If you encounter last line no longer available issue, then what does last line no longer available mean and how to fix it? No worries, we provide 13 tricks to fix this problem.
Does your iDevice frequently pop up “last line no longer available” error message each time you try to host a call? If so, you don’t have to worry as there are others that are faced with the same issue.
What does the error message mean, why is it popping up, plus how do you fix it are the questions this article is structured to answer. Without further ado, let’s get started.
The last line no longer available error message isn’t as complicated issue as you may have thought. If you are familiar with iOS dual SIM-supported devices, you must have noticed a prompt requesting which SIM you wish to use for iMessage, FaceTime, and phone call. The device acts according to your selection.
Should in case your device can’t recognize the selected network, you will get the “Last Line No Longer Available” error message. And you will be forced to host a call using the other line you have on the device.
What Does Last Line No Longer Available Mean
“Last Line No Longer Available” occurs on selected iOS devices, mainly those with dual SIM functionality. Some of the devices include; iPhone 11, 12, 13, and 14 series. It’s not common with iPhone SE, both first and second generations.
Last Line No Longer Available error message occurs for several reasons. Some of them are listed below:
Fixing this is absolutely easy when you have our guide at hand. The next section of this article will focus on possible ways to fix “last line no longer available” error message.
Wipe the “last line no longer available” error message popping up on your iDevice today using any of the 13 solutions provided below.
With an iOS system repair tool like PhoneRescue, you can fix your device and improve its functionality conveniently from the comfort of your home. The software fixes over 100 iOS-related issues ranging from iPhone/iPad broken screen, white lines, frozen screen, unresponsive keys and more.
Also, it works perfectly for the “last line no longer available” error message you encounter on your iDevice. The software fixes this error within the shortest possible time using the latest firmware package. It works without compromising your data, or the device performance.
Get rid of “last line no longer available” error message with PhoneRescue following the instructions below:
Step 1. Get PhoneRescue for iOS installed on your Mac/Windows PC. Choose Repair iOS System.
Choose the Repair iOS System Mode
Step 2. You can choose Advanced Mode (no data loss) or Standard Mode. After repairing, your iPhone will be restart normally.
Select the Advanced Mode
Step 3. Enter your iPhone to recovery mode.
Put Your iOS Device into Recovery Mode
Step 4. Get matching firmware for your iPhone. After downloading, PhoneRescue will start repairing immediately.
Download Matching Firmware
Step 5. The repairing process is completed.
iOS Repairing Completed
Activating and deactivating Airplane Mode is a popular troubleshooting technique often used to fix network error. And since network error is one of the primary causes of “last line no longer available” error message, turning Airplane on/off should fix it.
This solution is easy to implement. Follow the guide below to do that:
If your iDevice has a home button, kindly swipe up from the bottom of your screen to launch the control center.
Turn the Airplane Mode On/Off
Force restarting your iDevice is another wonderful solution to fix the “last line no longer available” error on your phone. The solution refreshes your device by flushing out those cache and unwanted temporary files causing it to misbehave.
Apply the following instructions to force restart your iPhone:
Force Restart Methods of Different Models iPhone
Since your iDevice is dual SIM compatible, we advise that you change your default calling line to the second line. This way you can reach out to whoever you want to without the “last line no longer available” error message popping up.
Here’s how to switch your default calling line:
Here is another effective troubleshooting solution to fix “last line no longer available” issues on your iDevice. Sometimes your carrier settings may be outdated and require updating.
When you update your carrier settings you can easily boost your network performance, thereby fixing the error message. Follow the procedure below to update your carrier settings:
Check Carrier Settings Update
Improper placement of SIM cards often result in “last line no longer available” issues on iOS devices. You can fix this by taking off the SIM from your device and reinserting it. Although traditional, this solution is one of the most effective solutions available for fixing cellular network issues on a mobile device.
To implement this solution, you have to turn off your iDevice first. Once done, follow the directions below:
Dialling calls from recent call logs often show “last line no longer available” error message. The reason for this is unknown but experts belief clearing the recent call logs on your iDevice is a potent solution to fix it.
You can clear your recent call logs following the instructions provided down here:
Clear Recent Call History
Should the problem persist after employing the solution above, consider turning off the Find Contacts feature on your iDevice. Turn off the Find Contact feature. But this feature may not be available on the latest version of iOS.
Turn Off Find Contacts on iPhone
Fix 9. Turn Off WiFi Calling
WiFi Calling is an advanced feature that lets you engage in a phone conversation with your contact via WiFi instead of cellular data. If you’ve enabled this feature in the past, your device may display “last line no longer available” error message.
Should this be the case, we recommend you to turn off WiFi calling. Doing this is super easy. Follow the directions provided below:
Older iOS versions often show Cellular Data instead of Mobile Data. Both options are similar.
The network selection settings have a significant effect on your carrier’s functionality. You have both manual and automatic network selection settings. When you select the former, your device connects using any available radio signal, whether strong or not.
However, when you choose the latter, your device connects to the best radio signal which, in most cases, is hard to find. While your device is struggling to connect with the best radio signal, you may experience “last line no longer available” error when you host a call.
Adjusting these settings can help fix the error message. Here is the procedure to disable automatic network selection:
How to Disable Automatic Network Selection
Wrong network configuration settings also affect your carrier’s connection. But you can fix it by resetting your network settings. Follow these instructions to reset the network settings on your iDevice:
iPhone Reset Network Settings
No doubt, you’ve changed the default settings on your device in the past. And when that happens, the device may malfunction causing the error message “last line no longer available” to pop up.
Resetting all settings is the perfect solution to fix this issue. Follow the stepwise instructions provided down below:
Click on Reset All Settings
What OS is your iDevice running on? If you have your device operating on the latest OS version, there’s a possibility you may encounter “last line no longer available”.
An update in the OS can fix this issue within the snap of a finger. Here’s the guide to do that:
Check Software Update
The red you go with the detailed instructions on how to fix “last line no longer available” error message on your iDevice. All solutions are cost-free, easy to implement, and highly effective. Our best solution is PhoneRescue for iOS. The software uses AI to fix “last line no longer available” error at a remarkably high speed without you stressing yourself.
