This article talks about the reasons your iPhone 14 touch screen might not be working and 5 easy solutions to get this issue fixed promptly.
Download AnyFix to repair iOS system issues like Screen Stuck, Update Issues and so on. You can recover system failure using this tool to get things right back. It supports the latest iOS 18.
iPhone Touch Screen not working
I recently updated my iPhone 14 Pro Max to iOS 17 and everything has been working really well. I woke up this morning and my iPhone’s touch screen was unresponsive and won’t let me unlock my phone. I found a way to restart my phone by clicking the top volume button, then the bottom volume button, and then holding the lock button, however that did not fix the issue. I work primarily off of my phone so I need to get this fixed ASAP. Any tips?
Is your iPhone 14 touch screen not working? This can be a very frustrating situation. Even though Apple’s phones feature the latest technology they still run into hardware and software glitches once in a while.
If you notice that your iPhone is not responding to your touch you must resolve this issue promptly to avoid further complications. Luckily, there are several methods that can come in useful in this situation. In this guide, we’ll talk about the common causes of this problem and share some trusted solutions to get this issue fixed.
If your iPhone’s touch screen is not working, you won’t be able to perform any functions on it. The screen won’t respond despite swiping your fingers across it. To fix the problem, it is important to know what causes it.
There can be many reasons why your iPhone 14 touch screen isn’t working. Some of the most common ones are:
Not repairing an unresponsive touchscreen can lead to several issues. Here’s why this issue must be resolved quickly.
If your iPhone 14 touchscreen isn’t working, try these methods to get your phone fixed:
At times, the screen can be completely unresponsive so you might not be able to slide the power off slider on your phone. In that case you’ll need to force restart your iPhone. This process is a little different than how you usually restart your phone.
Step 1: Press and release the increase volume button.
Step 2: Press and release the decrease volume button.
Step 3: Press and hold the side button of your phone and wait for Apple logo to appear.
In most cases, force restarting your phone may resolve the issue of the unresponsive screen. So, it’s recommended to try this solution before attempting anything else.
If the issue started after you got a new screen protector for your phone, it is possible that it was not applied properly. Air bubbles within the screen and the screen can cause the phone’s screen to stop working. Try removing and reapplying the screen protector if you believe this may be causing the problem.
Other than this, make sure that the screen is clean. Use a fibercloth to clean the screen till its spot free. This will help solve the issue if it was caused by dirt or grime stuck on the screen or under the screen protector.
If your touch screen is unresponsive, you won’t be able to update the software from the settings. Here’s how to update your iPhone 14.:
Step 1: Connect your iPhone to your computer.
Step 2: If you’re using Windows or macOS 10.14 or earlier, open iTunes.
Logo of iTunes
Step 3: Perform a force restart on your iPhone.
Force restarting iPhone
Step 4: Look for the recovery mode screen on your iPhone.
Enter Recovery Mode on the iPhone
Step 5: Select “Update” in the window to download and install the latest iOS version.
Update the Software
AnyFix is a professional iOS System Recovery tool to handle various iOS system-related issues like touch screen not working and iPhone screen freezes.
Step 1: Install AnyFix on your computer. Use a lightning cable to connect your computer to your iPhone. Then choose System Repair on the home screen.
AnyFix Main Screen
Step 2. On the subsequent interface, proceed to the left sidebar and hit the Screen Stuck tab. Afterwards, click on Start Now.
Step 3: Then in the “System Repair” screen, choose “Standard Repair” mode to fix iOS issues on your device. Once done, click Standard Repair again at the bottom of the screen.
AnyFix Standard Repair
Choosing standard mode will erase all the data on your phone. So its recommended to only opt for this mode if the advanced mode doesn’t work for you.
Step 5: AnyFix will repair your device automatically. Wait till the iOS fixing process is complete before unplugging your device. Once the damage has been repaired, the interface below will appear.
Repair Is Completed
If updating your phone doesn’t resolve the issue, the last resort is to factory reset your phone. This may result in data loss, so make sure to create backups before you do this.
Step 1: First, go to Settings. Then click “General” and then “Transfer” or “Reset” .
Step 2: Enter your passcode or Apple ID password.
Step 3: Confirm that you want to erase your device.
Step 4: Wait for the process to complete.
Factory Reset Phone Instructions
Even though your iPhone 14 touch screen not working issue might seem alarming, it’s worth trying a few basic fixes before you seek professional help.
With its user-friendly interface and effective repair options, AnyFix helps restore your iPhone 14’s functionality quickly and easily. Don’t let a non-responsive touch screen disrupt your day—download it and get your device back in working order.
