“Checking with apple support I have tried to activate my ‘dead’ phone (volume up then volume down and then press right button until logo appears – that doesn’t work. Also put the phone on charge for over an hour, nothing) the iPhone had about 50% charge when it suddenly died. Any advice please? (the iPhone is 9 months old)”, a user asked on Apple Community.
iPhone SE won’t turn on? That can be frustrating for any iPhone SE user. This problem has triggered numerous discussions on the Internet, where users are exploring helpful instructions to fix this annoying issue. Luckily, there is always a way. This guide will provide you with several potential causes and fixes for this issue.
You may also like: How to factory reset iPhone SE without passcode
If the iPhone SE doesn’t turn on, usually there is something wrong with your battery or charging equipment. So first ensure your battery is not dead or faulty and your charging devices are in good condition.
Except for the battery drain and charging equipment issues, there are several other potential causes. Software bugs and glitches, hardware damage, and an overheating environment all are to blame for iPhone SE won’t turn on.
If you have tried many ways but your iPhone SE still won’t turn on, you can check and try the following ways to get it awake.
Having identified the potential reasons why iPhone SE doesn’t turn on, you can apply some practical ways to resolve this annoying issue. Let’s follow this detailed guide to try to make it.
The most common reason why iPhone SE doesn’t turn on is the low battery or battery damage. So the first step is to charge your iPhone SE to see if it works. If there is no response when you have charged it, then the charging equipment may be damaged. You need to replace a new or other compatible charging device to charge your iPhone SE. Then wait for the Apple logo and the power bar to appear.
If the battery works well, it may be a software issue. Recovery mode is a tool inset in the iPhone that allows users to recover some problems that can’t be resolved in other ways. So if all those ways mentioned before don’t work, you can try to enter recovery mode to fix the iPhone SE not turning on. Follow the steps below to have a try:
Put iPhone SE into Recovery Mode
Then your iPhone SE will be diagnosed and recovered automatically. But if this can’t help, try DFU mode.
Also read: How to fix iPhone won’t go into recovery mode
DFU mode is a deeper restore mode than recovery mode, which can fix more advanced issues. So if the recovery mode doesn’t work, you can try to use the DFU mode to recover or restore your device’s software and firmware. Follow the steps below to have a try:
Put iPhone into DFU Mode
Following these steps, you can enter DFU mode to resolve this issue. If your iPhone SE still won’t turn on, force reset your iPhone SE.
Performing a hard reset on your iPhone SE can resolve the software glitches and bugs in your iOS system. However, you are at risk of losing all your data. So remember to transfer and store your data before you hard reset your iPhone SE. Follow the steps below to have a try:
Hard Reset iPhone SE
Following these steps, you can easily reset your iPhone SE to factory default. However, if you want a way not to lose data or this way doesn’t work, then keep reading.
iPhone SE still won’t turn on? Can’t bother to recover your data before restoring your iPhone SE? You may think there is no perfect way for you to fix this issue.
But don’t lose heart, a specialized iOS system repair tool can help you. AnyFix is an advanced system repair tool that removes all the issues with your iOS system, such as iPhone stuck on SOS mode,iPhone stuck on lock screen,iPhone black screen spinning wheel, and so on. With the standard repair option, you can fix your iOS system without erasing your data! Interested? Come and experience hassle-free troubleshooting with just a few clicks and get back a nicely working Apple device in minutes.
Let’s see how to use AnyFix to get past the SOS mode malfunction error in several simple steps.
Below are the steps.
Step 1. First of all, download and install AnyFix on your computer.
Step 2. Launch AnyFix and choose the System Repair mode. Then choose the Device Bug mode and click Start Now to keep on.
Choose System Repair Option
Step 3. Next, select Standard Repair.
Select Standard Repair Mode
Step 4. Download Firmware Package for your iOS device.
Step 5. Click the Start Standard Repair button to repair your iOS system issues instantly and easily. Now, AnyFix will start repairing your iPhone SE. Don’t disconnect your device until it restarts. Once the repair process is completed, click “OK.”
Click Start Standard Repair Mode
You’ve seen how simple it is to fix an iOS system using AnyFix. Now, you have grasped several fixes for this issue, and there must be one perfect for your needs.
1. How can I force restart my iPhone SE?
If your iPhone SE isn’t responding or won’t turn on, and you can try forcing it to restart.
When the Apple logo appears, release the side button.
2. Why is my iPhone SE screen black but still on?
Your iPhone SE screen black but still working can be caused by an iOS system bug on your phone. Or your iPhone SE displays a black screen to preserve the power when its power is too low.
So far, the guide has walked through the potential causes and ways to solve the issue that iPhone SE won’t turn on. From simply charging your iPhone SE to an advanced iOS system recovery tool AnyFix, every way has been discussed specifically. By the way, if you can’t bother to transfer your data from time to time in the process of performing a hard reset or updating software, then AnyFix is recommended for its versatile function of iOS system repair without data loss. Take action!
