iPhone keyboard lagging issues iOS update is one of the recent feedbacks obtained from many end-users. So in this post, we will look at the potential reasons for iPhone keyboard lag and the 11 troubleshooting solutions that you can use to fix it here in this post.
Hi there, Recently, I heard about the iOS 17 update and the great features it holds, so I decided to upgrade my iOS. The operation was successful, but I’ve got a problem- lagging keyboard. It takes almost forever for my keyboard to print any letter I click on and it’s annoying. Please, how can I fix this?
Slow or lagging keyboards can be annoying to deal with, as you expect your device to print every letter you click on. However, for some reasons, this might not go as planned. And in such a situation, a guide on how to fix iPhone keyboard lags while typing would be helpful. Here in this post, we will share the comprehensive guide that you can use, as we reveal the 11 simple ways to resolve iPhone keyboard lag issues. Continue reading!
The Apple iPhone is nicely designed and equipped with a sleek keyboard that responds to clicks within the shortest possible time, so you shouldn’t experience keyboard lag. However, if the keyboard does lag, then there must be something wrong.
Some of the common reasons for keyboard lag, as discovered by experts include:
Adjusting your keyboard settings to suit your preference is great but at the same time, it can cause delay in printing your entry, especially when you make the wrong adjustment. So when you notice that your keyboard is malfunctioning while typing, it could possibly be because of your wrong keyboard configuration.
Are you using an outdated or beta version of iOS on your iPhone? If so, your device may be vulnerable to bug attack and other errors which pile up to cause software glitch which in turn causes your device to malfunction and display issues like iPhone keyboard lags, etc. To fix this, updating your system via the appropriate source or installing a new firmware package is the best thing to do.
Broken screen, and damaged flex are some of the hardware issues that can cause your keyboard not to respond to click or take forever to print results. Visiting the nearest Apple store in your vicinity is the only solution to fix this problem.
Apply the following troubleshooting solutions to resolve iPhone keyboard lag while typing:
Force restart is a common troubleshooting solution for fixing iOS related issues. This involves switching the corresponding device OFF and ON, so as to clear bugs and refresh your iPhone RAM so it can function at optimal level.
The procedure to follow isn’t rigorous and differs for the different iPhone models. Check and apply the steps that suit your phone model from the instructional guide below:
iPhone 8/X and Later Models
iPhone 7/7 Plus
iPhone 6/6 S and Older Models
Restart Different Modes of iPhone
Although third-party keyboards take typing to another dimension (positively), they are one of the chief culprits for keyboard lags on an iPhone and yours isn’t left out. The reason is that most third-party keyboards aren’t lightweight, garner data about your activities and make heavy requests on your device which can slow down the operations.
Removing or deactivating the third-party keyboard is the most effective solution to fix this on your iPhone. Follow the procedure below to remove third-party keyboards if you’ve got them installed:
Remove Keyboard in iPhone
Keyboard dictionary reset is another handy solution to help fix iPhone lags while typing. This solution helps you clear dictionary conflicts and restores the operations of your keyboard so it starts functioning at optimal levels again.
Follow the instructions down here to reset your keyboard dictionary:
Reset the Keyboard Dictionary
Since an outdated iOS version is among the reasons for iPhone lags while typing, updating your device to the latest iOS could help resolve the underlying problem. This solution is super easy to apply and can be performed directly on the device.
Here’s how to do this:
Launching too many apps at the same time declutters your RAM which in turn slows down the operations of your iPhone and causes it to malfunction. You can experience keyboard lags for this reason. To fix this issue and restore operations to normal on your iPhone, force closing all opened apps plus background applications will be helpful.
This solution not only improves the operations of your keyboard, it also enhances the operations of your iPhone in general. Since force closing all apps and background apps are two different things, let’s move one step at a time.
Find below, how to force close all opened apps on your iPhone:
However if you use an iPhone with a home button on it, just triple click on the Home button to preview all the opened apps. Once done, swipe up each of the apps to close it.
In order to stop background apps from operating,
Reduce Motion is a feature built specifically to help you manage the movement of certain elements on your iPhone screen. Activating this feature can help resolve the underlying problem causing iPhone keyboard lags.
You can enable Reduce Motion feature using the steps below:
Turn on Reduce Motion
The predictive text is a brilliant feature designed to master your keyboard entry overtime and then use your past content to predict your action when typing. While this is a great feature to use, it sometimes slows down the operations of your keyboard.
To avoid that, deactivating predictive text would be helpful. Here’s how to do this on your iPhone:
Disable Predictive Feature on iPhone
Another noteworthy solution to clear iPhone keyboard lags on your device is disabling keyboard settings and re-enabling it to refresh the keyboard. This solution can also help you discover which of the settings is causing your keyboard to malfunction.
So we suggest deactivating all keyboard settings, and then enabling one after another. While enabling each setting, try using the keyboard to see if the problem will occur. If it does after activating any settings, then that’s the source of keyboard lags.
Here’s how to disable keyboard settings and re-enabling them:
Still battling with iPhone lags while typing after implementing the solutions above? Try using a different app to see if the problem would occur. Sometimes, keyboard lags can be app specific, that is- happens with a particular app. This is common with apps such as Google Chrome, Twitter, and other heavily cached apps. These apps eat up your iPhone RAM and disorganize the operations.
AnyFix is a feature rich iPhone repair tool suitable for fixing keyboard lags on any iPhone model. This software is super efficient as it repairs your firmware package and fixes any other system related issues that are causing your device to malfunction.
Key Features
Step 1. Free download, install, and run AnyFix on your computer. From the home page window, select System Repair.
Tap on System Repair
Step 2. Connect the iPhone to your computer and select the 50+ iPhone Problems from the program window. Then click on the Start Now button to proceed.
Choose the 50+ iPhone Problem to Fix System Issue
Step 3. Choose the Standard Repair option from the program window and follow the screen instructions to put your iPhone into recovery mode.
Choose Standard Repair in System Repair
Step 4. Confirm the device information and click on the Download button to download the device firmware package.
Download the Firmware
Step 5. Click on the Fix Now button to start the repair process. Wait till the process finishes and make sure that the device stays connected to your computer.
System Repair Completed
Lastly, consider restoring your iPhone to factory setting if the problem persists. Factory reset will clear glitches and bugs causing keyboard lags. However, mind you, this action will erase all installed content and settings on your iPhone. If you don’t mind the consequence, you can apply the steps below to factory reset your iPhone:
Factory Reset iPhone
With the 11 troubleshooting solutions above, you can handle iPhone lags while typing on any iPhone model. All solutions are free to use, simple to employ and work effectively. However, AnyFix is our most preferred option. The software fixes keyboard lags and clears every other issue slowing down the operations of your iPhone.
