“Screen Time option in settings is currently not working, clicking on it does nothing. Restarting/ Resetting settings doesn’t solve this. I had an app limit on a number of social media apps like IG, to improve productivity. Ignore for a day option not working, so I guess I’m involuntarily getting social media detox I need.” An iPhone user posted on Reddit after iOS 18 beta update.
The release of the iOS 18 beta brought a slew of exciting new features and improvements to Apple’s mobile operating system. However, as with any beta software, it also introduced a few bugs and issues. One notable problem many users have encountered is the Screen Time limits not working as expected. This feature, designed to help manage and limit device usage, is crucial for many users, especially parents looking to regulate their children’s screen time. In this article, we’ll delve into the causes of this issue and provide detailed instructions on how to fix Screen Time limits not working on iOS 18 beta.
Several factors could be causing Screen Time limits to malfunction on the iOS 18 beta. Understanding these potential causes is the first step in troubleshooting the issue.
Beta Software Bugs: Since iOS 18 is still in the beta phase, it is prone to bugs and glitches that can affect the functionality of various features, including Screen Time.
Improper Settings Configuration: Sometimes, the Screen Time settings might not be configured correctly after the update, leading to issues.
Software Conflicts: New features or changes in the iOS 18 beta might conflict with existing settings or third-party apps, causing Screen Time to behave unexpectedly.
Incomplete Installation: If the iOS 18 beta update was not installed properly, it could lead to various system issues, including problems with Screen Time.
Also Read: How to delete screen time history on iPhone
One of the simplest and most effective ways to resolve Screen Time issues is to disable and then re-enable the feature.
If re-enabling Screen Time doesn’t solve the problem, try setting limits for specific apps.
Set Screen Time Limits for Apps
Ensuring that your Screen Time settings are protected by a passcode can sometimes resolve functionality issues.
Performing a hard reset can help resolve temporary glitches and bugs.
If none of the above methods solve the screen time limits not working in iOS 18, you can try an iOS system repair tool. AnyFix is powerful in repairing iOS system issues, including some beta issues. It has fixed several beta problems in the previous beta versions, such as iOS 17 beta update failure, iPhone stuck on Apple logo in iOS 17 beta. To solve the screen time limits not working on iOS 18 beta, you can follow the steps:
Step 1. Download and install AnyFix on your computer.
Step 2. Launch AnyFix and select System Repair. Use a USB cable to connect your iPhone to the computer.
AnyFix System Repair Option
Step 3. Select App Issues and click Start Now.
AnyFix System Repair App Issues
Step 4. Choose Standard Repair mode to fix this issue. It will not cause data loss.
AnyFix Standard Repair
Then follow the instructions to finish system repair with AnyFix.
Repair Is Completed
For some iPhone users who may forget their Screen Time passcodes, here is a tip to remove screen time passcodes without data loss. Using AnyUnlock is the quickest way to remove the screen time passcode if you have forgotten it. Here are the guides:
Download AnyUnlock and install it on your computer.
Launch AnyUnlock and choose Unlock Screen Time Passcode. Use a USB cable to connect your iPhone to the computer.
Choose Unlock Screen Time Passcode Mode
Follow the guides to finish removing the screen time passcode on your iPhone.
Screen Time is a valuable feature for managing device usage, but it can be frustrating when it doesn’t work as expected, especially after updating to iOS 18 beta. By following the methods outlined in this article, you can troubleshoot and fix the issue effectively. Whether it’s re-enabling Screen Time limits, setting specific app limits, using a passcode, performing a hard reset, or utilizing the AnyFix iOS system repair tool, there are several ways to resolve the problem and ensure your Screen Time limits are functioning correctly.
