What to do when you encounter shared with you not showing issue? Don’t worry, this article offers 6 ways to solve shared with you not showing problem, including one with a 98% solution rate. Not only that, but this guide also answers some of the questions users have about the share with you feature.
In iOS 15 and iPadOS 15, Apple launched a new feature that has made sharing music, TV shows, website URLs, pictures, and videos more convenient.
Over the years, Apple has worked on ways to facilitate connectivity among its users. When you update your iOS/iPadOS version, you will find already shared data in the Shared with You section of all the iOS applications. But sometimes, you may not find the Shared with You feature.
To help you out with that, we’ve listed some solutions. Proceed with these solutions as per the steps given.
News app, Photos app, Apple TV app, Safari app, and Podcast app have a Shared with You tab where you can find content that has been shared with you, even by people using older versions. Moreover, you can reply via messaging by tapping on the names below.
The Shared with You feature puts shared music in the Music app, shared media in the Photos app, shared URLs in the Safari app, shared schedules in the Calendar app, shared podcasts in the Podcast app, and so on.
In the next section, we will see the solutions that you can use to troubleshoot Shared with You not showing.
There are several ways to solve ‘Shared with You’ not showing. Here are some of them, let’s get started.
Although we will present a total of six approaches in this section, if you want to solve problems quickly and with a high success rate, PhoneRescue for iOS is exactly what you need, which is powerful to bring your iPhone back to life. The following are its specific features.
Now download PhoneRescue on your computer and follow the instructions below to fix iPhone stuck on Apple logo!
Step 1. Launch PhoneRescue and connect your iPhone and computer. Select Repair iOS System in the Device Rescuer list.
Choose the Repair iOS System Mode
Step 2. To keep the data intact, please select Advanced Mode.
Select the Advanced Mode
Step 3. Follow the on-screen instructions to put your iPhone into recovery mode and download the firmware. After that, PhoneRescue will start to repair iOS system problems. Minutes later, you’ll see iOS repairing completed page.
iOS Repairing Completed
To see if the Shared with you feature is turned on, follow these steps,
Check if Shared with You is Turned On
You may face this problem for some contacts and not all of them. This might be because the Shared with You option is turned off for certain contacts. You may not find the content of certain contacts. To enable any hidden contact, follow these steps
Turn on Shared with You for Certain Contacts.
To restart the device, do the following steps.
Restart Different Modes of iPhone
To sign out of iCloud on your device, follow these steps:
Sign Out Old iCloud Account
To sign in to iCloud:
The Shared with You only comes in iOS 15/iPadOS 15 and above. It is not available for older versions. You must update your phone to use it. To update your phone, follow these steps
Check Software Update
Here are some of the frequently asked questions that users often ask.
To find Shared with You on your iPhone, follow these steps.
You will see Shared with You. By tapping on it, you can further select the applications you want to allow.
To hide the data of some applications, follow these steps.
To stop data of conversation with someone to sync with Shared with You, follow these steps.
You may have to hide any app or conversation with some people. To unhide these files and media, follow these steps
For applications:
Apple has come up with the integration of iOS apps with this feature. Those applications include
The shared with you function is a feature that makes life on iOS even easier. As such, it can be a headache to have problems with shared with you not showing. Fortunately, this article not only has an easy way to do this, but also has a tool like PhoneRescue that can solve the problem on 130+ iOS devices
