Are you wondering when the iOS 18 beta will be released? Read this article to find all about iOS 18 and its beta updates. We will discuss its release date, new features, device support, and five easy ways to install it on your phone.
Are you waiting to install the first iOS 18 beta as soon as it’s available? We can relate! Apple’s iOS 18 update is set to be the most significant update to iPhone software ever. It will bring various new features to the iOS ecosystem.
Now the wait is about to end! Apple will finally reveal its groundbreaking iOS 18 update on Monday, June 10. And you probably cannot wait to get your hands on it! This article will explain everything you need to know about the iOS18 beta and how to install it on your iPhone. You’ll find five practical ways to download this latest update and try its all-new features! Are you ready for it? Let’s go!
Wondering when the iOS 18 Beta will come out? What are its features, and if your device is supported? Let’s answer these essential questions before discussing how to install it.
iOS 18 is set for a preview at Apple’s WWDC’24 on June 10. The first developer beta will be released on the same day. However, the public beta may not be available until a month later. The full version of iOS 18 will officially arrive in the fall, right after the iPhone 16 arrives in stores.
When will the iOS 18 beta come out? Here’s a quick timeline for the first beta release and the official launch.
Let’s move ahead now and explore this release’s exciting new features!
Several new features are coming with the new iPhone update. These will also include generative AI capabilities. Here’s a look at some of the most anticipated features.
Siri will be able to respond naturally and conversationally. It can retrieve information from various apps without opening them.
AI features will seamlessly integrate with apps like Notes, Numbers, and Pages. You can also summarize texts and notifications, create AI-generated emojis, and retouch photos with AI.
iOS 18 update will let you move the apps’ icons without following the grid layout. You can put the icons anywhere on the home screen with gaps between them.
Now, let’s see which devices are supported for this brand-new update!
There is no official announcement on which devices are supported. However, a leak has suggested that all the iPhones running iOS 17 are compatible with the iOS 18 beta update. Here’s a list of eligible iPhones based on this:
Supported Devices for iOS 18
Ready to learn how to install iOS18 on your iPhone? Continue below to find out!
There are several ways to download the beta update on your iPhone. You can install it using the iPhone’s settings, Apple Beta Program, configuration profile, and reliable third-party software.
Let’s explore each of these methods with step-by-step guides.
For now, the iOS 18 beta is not available for download. But once it is, you can install it with your iPhone’s Settings. However, you must back up your phone’s data. It may get deleted during the update process. After that, use the steps below to install the new update.
Step 1. Turn on your iPhone and open the Settings app. Select “General” to open the general settings.
Step 2. Tap “Software Update” on the new screen. This will prompt the iPhone to check for the available updates.
Step 3. Go to the “Beta Updates” and select the “Developer Beta” option. Tap “Update Now” or “Download and Install.”
Step 4. Your iPhone will download all the necessary files for the beta update. Wait for the process to complete. Then, tap the “Install” or “Update” button.
Choose Beta Updates
Let’s move forward now and explore the next solution.
If you do not see any beta updates available when trying to update, you can resolve it by joining the Apple Beta Software Program. You don’t need to be a developer to use this method.
Here are the steps to do it.
Step 1. Go to the official site of the Apple Beta Software Program on your iPhone. Tap the “Sign in” option and use your Apple ID or Face ID to sign in.
Step 2. Select the iOS tab and scroll down for the “Enroll your iOS device” option. Click on it and continue.
Step 3. Tap the “Download Profile” option to download the beta profile. Wait for the download to complete.
Tap Download Profile
Step 4. Go to “Settings” on your phone. Tap “Profile Downloaded” and press the “Install” option near the top right. You will need to restart your phone once the installation is complete.
Step 5. Go to the “Settings” app again. Press “General” and go to the “Software Update” section. Tap “Beta Updates” and download the beta version.
That’s all about this method. Let’s move forward to another solution for downloading iOS 18 beta!
Apple Developer Center offers another excellent solution for downloading iOS 18 Beta. While this platform is intended for developers to familiarize themselves with the iDevices ecosystem, anyone can sign up for it.
Here are the steps to use this method.
Step 1. Go to the developer.apple.com website on your iPhone. Tap the two horizontal lines in the top left corner to pull up the side panel.
Step 2. Tap “Account” from the available options and sign in with your Apple ID and password.
Step 3. Tap the “Enroll Now” button if you are a developer and want to join the Developer Program. But you can still access the developer beta if you do not enroll.
Step 4. Exit the screen and go to your iPhone’s “Settings.” Then go to “General > Software Update > Beta Updates.” Developer Beta will now be available.
Sign in to Apple Developer
Simply download and install the beta update on your phone. This method may only work for some iPhone models, but don’t worry – our next solution can help you out.
You can also download the beta configuration profiles directly through the beta profiles websites. This method will require a PC or computer to download and install the profiles on your phone.
Let’s see how to use this method to download the iOS 18 beta update.
Step 1. Go to the IPSW Beta Downloads website on your PC. Click on “iOS” from the top menu bar and select the “iOS 18” option.
Step 2. Scroll down and select your iPhone model. Then click the “Download” button next to the beta version you need to start the download process.
Step 3. Wait for the download to complete, and connect your iPhone to your Mac PC with a USB cable.
Step 4. Open Finder. Select your iPhone from the right panel and click “Check for Update.” Select the IPSW profile you downloaded and install it on your phone.
Click Check for Update
Step 5. For Windows, install the iTunes and connect your iPhone with a USB cable. Open iTunes and click on “Summary” from the right. Then click “Check for Update” and install the IPSW file on your iPhone.
That’s all about how to install the beta version of iOS18 using this method. While this solution may work, online sources are unreliable and not secure. There are risks of corrupted files and malware attacks.
Keep reading to find a more secure solution to install iOS 18 beta in a few clicks!
Are you looking for an easier and safer solution to install iOS18? AnyFix – iOS System Recovery can be your go-to. It is a powerful desktop tool that can install the latest iPhone updates in a few clicks. No lengthy process or complex steps are involved. Using Anyfix to upgrade iOS is quick and easy. And the system installed is official and no data will be erased, ensuring the security and safety.
One important thing to note is that AnyFix does not support iOS 18 at the moment. However, you can use it to upgrade your phone once Apple releases the iOS 18 beta. Let’s see how to use it with the stepwise guide below.
Step 1. Free download and install AnyFix on your computer. Open it and select the Upgrade/Downgrade iOS option from the main screen.
AnyFix Upgrade/Downgrade iOS Option
Step 2. Connect your iOS phone to your PC with a USB cable. Wait for it to get detected. Select the 1 click to upgrade to iOS/iPadOS option and click Start Now.
AnyFix Upgrade iOS
Step 3. A new window will open up on your screen. It will display all the firmware packages higher than your phone’s current version. Click the Download button next to the latest one.
Click the Download Button
Step 4. Wait till the download is complete. Then click Upgrade to update your iOS version. Your phone will restart once the process is complete.
Click Upgrade
Step 5. Your phone will now be upgraded to the latest software. The Upgrade Completed window will allow you to verify the upgrade’s completion.
Upgrade Completed
There you have it! All the best ways to install Apple’s new iOS 18 beta.
However, beta versions are not fully developed and may contain bugs. After the update, you may want to downgrade to iOS 17. Keep reading to find out how to do it.
Apple releases Beta updates to test the software before its public launch. Because of this, it’s not uncommon to experience unexpected crashes after installing beta updates. You may want to switch to your previous software version if you experience hiccups.
No worries, though! AnyFix will make your downgrade to iOS 17 simple and effortless. Here are the easy steps to do it.
Step 1. Open AnyFix on your computer and click the Upgrade/Downgrade iOS option from the main interface.
Step 2. Connect your iOS phone to the PC with a USB cable. Wait till it’s detected. Select the 1 click to downgrade iOS/iPadOS mode from the available options. Click Start Now to begin.
AnyFix Downgrade iOS
Step 3. It will show all the firmware packages lower than your phone’s software version. Click Download next to your desired iOS version.
Step 4. Wait for the download to complete. Then click Downgrade to revert your software version. Your phone will restart once the process is complete.
Click Downgrade
Step 5. AnyFix will downgrade your phone in a few minutes. You can verify the completion of the process with the Downgrade Completed window.
Downgrade Completed Page
And you’re all done switching back to iOS 17! AnyFix makes the process effortless with its seamless solutions for fixing iOS issues.
We have discussed everything you need to know before downloading the iOS 18 beta. You can install the developer beta update from your iPhone’s settings, Apple Beta Program, or Developer Center. You can also use the online IPSW download website for this purpose.
However, nothing is easier and more reliable than using AnyFix. It is the 1-click solution to upgrade and downgrade your iPhone instantly. Try it when you switch to iOS 18 beta, and have fun exploring the brand-new features!
