My friends iPhone 11 has this black vertical line in the middle of the phone, has anyone else encountered this and know how to fix? – Reddit
Finding a black line flashing across your iPhone 11 screen when you unlock it can be both worrying and inconvenient. The issue is known as “black lines on iPhone 11 screen,” and more and more users are reporting that they notice a horizontal line briefly appearing on the screen when turning on or unlocking their phone.
In fact, Apple has acknowledged that customers may “report seeing horizontal lines flashing briefly on the screen during these actions.” For many, this immediately raises concerns about the health of the device and the potential costs associated with repairs.
In this article, we’ll explore the causes of black lines on the iPhone 11 screen and provide practical solutions to help you effectively deal with and resolve the issue, ensuring your iPhone 11 is back to peak performance.
Many people will have confidence in the quality of iPhones until they encounter black lines on the iPhone 11 screen….
Although iPhone officials have ruled out hardware defects, some users have reported hardware defects. In addition, there are more reasons why the iPhone screen goes black.
Although the iPhone has said: “We are aware of this problem and will soon launch a software update to solve this problem”, many users’ problems have not been solved. In addition to relying on iPhone software updates, you can also take the following methods to fix it.
Sometimes, a simple restart can fix the problem that causes black lines on your phone screen.
Here are the restart methods for different iPhone models:
iPhone 8 and later models (including iPhone SE 2, iPhone X, iPhone XR, iPhone XS, iPhone 11, etc.):
iPhone 7 and iPhone 7 Plus:
iPhone 6s and earlier models:
Make sure your iPhone has the latest iOS version installed. Go to “Settings” > “General” > “Software Update” to check and install any available updates.
iOS Update
Determine if the black lines only appear in certain apps. If so, try deleting and reinstalling those apps to see if the problem persists.
Resetting all settings can fix the problem without deleting your data. Go to Settings > General > Reset > Reset All Settings. If prompted, enter your passcode and confirm your choice.
Reset All Settings
If the black lines on the screen issue persists, consider a factory reset. Be sure to back up your data first. Go to Settings > General > Reset > Erase All Content and Settings. Enter your passcode and confirm.
Factory Reset
If the above methods cannot solve the problem, you can also use the AnyFix system repair tool. This is a professional iOS system repair tool that can not only solve the iPhone black line on the screen but also fix the charging port not working, liquid detected in the lightning connector, and other problems.
Key Features:
Step 1. Free download AnyFix on your computer. From the home page window, select System Repair.
AnyFix System Repair Option
Step 2. Connect the iPhone to your computer and select the Screen Stuck from the program window. Then click on the Start Now button to proceed.
Step 3. Choose the Standard Repair option from the program window.
Choose Standard Repair
Step 4. Confirm the device information and click on the Download button to download the device firmware package.
Step 5. Click on the Start Standard Repair button to start the repair process. Wait till the process finishes and make sure that the device stays connected to your computer.
Repair Completed
In addition to the above methods, you can also consider restoring your iPhone in DFU mode. However, this will erase all the data on your iPhone, so please use it with caution and remember to back up your data.
You can troubleshoot first. If the black screen lines are caused by a software problem, using DFU (Device Firmware Update) mode and restoring your iPhone may help you solve the black screen line problem.
Here are the steps to restore your iPhone using DFU mode:
Step1. Connect to a computer: Connect your iPhone to your computer using a USB data cable and open the latest version of iTunes (Use Finder in macOS Catalina and later).
Step2. Start DFU mode: Follow these steps to start DFU mode:
For iPhone 8 and later:
For iPhone 7:
For iPhone 6s and earlier:
Step3. Restore iPhone: In iTunes or Finder, select the option to restore your iPhone. This will erase the device and restore it to factory settings.
Restore an iPhone in DFU Mode
If the above steps do not resolve the issue, it may indicate a hardware problem. Please contact Apple Support for further help, or go to an Apple Store or authorized service provider for diagnosis and repair.
This article explores eight solutions to iPhone 11 screen black lines, from simply restarting the device to more complex hardware checks. For those who want a quick and efficient solution, you can also consider using AnyFix’s system repair feature. This can not only fix black lines on the iPhone 11 screen, but also solve other system problems such as iPhone calendar search not working. Try these solutions now to get your iPhone 11 back to normal!
