 18 update was released that is expected to boast very exciting features. Whether it’s about the New App Library, a whole new redesigned home screen with widgets, App Clips, No full-screen calls, or Improvement and Fixes, iOS 18 will give you a wonderful iPhone experience. But wait!! Is your iPhone update stuck on terms and conditions? Unfortunately, there are many iOS users who are facing this issue but luckily, we have got the fixes.
iPhone Stuck on Terms and Conditions
Here in this guide, we had covered the top fixes that you must try when your iOS update stuck on terms and conditions. Not only this, but we will also uncover the reason behind this issue.
Let’s start then!
Before diving into the solutions to fix iOS 18 stuck on terms and conditions, it’s important to know why this issue arises.
Well, this is because Apple releases multiple beta updates throughout the preview period. All those releases consist of updates that can make an application malfunction. As per research, any software update contains some amount of bugs, and the latest iOS 18 has a series of bugs, which is what is causing the iPhone update stuck on terms and conditions issue.
Solving this issue is not as tough as it sounds to be! You don’t need to worry about the fixes, as below are the necessary methods that you can try to get out of this issue flawlessly.
Here’s a list of the top six methods to help you get out of iOS 18 stuck on terms and conditions issues without much hassle.
Performing a Force Restart on your iPhone is the easiest way to fix any iPhone issue. So, why not try fixing the iOS update stuck on terms and conditions error with the same method. Below are the steps to follow.
Restart Different Modes of iPhone
1. Press and hold the Power button of your iPhone for a couple of seconds.
2. Wait for few minutes for the Power Off option to be visible on the screen.
3. Swipe the Power Off slider.
4. Press and hold the Power button and wait for your iPhone to turn ON.
5. Enter your iPhone’s passcode at startup, even if you generally use Fingerprint lock.
You can now try installing the iOS 18 update on your iPhone. If it is still not working, then try the next method.
Another way to fix this problem is by signing out iCloud Account and downloading the iOS 18 again. This is one of those solutions that worked for many iPhone users. So, why not get your hands on this method and try resolving the iOS 18 stuck on terms and conditions issue. For this, you need to:
Sign Out iCloud Account and Download iOS 18 Again
1. Go to Settings in your iPhone, tap on your name, and hit the Sign Out button.
2. After clicking the Sign Out button, your iPhone will ask you to create a copy of your iCloud data. Here, choose everything.
3. Now, restart your iPhone and sign in again. For this, go to Settings and click on the Sign In option. Make sure to tap on Merge when prompted.
You can now try installing the iOS 18 update and check if it’s working fine! If no, then follow the next method.
Are you hunting for a quick fix to resolve the iPhone update stuck on terms and conditions issue? If yes, then we are here with an ultimate tool, i.e., AnyFix – iOS System Recovery, that can resolve any iOS related issue with one click. No matter what issue you face with your iOS device, AnyFix will revive your Apple device within just a few minutes. It is a one-stop solution to fix 150+ iOS related issues that can bring back your Apple device to normal without data loss.
With the highest success rate guaranteed, AnyFix offers three repair modes for you to choose on the basis of how severe the iOS related issue is! To know more about using AnyFix, refer to the steps below.
Step 1. Download and launch AnyFix on your PC. One the main interface, choose System Repair option and connect your iOS device to the PC via a USB cable. Once your iOS device is detected, click on Start Now button to get started.
AnyFix System Repair Option
Step 2. Now, select a mode to repair your iPhone. In order to fix iOS 18 stuck on terms and conditions issue, choose Standard Repair mode and then enter your device into Recovery Mode. After entering Recovery Mode, hit the Download button to download matched firmware package.
Choose Standard Repair in System Repair
Step 3. Once the firmware is successfully downloaded, click the Fix Now button and wait for the repairing process to get completed.
Firmware Download Completed
Step 4. Lastly, when the recovery process is finished, you will see the completed page as shown below.
System Repair Completed
That’s all! In just a few clicks, AnyFix will solve the system-related issues in your iOS device, and you will then be able to install the iOS 18 update on your iPhone without any hassle.
It may sound pretty out of the box, but changing the Language and Region of your iPhone can help you resolve a handful of common iOS system-related issues without much effort. Many iOS users who were facing the iOS 18 stuck on terms and conditions issue on their iPhones tried this method, and some of them succeeded in fixing the issue. So, you can also try fixing the same issue with this method that works as follows.
Change Language & Region
1. On your iPhone, go to Settings and tap on General.
2. Here, click on Language & Region.
3. Next, set the following: The language for iPhone > Region > Temperature unit (Celsius or Fahrenheit) > Calendar Format.
4. In order to add another language and keyboard to your iPhone, click on Add Language and then select the appropriate language.
It is quick and straightforward to change the Language & Region for iPhone. You can now check if the issue is resolved! If the issue still persists, then move on to the next method.
Every now and then, we connect our phones to the Wireless Connections in order to have a flawless internet experience but sometimes connecting to the Wireless connections may cause an issue in downloading the new iOS 18 update, and therefore users might be stuck on Terms and Conditions while updating their iOS version. So, if you are doing the same thing, then try fixing the issue by disconnecting the iPhone from Wireless Connections. Here’s how this method works.
Disconnect iPhone from Wireless Connections
1. Click on Settings on your iPhone’s home screen.
2. Click on Wi-Fi.
3. Tap the On/Off toggle to the right of Wi-Fi until it reads Off with a grey color background.
In just three simple steps, you have disconnected your iPhone from Wireless connections.
Last but not least, if the iPhone update stuck on terms and conditions issue is still not fixed, then try fixing the issue by resetting the Network Settings. Here’s how this method works.
Reset Network Settings
1. Open your iPhone and go to Settings app.
2. Click on General.
3. Scroll to the bottom of the screen and tap on Reset option.
4. Under Reset, click on Reset Network Settings.
5. If prompted, enter your iPhone’s passcode and click on Reset Network Settings again to confirm.
That’s all! Check if you can now install the iOS 18 update on your iPhone.
In addition to the problem discussed above, you may encounter several other issues with your iOS device when it comes to updating to the latest iOS 18. So, if you have still not updated your iPhone to iOS 18 but planning to do so, then make sure to have a look at some of the other issues that your iPhone may cause while updating to iOS 18.
Preparing for the update is one of the phases that your iOS device goes through when you try to install the iOS 18 update. The main purpose of this phase is to prepare the iOS 18 update to be installed on your device. But sometimes, due to iOS update bugs, your iOS 18 might be stuck on preparing updates but resolving this issue is not as challenging as it sounds with the right method and tools in hand.
There are times when you try downloading the iOS 18 update on your iPhone, but suddenly a pop-up appears on the screen that reads as iPhone software update failed. You may retry installing the update, but it again fails. Well, this is a common iOS 18 update issue that is faced by many iPhone users, but you don’t need to worry as there are multiple fixes to fix iPhone software update failed errors.
Last but not least, another common issue that iPhone users encounter while installing the iOS 18 update is that the iOS 18 update is stuck on verifying updates. In this issue, you try to install iOS 18, but Verifying Update…. pop-up does not go away. It appears on your screen for several minutes, but nothing happens. In general, this process takes a few seconds or minutes, but if it’s stuck for more than 15 minutes, then it’s quite likely that there’s some issue with it that needs to be fixed. You can refer to any of the reliable guides to fix this issue.
So far, we have discussed all the top methods on how to fix iOS update stuck on terms and conditions issues. We hope the methods included in this guide will surely help you resolve the iOS 18 update error, and in case you are hunting for a more advanced way to fix the issue, then it’s highly recommended to use AnyFix as this tool has everything to help you get rid of not just iOS update related issue but with other iOS issues as well. So, install AnyFix now and fix iOS issues in a hassle-free way!
With AnyFix – iOS System Recovery you can quickly fix iOS 18 update issues including iPhone stuck on preparing update and unable to install the update, etc!
