This article provides solutions for the “shortcuts not working iPhone” issue in iOS 17. It outlines seven easy steps, from restarting your iPhone to contacting Apple Support. These methods are designed to get your shortcuts working smoothly!
Are you struggling with the “shortcuts not working iPhone” issue on iOS 17? Consider trying to automate your morning routine with a shortcut, but it fails to launch. Or imagine setting up a shortcut to get directions quickly, but it just won’t activate. These problems can be frustrating for any iPhone user.
In this guide, we will cover several practical fixes to address these issues. Whether you’re an experienced iPhone user or new to iOS, these steps are easy to follow. Let’s fix this issue to ensure your daily tasks remain effortless and efficient.
Shortcuts on the iPhone are a feature that lets users automate tasks. With it, you can create custom actions using various apps and services. For example, you can set a shortcut to send a message, play music, or open a map route with just a tap or voice command. It’s like having a personal assistant on your phone.
You can find ready-made shortcuts in the app or make your own. This tool helps save time and streamline everyday activities. It’s especially useful for repetitive tasks. With shortcuts, you can simplify complex sequences into easy, quick actions. This feature enhances iPhone usability. So making it more efficient and customized to your needs.
Until now, you know what shortcuts are on iPhone. Now, let’s understand why shortcuts not working iPhone.
iOS 17 brings small updates, including changes to current features for today’s users. No software is perfect, and this is true for all big companies. Several reasons might explain why iPhone shortcuts don’t work. Here’s a list of possible causes.
Now that you know the possible causes of why “iPhone shortcuts not working.” Next, let’s see how to fix this issue.
It is a very frustrating experience when the shortcuts on your iPhone don’t work. Let’s discuss seven practical fixes for resolving this issue on your iPhone.
If iPhone shortcuts not working, first try restarting the app. Close it and reopen it. This can fix minor glitches. If that doesn’t work, a restart of your iPhone might help. It clears temporary issues that might be affecting the app. Restarting the app and phone is a quick and easy first step in troubleshooting.
Force Restart iPhone
To reboot an iPhone 8 or later:
For iPhone 7:
For iPhone 6:
After restraining your iPhone, restart the shortcuts app. If doing so doesn’t resolve the issue, move to the next fix!
In some cases, the issue might be with a specific shortcut rather than the app or the operating system. If this is the case, the solution is to delete the problematic shortcut and create a new one. Here’s how to do it:
Step 1. Open the Shortcuts app.
Step 2. Tap ”Select” in the top right corner, near the plus (+) icon.
Step 3. Choose the shortcuts you wish to remove.
Step 4. Tap ‘Delete’ to remove them.
Delete the Shortcuts
Step 5. To make a new shortcut, tap the plus (+) icon at the top right and follow the steps.
Now, let’s go to the next fix for shortcuts not working iPhone. This will help your shortcuts work better on your iPhone. Let’s see what it is.
If your Shortcuts aren’t working, try re-enabling Automation. And you can follow the steps below.
Re-enable the Automation
This simple step can fix issues. It refreshes the settings and often gets things working again.
After trying to re-enable automation, let’s explore another solution to address the issue of “iPhone shortcuts not working.” This next step could be the key to resolving any remaining problems.
To fix the “shortcuts not working iPhone” issue without losing data, you can use a smart tool: AnyFix – iOS System Recovery. This software helps with various iOS system issues. It’s great for common problems, like an iPhone shortcut not working, stuck on Apple logo, stuck on recovery mode, won’t turn on, frozen screen, etc. It’s easy to use and works fast, ideal for non-tech users. A big plus is it fixes problems without losing data. This is important for those who don’t back up their phone often. And it also offers 3 repair modes to meet different needs. AnyFix supports all iPhone models and iOS versions, making it versatile.
Here’s how to use AnyFix to fix shortcuts not working iPhone.
Step 1. Firstly, free download and install AnyFix on your computer. Then, choose the System Repair Mode.
AnyFix System Repair Option
Step 2. You will see the below interface as your device is detected. Now select the Start Now Button.
AnyFix System Repair Device Bug
Step 3. You can select a mode to repair your iOS device. Now select the Standard Repair option first to avoid data loss.
AnyFix Standard Repair
Step 4. After clicking the standard repair button, you will see the below interface. Click on the Download button.
Step 5. As the firmware download completes, you will see the below page. Click the Start Standard Repair button.
Step 6. Now, AnyFix will automatically repair your iOS device.
Repair Is Completed
This is all about how to use Anyfix to fix system issues. If you are not satisfied with this method, you can try the next one!
To fix issues with shortcuts, clear clutter from your iPhone. To do this:
Select iPhone Storage
If your iPhone’s storage is nearly full, use more tips to free up memory. This can help shortcuts work better. If this method doesn’t work for you, try the next one!
If Shortcuts still isn’t working, try resetting all settings on your iPhone. This won’t delete your data, but it resets system settings to default. Here are the steps.
Select Reset All Settings
This resets network, privacy, and location settings, among others. It can often fix issues with apps like shortcuts. You’ll have to set up some settings again after this reset.
However, if you don’t want to reset all settings, you can try the next fix on ”shortcuts not working iPhone.”
If other solutions fail, reach out to Apple Support. They’re skilled in handling iPhone issues. You can call them, chat online, or go to an Apple Store. Their team can give specialized help. They can solve complex problems that other steps can’t. This should be your go-to for stubborn issues with Shortcuts.
This is the last solution that you can try to fix this issue! Hopefully, trying the above fixes will help you to get rid of the issue!
Q1. Do shortcuts work when iPhone is locked?
Shortcuts don’t work when your iPhone is locked. This keeps your phone secure. To use a shortcut, you need to unlock your iPhone first. This is to make sure only you or someone else can use the shortcuts. While most shortcuts won’t run with the iPhone locked, Siri can enable some of them. So, if a shortcut is set up with Siri, you can use it even when your phone is locked. This is useful for quick tasks without needing to unlock your phone.
Q2. What is the shortcut to restart an iPhone?
There’s no shortcut in the Shortcuts app to restart an iPhone. You need to use the phone’s buttons to do this. New updates might change this, so it’s good to keep checking. For the latest info, look at Apple’s website or tech news.
In a nutshell, resolving the “Shortcuts not working iPhone” issue in iOS 17 is easy with these seven steps. Each method is clear-cut and might be the solution you need. And we highly recommend you try AnyFix for free first due to its convenience and high success rate. Just fix Shortcuts not working iPhone now! And make the most of your iPhone’s shortcuts to simplify your daily routines.
