Too many wrong spellings or typographical errors in content often confuse the recipients but the auto-correct feature on iPhone has come to fix that. However, in a situation where auto-correct isn’t working, what should you do? Kindly apply any of the solutions introduced in this post.
Is iPhone auto-correct not working? How to Fix? Free download AnyFix to fix iPhone auto-correct not working 1-click! AnyFix is your one-stop solution to fix various iOS/iPadOS/tvOS/iTunes issues in minutes and bring your Apple devices back to normal without data loss.
The auto-correct feature on iPhone is designed to ease proofreading and editing by simply helping end-users adjust wrong spellings or typos observed in written content. It doesn’t matter whether or not the message is formal, the feature ensures your text is free of spelling errors without distorting the content layout.
Auto-correct uses AI to detect issues in your content and then change them automatically or better yet notify you so you can make corrections. However, sometimes, this feature often fails to work. And in such a situation, seeking how to fix it is the next thing to do.
In this post, we will discuss how to fix iPhone auto-correct not working easily and quickly at a zero cost fee. So read on, as we explore the 7 ways to do that.
Also Read: How to Fix iPhone Overheating While Charging
Just before delving into the solutions to fix iPhone auto-correct not working, let’s explore the possible reasons why you encounter such an issue on your device. Find below the possible reasons why your iPhone stopped auto-correcting:
A common reason why the auto-correct function on your iPhone isn’t working is alteration/improper keyboard settings. You need to check to see whether or not you’ve activated auto-correct in the past. If you haven’t, then you should so you have error-free content.
Another popular reason why the auto-correct function fails to work on your iPhone is a software glitch which can be attributed to outdated iOS or the installation of a beta version OS. Installing the most recent OS is the best solution in this case. Better yet, you can download a new firmware package to rectify the issue on your iPhone.
Use the following solutions to fix iPhone auto-correct not working right away:
Our first solution is checking the auto-correction settings on your device to see whether or not its enabled. We suggest this because alteration in keyboard settings is one of the principal reasons why the auto-correct function on an iPhone won’t work.
Apply the simple directions below to check the auto-correction settings on your iPhone:
Do you have the replacement shortcut feature enabled on your iPhone? If so, auto-correct might fail to work. This is because the replacement shortcut is programmed to replace some of your common phrases.
For instance, when you wish to enter BRAIN in your text and your iPhone picks BRIAN, that’s the effect of the text replacement feature. To avoid such, deactivating the feature would be helpful. Here’s how to do that:
Remove the Text Replacement Shortcut
Another quick solution to fix auto-correct not working on your device is verifying whether or not spelling and predictive settings are enabled. Spelling settings are designed to ensure auto-correct works on your iPhone while predictive settings on the other hand suggest words that are nearly similar to what you have in mind while typing.
To check and activate spelling and predictive settings on your iPhone, use the steps below:
Check Spelling and Predictive Settings
A quick reset on your keyboard dictionary is another wonderful way to resolve iPhone auto-correct not working. This solution helps you clear all misspelled words stored on your device allowing you to refresh your dictionary.
You can reset your keyboard dictionary using the steps down here:
Reset the Keyboard Dictionary
Since software glitch is one of the reasons for iPhone auto-correct not working, updating your system is a wonderful solution to employ. By updating your software, all bugs and glitches are automatically cleared so your iPhone can function at optimal levels.
A quick way to install the latest software update is to follow the simple instructions below:
Use Software Update
Force restart is another cost-free solution you can use to rescue your device from issues like iPhone auto-correct not working. This solution clears all conflicting settings, bugs, and temporary glitches causing your iPhone to malfunction.
There’s no data loss when applying this solution. However, the steps required differ from one iPhone model to another. Follow the steps that correspond with your phone model to force restart it and fix auto-correct not working immediately:
iPhone 8/X and Later
Force Restart iPhone 8/X and Later
iPhone 7/7 Plus
Force Restart iPhone 7/7 Plus
iPhone 6 and Older Models
Force Restart iPhone 6 and Older Models
If all the solutions mentioned above fail, then you should consider fixing your iOS, as the firmware package might be damaged. To do this, you need a top-quality iOS system repair utility and here we recommend the iOS repair utility- AnyFix.
AnyFix is one of the most outstanding iOS system repair solutions capable of fixing iPhone auto-correct not working. This software rescues your device from this issue and brings it back to normal without crashing the system. It works for nearly all iPhone models, including the most recent one, the iPhone 15 series.
With this software, you can also handle iOS issues like white screen, frozen screen, green line of death, and 150+ others from the comfort of your home. AnyFix repairs your system in 3 steps using the most suitable firmware package. Your tech literacy doesn’t matter when operating this software- thanks to the sleek UI.
Step 1. Start by downloading the latest version of AnyFix and launch it on your PC/Mac. Select the System Repair mode.
Tap on System Repair
Step 2. Connect the faulty iPhone with the help of a reliable USB cable and wait for it to be detected by AnyFix. Click the green Start Now button.
Choose iPhone Problems and Start Now
Step 3. Next, you will be led to another screen where you have to select a repair mode to fix your system. Click Standard Repair to proceed.
Choose the Standard Repair to Fix QuickStart Not Working via AnyFix
Step 4. Now, AnyFix will scan your system. After that, it will recommend a matching firmware package to download to repair the device. Click Download.
Download a Matching Firmware for your Device
Step 5. When the download is finished, tap Fix Now and AnyFix will proceed to repair your iPhone using the newly installed firmware package.
Tap on Fix Now when Firmware Downloaded
Wait for a while until the repair is over, then you can disconnect the iPhone from your computer and use it without experiencing auto-correct not working.
Deactivating spell check on your iPhone is easy. All you need is to navigate to the Settings menu, select General, and click on the Keyboard icon on the next interface. Once done, head down to where you have ENGLISH and toggle the Check Spelling icon to turn white.
Sure, you can!
You have control over which case you want your texts to be written on your iPhone. You can choose to write in capital letters all through or small letters. To stop your iPhone from automatically capitalizing words, use the guide below:
Can I stop my iPhone from automatically capitalizing words
Auto-correct not working is a minor issue that you can fix conveniently from the comfort of your home using any of the solutions shared in the article. Choose and apply any of the solutions to fix auto-correct on your device.
AnyFix offers the best way to rescue your iPhone from auto-correct not working issues. The software repair clears software glitches and returns your device to normal working mode using the most compatible firmware package. It’s worth trying as it repairs your device completely without compromising it. If you prefer a way to easily solve this problem without any data loss, AnyFix is worth a try!
