iPhone’s brightness not working? We have the fix for you! From simple restarts to software repairs, this article offers a range of solutions to fix auto-brightness issues, software glitches, and more. Find the fix you need to get your screen shining at the perfect level again.
Ever tried to read a text on your iPhone under the blazing sun, only to find the screen stubbornly dim? Or worse, been blinded by a piercingly bright screen in a dark room? If your iPhone’s brightness settings seem to have a mind of their own, you’re not alone. This frustrating issue can pop up unexpectedly, but don’t despair.
Before you reach for the sunglasses (or the eye drops!), let’s figure out why your iPhone’s brightness isn’t cooperating. In this article, we will help you troubleshoot your iPhone’s brightness issues. Ready to get your screen back to perfect brightness?
Brightness problems are super annoying! One minute you’re scrolling through social media in perfect lighting, the next you’re squinting to see anything on the screen.
The good news is, that there are usually simple explanations behind why your iPhone’s brightness isn’t working properly. Let’s look at some of these reasons:
Something could be wrong with the actual screen of your iPhone that makes everything look dimmer. Or, the tiny sensors that adjust brightness automatically might be broken. That’s why the brightness won’t change even when the light around you does.
Now, let’s get started on fixing these! We’ll get your screen shining bright (or comfortably dim) again.
Alright, let’s get your iPhone screen to behave properly again! We’ll look into some solutions, starting simple and going deeper if needed.
Sometimes, a simple restart can fix all sorts of strange iPhone problems, including weird brightness. Here’s how to restart your iPhone, depending on the model you have:
Step 1: Hold the volume button and the side button together.
Step 2: Slide the power-off slider when it shows up.
Step 3: Wait, then hold the side button to turn it back on.
Force Restart iPhone to Fix iPhone Not Responding to Touch or Screen Frozen
Step 1: Hold down the button on the side or top of your phone.
Step 2: Slide the power-off slider that appears.
Step 3: Wait a bit, then hold the same button again to turn it on.
Didn’t fix the issue? Let’s move on to the next step.
iPhones try to be smart with the auto-brightness thing. It’s supposed to make your screen easier to see, no matter how bright or dark it is around you. But sometimes, it just gets it wrong, making your screen weirdly dim or super bright.
Let’s see if that’s what’s messing things up:
Step 1: Go to “Settings”.
Step 2: Tap “Accessibility”.
Tap Accessibility
Step 3: Choose “Display & Text Size”.
Step 4: Toggle the “Auto-Brightness” switch off. If it was already off, try turning it on, and then off again.
Still no luck? Don’t worry, there are more things to try!
Auto-brightness tries to be helpful, but sometimes it gets confused. It might think things are brighter than they are, or maybe you just like to be in charge. Either way, here’s the easy fix:
Step 1: Open your Control Center.
Step 2: Find the brightness slider.
Step 3: Drag up for brighter, down for dimmer.
Still having trouble? Let’s dig a little deeper into your iPhone’s software.
Sometimes, the brightness problem goes deeper than just a misbehaving setting. Sometimes, your iPhone’s software (iOS) can have a little bug. That’s where AnyFix – iOS System Recovery comes in to help. AnyFix acts as your iPhone’s tech support team. It’s a program made to fix all annoying iOS problems. Things like a frozen screen, apps that won’t open, weird brightness issues, stuck on Apple logo, boot loop, etc can all be fixed. And the best part? It fixes all those problems without deleting your photos, messages, or anything else important. All you need to do is click the buttons to repair the system.
To fix your brightness issue, here is what you can do:
Step 1: Download and launch AnyFix on your computer. Using a USB cable connect iPhone to computer. Click System Repair option.
AnyFix System Repair Option
Step 2: Choose the issue you want to fix. Then, click on Start Now.
AnyFix System Repair Device Bug
Step 3: Click on the Standard Repair option if you don’t want to lose your important data.
AnyFix Standard Repair
Step 4: Download the firmware. Once downloaded, click on the Start Standard Repair button.
Step 5: Wait for the repair to be completed.
Repair Is Completed
If software troubleshooting doesn’t help, we’ll try some other quick workarounds.
Stuck outside on a sunny day? Can’t see a thing on your screen? Or maybe you’re in bed at night, and your phone’s way too bright. Don’t worry! There are simple ways to fix it, no special tools needed.
Let’s try adjusting the accessibility setting next.
iPhones have this neat setting called “Reduce White Point.” It’s meant to tone down super bright colors so they’re easier on your eyes. But sometimes, it can make your whole screen look dimmer than you’d like. Let’s see if turning it off makes a difference:
Step 1: Go to “Settings.”
Step 2: Tap “Accessibility.”
Step 3: Choose “Display & Text Size.”
Step 4: Toggle the “Reduce White Point” switch off.
If the setting was already off, try toggling it on and then off again, just in case.
However, even if this didn’t work, let’s try one last thing.
This is your last option – it’s like hitting the reset button on your iPhone. It wipes out all your personalized settings, like your wallpaper, Wi-Fi passwords, and brightness settings. If nothing else works, it’s worth trying. But remember, you’ll need to set everything up again later!
Here’s how to do the reset:
Step 2: Tap “General”.
Step 3: Scroll way down and choose “Transfer or Reset iPhone.”
Step 4: Select “Reset.”
Step 5: Choose “Reset All Settings.”
Select Reset All Settings
Hopefully, one of these solutions brought your iPhone screen back to its bright self! If not, it might be time to consider a hardware issue and consult a professional.
Phone problems can be a pain, but they happen to everyone, even with our favorite iPhones! Don’t worry, you can fix those brightness problems yourself. If your iPhone’s brightness acts weird again, stay calm. Try the fixes in this guide. And if this issue is caused by system issues, don’t forget to get rid of this problem with AnyFix in simple clicks. You should be able to see your screen perfectly again in no time. But if you can’t do it yourself, seek professional help.
