iPhone display screen not responding to touch? Discover the reason and learn how to fix the issue without spending a dime here in this post. We will discuss the 8 ways to fix iPhone screen freezes and won’t respond to touch issues.
Undoubtedly, your screen is paramount when dealing with an iPhone. Whether you want to send a text, unlock your screen, configure your device, or install any app, your screen must be functional for you to execute any of the operations. But what happens when the screen isn’t responding to touch? Performing any of the mentioned operations becomes difficult.
If this is a problem you are experiencing on your device and seeking a solution, this post is for you. Here, we present to you the reasons your iPhone screen is frozen and won’t respond to touch plus the appropriate solutions to resolve the issue. Keep reading!
Below we have the rundown of the reasons why your iPhone screen freezes and won’t respond to touch. Check them out to avoid future occurrences:
How to fix iPhone screen freezes and won’t respond to touch? Using any of the troubleshooting solutions recommended down here, you can quickly fix iPhone screen freezes and won’t respond to touch issues without involving assistance from anyone:
Force restart is one of the basic solutions you can apply to fix iPhone screen not responding to touch issues on any iPhone model. It’s a simple solution that lets you restart your system without having to turn it off and on. Just by holding the right set of buttons, your phone will go off and come on by itself.
With this solution, your iPhone refreshes itself and clears all bugs or glitches that are causing it to not respond to touch. Here’s how to force restart the different iPhone models:
Force Restart iPhone to Fix iPhone Not Responding to Touch or Screen Frozen
When your iPhone comes up, try tapping the screen to see if the underlying issue has been resolved.
Perhaps force restart doesn’t fix the issue on your iPhone, you should try resolving it following the professional approach which involves the use of an iOS repair tool like AnyFix – iOS System Recovery. This software is one of the most versatile for handling any system-related issue that occurs on an iPhone or iPad, including iPhone screen freezes and won’t respond to touch.
AnyFix can fix more than 150+ iOS system-related problems without compromising user’s data. It doesn’t matter what model of iDevice or iOS you are running on the faulty device. The software scans and recommends the most suitable firmware package to fix your system and return the operations back to normal. Furthermore, on the services offered, AnyFix is also capable of upgrading/downgrading your iPhone to any OS of your choice.
Step 1. Free get AnyFix and launch it > Select the System Repair mode.
AnyFix Main Screen
Step 2. On the subsequent interface, proceed to the left sidebar and hit the Screen Stuck tab. Afterwards, click on Start Now.
Step 3. Proceed to select a repair mode from the 3 options provided on your display screen. Click on Standard Repair.
AnyFix Standard Repair
Once done, click Standard Repair again at the bottom of the screen.
Step 4. Without delay, AnyFix will scrutinize the faulty iPhone, display a few info about it on your screen and then recommend a firmware package to fix it. Confirm the details shown and click on Download.
Step 5. Wait till the firmware package is downloaded. After that, a screen with the Start Standard Repair button will come up. Tap on the button and AnyFix will commence the system repair immediately. In no time, the software will clear all bugs, update your firmware, and get rid of iPhone screen freezes and won’t respond to touch issues.
Repair Is Completed
Since insufficient storage is one of the principal causes of iPhone screen freezes and won’t respond to touch, clearing junk files and data from your device would be helpful in creating space. We suggest that you browse through your iPhone for large files and apps that you don’t usually use and get rid of them. In case you are dealing with an app, follow the steps below to remove it from your iPhone:
If you are looking to delete files, then follow these steps:
Waiting for the Battery to Drain
Waiting until your battery is drained is another possible solution you could use to tackle the underlying issue. However, it’s best to apply this method when you have a low battery percentage on your device. This way, you don’t have to wait for so long until the power goes off on the device. Afterward, you can proceed to connect the iPhone to a power source for charging. Doing this helps you recycle power on the device and clears the iPhone screen freezes and won’t respond to touch issues.
Running too many apps at the same time on your iPhone can be the reason the device is freezing and not responding to touch. In order to fix this, it’s suggested that you force quit all opened apps, wait a while, then try tapping your screen again to see if the issue is cleared.
To force quit the apps on your iPhone, follow the steps below:
Force Quitting Apps on Your iPhone
The solution above only works for devices with Face ID. If you use an iPhone with the home button, follow the illustrative guide down here to force quit apps:
Another quick solution to fix iPhone screen freezes and won’t respond to touch is installing the most recent iOS update on the device. With this solution, all bugs and errors and bugs that are present in the previous iOS version and responsible for the issue you are facing on your device are automatically removed.
Use these stepwise guide to update your iPhone:
Try to Update Your iPhone
You need a stable and reliable internet connection to implement this solution.
Factory reset is another troubleshooting solution to fix iPhone screen freezes and won’t respond to touch. This solution wipes all custom settings and installed apps that you have on your iPhone so the device looks like it was newly bought. By doing this, the affected apps or wrong configurations that are responsible for the underlying issue are removed.
To perform factory reset on your iPhone, you can follow the procedure below:
Step 1: Launch the latest version of iTunes on your computer and connect the faulty iPhone using a reliable USB cable.
Step 2: On the top left corner of your screen, locate and click on the device icon. After that, select Summary on the left sidebar.
Factory Reset iPhone
Step 3: Proceed to the right hand side of the screen shown and click on Restore iPhone. iTunes will commence the system reset in no time.
Since the guide above will lead to data loss, we suggest that you click on Backups on the right-hand panel and then wait patiently for iTunes to store your data safely. Afterward, you can proceed to the last stage of the guide to reset the iPhone. Once the installation is over, you can import the backed-up files on your device.
Finally, we suggest that you contact and ask Apple support to help you resolve iPhone screen freezes and won’t respond to touch if the issue persists after employing the solutions above. The team is in the best position to help you out in case there is a hardware-related issue like the damaged touchpad, broken screen, etc.
Running into iPhone screen freezes and won’t respond to touch isn’t a new thing. However, for someone who hasn’t experienced such in the past, it could be alarming. Fortunately, there are some techniques you implement to fix the issue and restore your device back to normal. There are 8 handy solutions recommended in the post above, select and apply the one that suits you. Our best solution is AnyFix. The software fixes the problem without tampering with the data files on your iPhone. So, free get AnyFix today and be your hero!
