iTunes will not recognize your iPhone for many reasons. If you are fed up with this problem, you might want to learn how you can fix it. This guide gives you some feasible methods to do so.
Free download AnyFix to 1-click fix the iTunes Won’t Recognize iPhone problem.
If you are having problems getting iTunes to recognize your iPhone, you are not alone. Thousands of users face this issue occasionally and it is pretty common. There are various reasons why the iTunes app on your computer will not detect your iPhone. There may be an issue with your iTunes, computer, iPhone, or the connection method.
Fortunately, there are several methods that you can try and hopefully fix the issue on your devices. The fixes that you will find here are both basic and advanced. First, you may want to apply all the basic fixes and see if that helps resolve your problem. If that does not work, go ahead and apply the advanced fixes and that should most likely resolve the issue for you. Check out the available solutions below.
Also Read: How to Unlock a Disabled iPhone and Won’t Connect to iTunes >
From the moment you turn on your iPhone and computer to finally when you turn them after finishing your work, millions of processes run and get executed on your devices. Sometimes, some of these processes negatively affect your device and that results in issues like the one you are currently experiencing. The good thing is that these minor issues can actually be easily fixed. All you basically need to do is restart your computer and iPhone and that should resolve most issues for you.
One of the reasons why iTunes will not recognize your iPhone is that there is an issue with your connection method. You need to make sure all the equipment that you use to establish the connection is working.
iTunes can sometimes be extremely difficult to fix. If the errors are caused by something serious in the app, then fixing it manually is going to take forever. Luckily, you do not need to do that as there are a few apps you can use to fix iTunes and the errors related to it with some basic steps.
AnyFix – iOS system recovery tool is an application that allows you to fix hundreds of issues associated with iTunes on your computer. You can use it to fix problems like iTunes Won’t Recognize iPhone, iPhone won’t update on iTunes, iPhone not showing up in iTunes, Cannot connect to iTunes Store, etc. Have a look at AnyFix’s main features below.
The following is how you use this app to fix iTunes not recognizing your iPhone.
Step 1. Download AnyFix on your computer, launch it, and click on iTunes Repair on the main app interface.
Repair iTunes with AnyFix
Step 2. On the following screen, select iTunes Connection/Backup/Restore Errors, and hit Scan Now.
Select the Error Type to Fix
Step 3. Wait for the app to analyze the errors. Then, click on Fix Now to start fixing those errors.
Resolve iTunes Errors
If iTunes is still having trouble recognizing your iPhone, there may be an issue with the iTunes app on your computer. One way to fix iTunes issues is to remove the entire iTunes app from your computer and then reinstall it. This should not take too long and you can fix many issues with this method.
The following shows how you can perform this method on your computer.
Uninstall Apps on Windows PC
The purpose of a security software tool on your computer is to keep your machine secure from any viruses and threats. Unfortunately, some of the antivirus software are not good at differentiating between good and bad files. As a result, they end up detecting good apps like iTunes as bad apps and cause interference with their workings.
This may have happened on your computer and that is why iTunes fails to recognize your iPhone. To fix this issue, all you need to do is disable your security software when you use iTunes on your computer. Since the software will remain disabled, it will not get into the way of iTunes and iTunes will be able to do what it needs to do to detect your iPhone
With most antivirus software, all you need to do is open the software and click on the Turn Off, Disable, or a similar option to turn them off.
If you use iTunes on a Windows computer, there are a few things you can do to possibly get rid of iTunes issues from your machine.
When you connect your iPhone to your computer, make sure you tap on the Trust option on your device. This way, your iPhone can exchange data with your computer using iTunes.
Make sure you are using the latest version of iTunes on your computer. If you are not sure, open the Apple Software Update utility and use it to check for iTunes updates.
Update iTunes on PC
You must have Apple Mobile Device Support installed on your PC. This gets installed when you install iTunes.
To check if it exists, head to Control Panel > Uninstall a program and find the utility in the list. If it is not there, you will need to reinstall iTunes to get that utility.
It is very rare for users to face issues with iTunes on a Mac. However, if you are one of those users facing issues, there are some easy ways to fix those issues.
You need to ensure that you are running the latest version of macOS on your Mac. You can check and update macOS as follows.
Click on the Apple logo, select About This Mac, and click on Software Update. It will check and let you download new updates for your Mac.
Update Mac
If you have plugged-in other USB devices to your Mac, disconnect them while using your iPhone. This will fix any other devices causing issues with your iPhone.
Many users find that iTunes is not recognizing my iPhone and there are several reasons why. If you cannot fix the issue on your own, the above guide will help you get the issue resolved using various methods. It shows methods for multiple platforms so you are covered no matter the platform. We suggest you download AnyFix and fix the iTunes system now!
