There could be several reasons why your iPhone keeps freezing, including a system glitch or insufficient storage. However, no matter what the reason, you can get your device back to normal with the 8 quick solutions discussed in this article.
Are you facing the frustrating problem of your iPhone constantly freezing and restarting? Don’t worry; we know how it feels to have your daily routine disrupted by this issue.
But the good news is that there are some quick and effective solutions to this problem. In this guide, we’ll help you understand why your iPhone keeps freezing and restarting unexpectedly, both due to software and hardware issues. We’ll also provide you with easy-to-follow instructions to troubleshoot and fix these problems so that your iPhone runs smoothly and reliably. Say goodbye to the annoyance of constant freezes and restarts as we guide you through the process of regaining control over your device!
If your iPhone is freezing or unresponsive, don’t worry; it’s a common issue that can be caused by a lot of different things. Let’s take a look at some of the most common reasons why this might be happening:
Sometimes, a specific app with a glitch may cause your iPhone to freeze.
Software bugs or glitches in the iOS operating system can also lead to freezing.
Running low on storage can lead to performance issues, including freezing and restarting.
Having too many apps running in the background can strain your iPhone’s resources, causing it to freeze or restart unexpectedly.
If you have a jailbroken iPhone, it may be prone to getting infected with malware or viruses, causing it to freeze or restart.
If there’s nothing wrong with the software, then your iPhone may be slowing down, freezing, or restarting due to some hardware issue.
Regardless of why your iPhone keeps restarting, here are 8 quick solutions to fix it.
If your iPhone keeps freezing and restarting due to a minor system glitch, force restarting it might just fix it. Restarting your device not only gets rid of glitches but also helps resolve any petty system issues that slow down your iPhone’s performance. Here are the steps to force restart different iPhone models:
Another reason for your iPhone freezing and restarting could be an outdated system and apps. Therefore, if you update your iOS, it could fix the freezing and restarting issue. Find how to update iOS and app on your iPhone below.
Steps to Update iOS
Steps to Update Apps
If your iPhone is freezing and restarting due to a faulty app, turning it off could possibly solve the issue. For this:
If the above-mentioned quick solutions don’t work, you can always use iMobie PhoneRescue for iOS to repair your iOS system in one click. It comes with a “Device Rescuer” feature that helps you fix known and unknown iOS-related issues, like iPhone keeps freezing, iPhone is stuck on the Apple logo, or black screen, and bring your device back to normal operation. Check what PhoneRescue for iOS can do:
Free download PhoneRescue for iOS to fix iPhone keeps freezing and restarting:
Step 1. Launch PhoneRescue on your PC, connect your iPhone to it using a USB cable, and select “Repair iOS System” from the Device Rescuer tab.
Step 2. You will be given the option of selecting 2 modes from the interface. Select the “Advanced Mode.”
Step 3. Now follow the on-screen instructions to put your iPhone in Recovery Mode.
Step 4. Select your iPhone model and iOS version and click “Download” to continue. PhoneRescue will now download the firmware specific to your device and start restoring the software.
Step 5. Once the restoration process is complete, your iPhone will restart and function normally.
If, even after using PhoneRescuer, your iPhone keeps freezing and restarting, then there’s a possibility that your storage has reached the maximum limit. Therefore, we recommend deleting unused apps, unnecessary photos and videos, and clearing app cache and data.
This will free up some space on your device and help it run smoothly without freezing.
Another safe, reliable, and trusted way to fix the iPhone keeps freezing issue is to get AnyFix – iOS System Recovery. It is a comprehensive and versatile software tool that can help you resolve a wide range of iOS system issues, errors, and problems with ease. It’s like an all-in-one solution to fix any common iOS-related problem and ensure that your device runs smoothly.
AnyFix can fix a variety of system-related problems like iPhone or iPad, like not turning on, iPhone keeps freezing, device won’t charge, reboot loop, and over 130+ system repairs.
It has different repair modes that can help you fix any issues that you may be facing. You can choose from the Standard Repair mode for common issues or the Advanced Repair mode for more complex problems.
AnyFix can also tackle common iTunes errors and issues, making it easier to manage your iOS device’s content and backup/restore functions.
It also comes with features like optimizing iOS performance, clearing cache and junk files, and managing iOS storage to ensure your device operates at its best.
Free get AnyFix and follow these steps to fix iPhone keeps freezing:
Step 1. Launch AnyFix on your computer, and select “System Repair” from the interface. Meanwhile, connect your iPhone to your PC using a USB cable.
Step 2. Select “50+ iPhone Problems” and click on “Start Now” to begin the process.
Step 3. You will be given 3 repair options: Standard Repair, Advanced Repair, and Ultimate Repair. Select “Standard Repair” for now.
Step 4. Select your iPhone’s model and version, and click “Download” to begin. Once the firmware is downloaded, it’s time to begin fixing your iPhone. Click on “Fix Now.”
Step 5. It will take a few minutes before your iPhone is fixed, after which it will restart and will start functioning normally.
AnyFix is designed to fix all sorts of iOS-related issues; however, if your device is still acting up, you can try factory resetting it.
Sometimes, if your iPhone keeps freezing and restarting, the only solution is to reset all its settings and restore it to its factory version. This method removes all sorts of glitches, system errors, or issues that might be the root cause of your device acting up.
To reset all settings on your iPhone, follow these steps:
Step 1. Go to “Settings > General > Transfer or Reset Phone.”
Step 2. Now tap “Reset > Erase All Content and Settings” and enter your passcode to continue.
This will erase all the settings on your iPhone and reset it to the factory version. Now, when you switch on your device, you can set it up as new.
Another quick solution to fix your iPhone that keeps freezing is to restore it via iTunes. This method works by erasing your iPhone and resetting it to its factory version while fixing any firmware or iOS-related issues.
Here’s how to restore iPhone using iTunes:
These were the 8 tried and tested solutions to fix iPhone keeps freezing. However, if they fail to fix your iPhone, the problem may be with the hardware; therefore, get your device checked from the nearest Apple Store.
They will thoroughly check your device to see what’s causing the issue and fix it accordingly.
Facing issues like the iPhone keeps freezing, iPhone getting stuck on the Apple logo, or getting a white screen is pretty common. It could be due to a number of reasons, including software glitches, outdated iOS versions, insufficient space, faulty apps, etc. However, there are plenty of ways in which you can fix these issues. In this guide, we have rounded up 8 quick solutions to fix the iPhone keeps freezing issue, including using third-party apps like iMobie PhoneRescue for iOS and AnyFix. So, if your iPhone freezes, restarts, or shows any other signs of dysfunction, this guide will surely help you fix it!
