In this article, you’ll know the answer to why your iPhone stuck on Apple logo due to full storage and 4 ways to fix it. Moreover, you can also know 5 tricks to prevent iPhone storage full issues.
Are you struggling to boot your iPhone past the Apple logo screen because of the low memory storage? You aren’t alone as there are other iOS users who also complain about iPhones stuck on the logo screen due to full storage space. So you need not worry.
While the issue can be frustrating, you can fix it yourself within the twinkle of an eye at a zero-cost fee. Our team has curated a tutorial guide that explains how to fix iPhone stuck on the Apple logo storage full issues. Without wasting your time, let’s delve into the guide!
iOS devices are designed with no extra memory slot where you can add an SD Card. Instead, they come with large memory storage ranging from 64 GB to 256 GB. With that in mind, all data and files will be stored internally on the device. And since the memory space is finite, you can exhaust it with time.
When your iDevice memory gets filled, the operation slows down, and it starts misbehaving. You may experience issues like iPhone stuck on the Apple logo. Another reason you may encounter such an issue is when you run your device on an outdated iOS. Other reasons could be hardware-related such as broken or damaged screens.
Regardless of the reason, you can resolve the issue by implementing the solutions provided in the next section of this article.
Fix your iPhone stuck on the Apple logo screen due to full storage with the solutions below:
Hard resetting your iPhone is a great way to fix iPhone stuck on Apple logo screen issues when your storage system is full. The solution wipes nearly all the third-party apps and data from the device, leaving it just as if it were newly purchased.
This solution surely fixes your device. However, you cannot help but lose important data files and apps. Hard resetting your iDevice is simple. Check out the instructions for all iOS modes:
iPhone 8 and later generations
iPhone 7/7 Plus
Simultaneously press and hold down the following buttons
Keep holding both keys for approximately 10 seconds till your screen goes blank and the Apple logo comes up.
iPhone 6 and earlier generations
How to Hard Reset iPhone
An iOS System repair tool like PhoneRescue is one of the best options you have to fix your iPhone when it’s stuck on the Apple logo screen due to full storage. The software boasts of fixing over 50 iOS system issues without crashing or complicating your current data files.
With the software, you can repair Apple logo screens, broken screens, screen glitches, and more. You can also use it for iOS data recovery. PhoneRescue retrieves more than 20+ data files with high quality. It scans and retrieves multiple deleted files at a remarkably high speed.
Key Features
Step 1: Download PhoneRescue and launch the software and connect your iPhone to the PC using a USB charging cable. Click on Device Rescuer, and select Repair iOS System underneath.
Choose Repair iOS System
Step 2: The next screen requires you to select your preferred repair mode. You’ve got two options. Kindly choose Advanced Mode because it won’t erase any data on your device.
Choose Advanced Mode
Step 3: Follow the on-screen prompts to enter recovery mode for your iOS model. Once done, PhoneRescue will begin to repair your device. Minutes later, you’ll see iOS repairing completed page.
iOS Repairing Completed
Via iTunes/Finder, you can repair an iPhone stuck on the Apple logo screen due to full storage. This software program helps you update or restore your iPhone to eliminate software bugs and enhance its functionality. iTunes and Finder work with Windows and Mac computers, respectively. So if you have any of these devices, we implore you to install the latest versions of iTunes or Finder and follow the instructions below:
Restore iPhone to Factory Settings
Also known as Device Firmware Update, DFU is an advanced restoration method designed specifically for fixing iOS-related issues. It’s mostly used when the situation with an iPhone doesn’t yield positive results when subjected to normal resetting.
DFU Mode is simple to enter, and it works with all iPhone generations. Follow the steps below to restore your iOS device with DFU mode:
iPhone 8/X and newer generations
iPhone 7/7 Plus
iPhone 6 and older versions
Put Different iPhone Model into DFU Mode
Prevent your iDevice from storage full issues today following the tips below:
Clearing cache is crucial to the performance of a device, including iPhones. When you clear the cache on your device, you get some extra storage space on it, and that will improve the operations. Here is a simple way to clear caches on your iDevice:
Updating your iOS version improves its functionality by clearing temporal glitches and bugs. This approach helps maintain data storage and prevents it from getting full. You can follow the detailed procedure below to update your iOS version:
Do you have unused apps on your iDevice? If so, we advise that you uninstall them to free up the device’s memory space. To do that, hold down the app tills everything on your screen starts to wiggle. Once done, click on the – sign next to the app, and the screen below will pop up:
Jailbreaking exposes your device to malware and viruses. Though it gives you control over the device, we do not recommend you subject your iPhone to jailbreaking because of the consequences.
Got some unnecessary backup files on your iDevice? Such files are consuming spaces which can lead to your iPhone being stuck on the Apple logo screen due to full storage. Kindly look for these backup files and erase them from your system.
Getting stuck on the Apple logo screen due to full storage is a solvable issue now that you have our tutorial guide at your disposal. Apply the solutions and safety precautions introduced in the guide today.
Our recommended solution from the list involves the use of an iOS system recovery tool. PhoneRescue revives your malfunctioning device and fixes all issues you may encounter on it. It’s also a good iOS data recovery option. You should try it out now!
