My iPhone is Dropping Calls? Why and How to Fix It?
If your iPhone keeps dropping calls after update your iPhone to the latest iOS 17, you can try the 9 methods to get your iPhone out of the problem.
Author Avatar Joy Taylor Last Updated: Jul. 26, 2024
AnyFix – Fix All iOS Issues Including iPhone Keeps Dropping Calls
Some iPhone users have reported that their iPhone keeps dropping calls. No worries! Free download AnyFix to one-click fix all iOS system errors you meet, including the iPhone dropping calls issue.
Our calls were dropped for one reason or the other from time to time. But if this keeps happening, it is a sure sign that something is wrong with your iPhone. You may be wondering why this happens and how you can fix it.
iPhone dropped issues can be caused by various hardware and software-related reasons, such as iPhone dropped after updating. Apple will release the latest iOS 17 system in mid-September this year, if you have the problem of iPhone dropping calls after updating iOS 17, in this article, we will help you find the source of the problem and tell you how to solve it.
Why Does My iPhone Keep Dropping Calls?
  • iPhone usually drops calls because of a bad signal in the region from which you’re making the call. So if your call was suddenly interrupted, you should check how many receptions bar the iPhone has. Moving within a few feet radius won’t resolve the issue, and you’ll probably have to wait until you arrive in the area in which your carrier has good coverage.
  • Besides poor signal, pending iOS updates, damaged SIM cards, or even the change of a time zone can cause the iPhone to drop calls. Moreover, your iPhone’s RAM may be overwhelmed by the apps you’re using or some other software bug may be causing the problem.
In any case, you don’t have to be a tech wiz to sort this issue out on your own, although contacting your carrier may be necessary.
If your iPhone keeps dropping calls even though it has a good signal, then the problem is most likely created by malfunctioning software or hardware. Here are a few things you can do that should prevent the iPhone from dropping calls.
1. 1-Click Fix iPhone Keeps Dropping Calls Directly [Safe & Easy]
Since you may be in a hurry to fix this problem, we list the one-stop iPhone system errors repairer as the first solution here. This method is a third-party iOS fix tool. If you are reluctant to download any application, you may scroll down to go to the next solution.
AnyFixiOS System Recovery is an iOS-based device repairer. It is capable of resolving 130+ system issues for iPhone/iPad/iPod touch/Apple TV and 200+ iTunes errors. With this tool, you can fix the “iPhone dropping calls” issue with one click. Check more features of AnyFix below to learn it better:
AnyFix – iOS Devices System Repairer
  • Solve the iPhone drop calls problem with one click.
  • Fix iPhone stuck on the call screen with simple steps.
  • Lightning-fast speed to detect all underlying system errors.
  • No erase of data and no viruses carried, 100% clean & safe.
Step 1. Download and install the AnyFix on your computer. Connect your iPhone to your computer and launch AnyFix. Then, choose the option that says System Repair.
AnyFix System Repair Option
Step 2. Click on Start Now on the following screen to start repairing your iPhone.
AnyFix System Repair Device Bug
Step 3. Choose Standard Repair as the repair mode. Follow the leads, AnyFix will download the matchable firmware for your iPhone.
AnyFix Standard Repair
Step 4. When your iPhone is fixed and is free of any errors, you will see the following on your screen.
Repair Is Completed
Repair Is Completed
2. Check Your SIM Card to Fix iPhone Keeps Dropping Calls
A bent or cracked SIM card may be the reason why the iPhone is dropping calls. To clear the doubt that this is the root of the problem, you should remove the card from your iPhone and inspect it closely.
  1. Locate the position of the SIM card tray on your iPhone. It is usually positioned on the device’s right side, but its exact location varies from one model to another. Use the SIM card tray pin to eject the tray.
  2. Examine the SIM card carefully, and search for any traces of damage. Put it back into the tray and make sure it is correctly positioned before reinserting the tray into the iPhone.
  3. Switch on the device and have someone call you in order to check if your iPhone is still dropping calls.
Change SIM Card with Eject Tool
Check Your SIM Card
It is worth noting that you have to replace the SIM card if it is damaged.
Related Read  How to Transfer Contacts from iPhone to SIM Card
3. Restart the Device to Fix iPhone Keeps Dropping Calls
Sometimes a simple restart of the device can fix this issue. The exact steps of restarting an iPhone depend on the model.
You can learn how to restart your iPhone to try to get your iPhone out of dropping calls issues.
Press the Buttons to Restart the Device
Restart the Device
4. Switch the Airplane Mode on and off
Surprisingly enough toggling the Airplane mode off and on can sometimes be a long-term solution to iPhone dropping calls issue. In order to do this, you can
  1. Tap on the Settings icon
  2. Click on the Airplane mode option to enable it
Turn on Airplane Mode on your iPhone
Your device is going to be disconnected from WiFi, while Cellular Data and Bluetooth are going to be disabled for as long as the Airplane mode is on. Tap on the Airplane mode once more to switch it off, and check if your iPhone is still dropping calls.
5. Turn off the Device When You Are Not Using It
Cleaning cache is important for a variety of reasons, and emptying cache memory may restore your device’s ability to take calls normally. Turning off your iPhone whenever you are not using it will delete all unused files from the cache memory, which in turn may prevent the device from dropping calls.
Apps that are running in the background are helping to fill the cache memory faster, and disabling them can help you take calls normally.
6. Reset Network Settings to Fix iPhone Keeps Dropping Calls
The network settings may also be the reason why your iPhone is dropping calls, so you should reset them if you are having constant difficulties staying on the line.
  1. Tap on the General option located in the Settings menu.
  2. Once the General window loads, you should tap on the Reset option and then pick Reset Network Settings.
Select Reset Network Settings
7. Activate the Caller ID to Fix iPhone Keeps Dropping Calls
Failing to activate the caller ID can be the source of your call dropping problems. To check if the option has been activated, you should:
  • Go to the Settings menu and open the Phone submenu.
  • Tap on the Show My Caller ID option and make sure that this feature is on.
    Enable Show My Caller ID
Optionally you can use the #3# code that disables the device’s anonymity status and in some cases, this code may help you fix the call dropping issues you’re experiencing.
8. Check for Carrier Updates to Fix iPhone Keeps Dropping Calls
Keeping the carrier settings up to date is vital for the iPhone’s normal functioning. To check if there is an update, you can:
  1. Go to the Settings menu, you can tap on the General submenu and then pick the About option.
  2. After a few moments, a pop-up should appear on the screen informing you about a pending update. In case nothing happens chances are that there is nothing wrong with carrier settings.
Carrier Settings Update
9. Set Time and Date Automatically
iPhone owners who travel frequently may be facing call-dropping problems because their device doesn’t set the Time and Date automatically. Making sure that this feature is enabled won’t take more than a few moments, you just need to fellow the step:
  • Go to the General submenu that is located within the Settings menu.
  • Tap on the Date and Time option.
  • Check if the Set Automatically option is selected, and proceed to change the setting if it isn’t.
    Check the Date & Time Settings
Although having your calls interrupted continually is certainly not pleasant, resolving this issue shouldn’t be too difficult. We hope that this article has helped you find the reason why your iPhone is dropping calls. And if you want to solve this problem quickly, just download AnyFix to one-click fix the iPhone drops calls issue. Let us know if you fixed the problem successfully in the comments.
