[iOS 18] How to Fix iPad Stuck on Verifying Update 2024
“My iPad is frozen on verifying update… I can not cancel update or turn it off, when I try to force restart, it will not let me slide the to power off. I have tried plugging it up to my MacBook, told it to trust device, but the iPad still does nothing. It has been frozen for around 24 hours.” – An iPad Pro user asked on Apple Community.
Author Avatar Joy Taylor Last Updated: Sep. 18, 2024
Many iPad users have encountered a common issue where their device gets stuck on the “verifying update” screen during an iOS update, especially after iOS 18 update. This frustrating problem can halt your update process and leave you uncertain about what to do next. Online forums and tech blogs are filled with feedback from users seeking solutions to the verifying update issue, highlighting the need for clear and effective troubleshooting steps.
You may also like: How to fix iOS update not showing up
1. Force Restart iPad
If your iPad is stuck on verifying an update, one of the first steps to try is a force restart. This can often resolve the issue by forcibly rebooting the system, which can clear out any temporary software glitches causing the problem.
Steps to Force Restart an iPad:
For iPads with a Home button: Press and hold both the Home button and the top (or side) button until you see the Apple logo. Wait for the iPad to restart in minutes.
For iPad models with Face ID: Quickly press and release the Volume Up button, quickly press and release the Volume Down button, then press and hold the Top button until the device begins to restart.
After restarting, go to settings and check the update verifying status.
2. Use iTunes to Update iPad
For some users, it’s impossible to force restart their iPads because the stuck-on-verifying update issue fails them to do anything. In this case, using iTunes to update iOS can be a choice.
Steps to Update iPad Using iTunes:
  • Connect your iPad to your computer and open iTunes.
  • Select your device when it appears in iTunes.
  • Click ‘Summary’, then click ‘Check for Update’.
  • Click ‘Download and Update’. If asked, enter your iPad passcode.
Also read: How to fix iPad passcode not working
3. Use AnyFix to Update iPad
AnyFix is a dedicated tool designed to solve a variety of iOS system issues, including an iPad stuck on verifying updates. This iOS system repair tool provides a straightforward solution that can address system problems without causing data loss. Besides, AnyFix supports updating to the latest iOS 18 in a few minutes. You can check how to update iPad using AnyFix below:
Steps to Use AnyFix to Update iPad:
Step 1. Download and install AnyFix on your computer.
Step 2. Launch AnyFix and choose the ‘Upgrade/Downgrade iOS’ option. Connect your iPad to the computer using a USB cable.
AnyFix Upgrade/Downgrade iOS Option
Step 3. Follow the on-screen instructions to complete the update process.
It takes a few minutes to finish updating the iPad with AnyFix. No technical skills are required and no data loss.
4. Restore iPad in iTunes
If the update doesn’t work or your iPad is still stuck, restoring the iPad in iTunes is another option. This will erase all data from your device, so ensure you have backed up your iPad before proceeding.
Steps to Restore iPad in iTunes:
  • Select your device and go to the ‘Summary’ tab.
  • Click ‘Restore iPad’ and confirm your choice.
iTunes will download the software for your device and restore it to factory settings.
5. Repair iPadOS to Solve the Verifying Update Issues
The last way you can try to get out of the verifying update is to repair your iPadOS with a third-party program. AnyFix can also repair the iPadOS system itself if updates through iTunes or directly on the iPad don’t resolve the issue.
Steps to Repair iPadOS with AnyFix:
Step 1. Open AnyFix and connect your iPad to your computer.
Step 2. Select the ‘System Repair’ option.
AnyFix System Repair Option
Step 3. Choose ‘Update Issues’ to fix the iPad without risking data loss.
AnyFix System Repair Update Issues
Step 4. Choose Standard Repair and follow the prompts to download the necessary firmware and complete the repair.
After fixing, your iPad will upgrade to the latest version and the verifying update issue will be solved. The standard repair will not cause data loss and you can use it to fix iPad stuck on verifying updates securely.
FAQs About iPad Stuck on Verifying Update
1. Why is my iPad stuck on verifying updates?
Your iPad may be stuck on “Verifying Update” due to various reasons, including software glitches, network issues, insufficient storage space, or corrupted update files.
2. Will my iPad finish updating if I keep waiting?
In some cases, the iPad may eventually finish updating if it’s a minor glitch or server overload. However, if it’s been a significant amount of time, it’s advisable to follow the troubleshooting steps mentioned.
Encountering the issue of an iPad being stuck on “Verifying Update” can be frustrating, but with the right solutions, it’s manageable. By following the steps outlined in this guide, including force restarting the iPad, using iTunes or AnyFix to update, restoring the iPad in iTunes, and repairing the iPadOS, you can resolve the problem effectively. AnyFix is highly recommended to update iPadOS directly or fix iPad stuck on verifying update. It’s powerful and easy to use.
