Restoring iPhone with iTunes should take more than hours since verifying iPhone restore is stuck. Read this post and get the proven methods to get iPhone to finish restoring.
Free download PhoneRescue for iOS to 1-click fix over 130 iOS system errors, including iTunes stuck on verifying iPhone restore.
My iPhone 7 plus is stuck in recovery mode and when I try to restore using iTunes it got stuck in verifying iPhone restore with apple. My phone screen displayed Apple logo with a progress bar that does not even start progressing. I waited for over one day but no progress. Can anyone help, please??
Restoring iPhone with iTunes will create an automatic backup on your Mac or PC which enables you to access songs, photos, or videos you had stored on your iPhone. However, your device can get stuck on the verifying iPhone restore step as the above user said, while you are updating iOS or restoring it back to factory settings using iTunes.
In some cases, your iPhone may just be slow, but if the progress bar doesn’t move for more than fifteen minutes it is a sure sign that something is wrong with the software. So in this article, we are going to show you how to fix iTunes stuck on verifying iPhone restore the problem and offer several different solutions to this issue.
Usually, it should take more than a few minutes for iTunes to verify iPhone restore, although the exact amount of time you will have to wait for your device to be verified depends on the size of the update.
Hence, this step can be completed in just a few seconds or up to ten minutes if the size of the update is larger than a gigabyte. In case, your iPhone is stuck on this step for more than ten minutes chances are that you are dealing with malfunctioning software or hardware.
iTunes Stuck on Verifying iPhone Restore
Also Read: Fix iTunes Not Recognizing iPhone in Recovery Mode >
You can try an iTunes alternative to update and restore your iPhone. This software is called PhoneRescue for iOS, which is designed to help iPhone/iPad/iPod users out of iOS/iPadOS dilemma. If you are stuck on verifying iPhone restore, just download PhoneRescue for iOS to repair the issue:
Next, you only need to complete a few simple steps.
Step 1. Get PhoneRescue for iOS on your computer. Open it. Click Repair iOS System under Device Rescuer.
Choose the Repair iOS System Mode
Step 2. Here are two repair modes that you can choose. Advanced enables you to restore your iPhone without data loss. If you also want to reset your iPhone to factory settings, you can choose Standard Mode.
Select the Advanced Mode to Fix Your Bricked iPhone/iPad
Step 3. Follow the on-screen instructions to enter recovery mode > Click Download button to get a matching firmware package.
Click Download to Get Firmware
Step 4. After that, PhoneRescue for iOS will start restoring the device for you. Minutes later, you’ll see iOS repairing completed page.
iOS Repairing Completed
We give you 6 feasible solutions to help you fix the iTunes stuck on verifying iPhone restore problem. Among them, AnyFix could fix this problem with simple clicks. You may give it a try.
The USB cable you used to connect your device to a computer may not be correctly positioned. The iPhone may have gone offline during the process or the issue can be caused by iTunes.
So, before attempting to update or restore an iPhone using iTunes, you must make sure that both devices are connected to a WiFi network and that the connection between the two devices is established.
If you checked the connection and everything was alright, then it may be a system error. If so, you can try installing a third-party app like AnyFix – iOS system recovery that is compatible with both Mac and PCs. This system repair software can help you resolve the iTunes stuck on verifying iPhone restore issue if the problem was caused by iTunes.
Here’s what you need to do:
Step 1. Select the Repair iTunes option once you’ve downloaded and installed AnyFix. Then launched the AnyFix app.
Click iTunes Repair
Step 2. Select the iTunes Connection/Backup/Restore Errors option and click on the Scan Now button. AnyFix will commence the analysis of the components.
Choose iTunes Connection/Backup/Restore Errors
Step 3. After the software completes the analysis it will display a list of components on the screen that may potentially be the reason why iTunes gets stuck while verifying iPhone restore. Click on the Fix Now button.
iTunes Component Errors will be Detected
Step 4. Once the repairing process is completed, you should click on the Open iTunes button in order to check.
iTunes Repair Completed
In addition, you should also disable the antivirus and ensure that you have the latest version of iTunes.
Optionally, you can try to restore your iPhone from another computer, especially if you are attempting to restore an iPhone with iTunes from a PC.
In case the issue still persists, you should delete the iOS update from iTunes and clear the cache. You can do so in simple steps:
When done you should restart your computer, launch iTunes again and then access your iPhone’s DFU mode. Differing from recovery mode, DFU mode restores your iPhone to its original factory settings but with the latest iOS and firmware. But keep in mind that the actual steps you need to take to access the DFU mode depend on the model of iPhone you have. Here’s how you can do this:
Proceed to choose the restore option in the recovery mode and then update your iPhone. Once the update is completed you should hard reset the iPhone in order to exit the DFU mode.
The iTunes stuck on verifying iPhone restore issue suggests that there is something wrong with iTunes or your iPhone. If in case the malfunctioning hardware is the root of the problem you will have to take your device to an authorized Apple repair center. But in most cases, PhoneRescue for iOS can solve your problem easily. Download PhoneRescue for iOS to repair the system now!
