Weather App Not Working iPhone (Quick Solution)
You are about to go out and want to check the weather conditions for the day, but you find that the weather app on your iPhone does not work. How do I fix the iPhone weather app not working? We’ve provided eight quick fixes in this article, so you don’t suffer from weather app glitches anymore.
Author Avatar Joy Taylor Last Updated: May. 14, 2024
⁤The weekend is here and you plan a leisurely outdoor camping trip with your family. ⁤⁤When you pick up your iPhone to check the weather, you’re faced with a frustrating sight: the weather app isn’t working. ⁤⁤This one is disappointing! ⁤⁤But don’t worry, we have some quick fixes for you that can help you quickly fix weather app not working issue and get your weather app back up and running in no time. ⁤
Why Is the Weather App Not Working on an iPhone?
The Weather app on iPhone provides users with real-time weather information and forecasts. ⁤⁤Weather alerts such as storm warnings, thunderstorm warnings, etc. ⁤⁤can also be sent to users. ⁤⁤This helps users stay informed about potential weather risks and take necessary precautions. ⁤
⁤But if the iPhone weather app does not work, it will bring a lot of inconvenience to the users. ⁤
⁤Here are some possible reasons why the Weather app isn’t working on your iPhone: ⁤
  • Internet problem
  • Location services disabled
  • Application failure
  • Outdated apps or iOS
  • Application data corruption
How to Solve the Weather App Not Working on the iPhone?
When there is a problem with the weather app on your iPhone, you can try the following methods to solve it:
1. Check the network connection
The weather app definitely requires an internet connection to get the latest information. If your iPhone is offline or has an unstable network connection, the Weather app may not work properly. You can check it by following these steps:
Step1. Open the Settings app, tap Wi-Fi or Mobile Data, and make sure your iPhone is connected to an available network.
Step2. If you’re using mobile data, make sure the mobile data option is turned on and that your data plan has enough balance.
2. Restart the application
Occasionally, an application may experience temporary issues or lags, and restarting the application may resolve these issues.
Relaunching an app is not difficult; just use a gesture to open the app switcher. Find the Weather app in the switcher and swipe it up to close the app. Then open the weather app again and see if the problem is resolved.
3. Clear the application cache
An application’s cache may accumulate too much temporary data, causing the application to run slowly or cause problems.
Open the Settings app, go to “General” > “iPhone Storage,” and find and tap the Weather app. On the Weather app page, click “Delete app” to clear the app cache. Then download and install the weather app again.
4. Enable location access
Weather apps often need access to your location in order to provide local weather forecasts. If you accidentally turn off location access, the app may not work properly.
You just need to open the Settings app, go to Privacy > Location Services, make sure Location Services is turned on, and select “Always” or “When Used” under the Weather app.
5. Reset location and privacy
In addition to enabling location access, sometimes location and privacy settings can become corrupted or have issues that prevent apps from properly accessing location information.
Resetting location and privacy settings may resolve these issues:
Step1. Open the Settings app, go to General > Reset, and select Reset Location & Privacy.
Step2. You’ll need to enter your device passcode and confirm the reset. Note that this will clear location and privacy settings for all apps, and you may need to reconfigure permissions for other apps.
6. Update the iOS version
Sometimes, older iOS versions can cause compatibility issues with apps. Updating to the latest iOS version may resolve these issues.
You need to open the Settings app and go to “General” > “Software Update” to see if there is an iOS update available. If an update is available, follow the prompts to update.
7. The Best Way to Fix a Weather App Not Working on an iPhone
By trying the above methods, you may solve the problem of weather apps not working on iPhones. If the problem persists, a more advanced method with a higher success rate is needed. You can use the AnyFix – iOS system repair tool.
Main Features:
  • Fix more than 150 iOS system issues on the iPhone, iPad, iPod touch, and Apple TV without data loss.
  • Remove all bugs that interfere with iPhone operation and cause the iPhone Weather app to not work.
  • The operation is simple, and the success rate is high.
  • There are three repair modes; choose according to your needs.
Step 1. Download AnyFix and run it on your computer > connect your iPhone to the computer > choose the System Repair.
AnyFix System Repair Option
Step 2. Follow the guide on the screen to select the corresponding question. Then click on Start Now button.
AnyFix System Repair App Issues
Step 3. Here will list 3 modes for you to fix the iPhone issue. Click on the Standard Repair which won’t risk any data loss.
AnyFix Standard Repair
Step 4. After clicking the standard repair button, you will see the below interface. Click on the Download button.
Step 5. As the firmware download completes, you will see the below page. Click the Start Standard Repair button.
Step 6. Now, AnyFix will automatically repair your iOS device.
Repair Is Completed
Repair Is Completed
Once completed, the weather application will work normally again. You can now download AnyFix to try to repair your system.
8. Delete and Re-download the Weather App
Sometimes, the weather app itself is the problem. This can help eliminate some of the underlying issues causing the app to malfunction by deleting the app and then re-downloading it from the App Store.
⁤When troubleshooting apps not working on iPhone, this article provides several quick solutions: restart the app, check network connection, update iOS version, reset location and privacy settings, and more. ⁤
However, if you find that these methods are not working or you want to fix the problem faster, you can try AnyFix. ⁤⁤AnyFix is a powerful iOS system repair tool that can help you quickly solve problems on various iOS devices, including non-functioning weather apps. ⁤⁤Try AnyFix today and enjoy fast, easy and effective solutions to keep your iPhone looking its best. ⁤
