How to Fix iPhone 14 Pro Max Green Screen
“ I’m experiencing the green screen issue on my 14 pro max. I use my mobile carefully & now I see so many people are facing the same issue. I took it to an authorized service provider for repairs, and they informed me that the screen needed to be replaced. The process is expected to take around a month. That’s too long… What should I do next?”, a user asked on Apple Community.
Author Avatar Joy Taylor Last Updated: Feb. 27, 2025
AnyFix – Fix iPhone 14 Green Screen
Download AnyFix to repair iPhone 14/14 Pro Max green screen caused by the system issues. Save time on refreshing your iPhone 14 series and use it normally. Support the latest iOS 18.
A heated discussion was triggered by iPhone 14 pro max green screen on Apple Community. It seems that this issue always happens after updating the iOS system or for some invisible and subtle reasons. And what makes things worse is that you just got this iPhone 14 pro max or the warranty expired not long ago. That can be frustrating!
Luckily, there is always a way. This detailed guide will walk you through the potential causes and several easy and practical ways to solve this annoying issue. Let’s check it together and find the one perfect for your needs!
Also Read: How to fix iPhone 14 won’t turn on
Part 1. What Causes iPhone 14 Pro Max Green Screen?
According to the official response, the frequent iPhone green screen issue is probably a result of the software bug. This seems to be a reasonable explanation because Apple users always encounter software bugs. However, this annoying issue still needs to be solved, though the iOS system has been updated several times. To explore what causes iPhone 14 pro max green screen, this guide will provide you with potential reasons.
  • Wrong display settings.
  • A busy system(you run numerous apps simultaneously).
  • Software bugs and glitches.
  • Hardware damage.
  • Water damage or drop damage.
Now, you must have learned something about why your iPhone 14 Pro Max screen turns green. This is the first step for us to overcome this issue. Then, with the initial judgment about your iPhone’s situation, you can explore some ways to resolve this issue. Let’s go on to have a look!
Part 2. Fix Green Screen iPhone 14 When It Still Works
Sometimes, the green screen iPhone 14 can still be functional and you can operate it though the display is a little annoying. In this case, you should hurry up to find fixes to recover your iPhone soon. Below this guide has listed three practical methods with detailed steps for you to follow. Let’s go ahead and take measures to solve your green-screen iPhone 14.
Way 1. Adjust Display Settings
Wrong display settings will cause the iPhone 14 green screen, so adjusting display settings with one click can be the first and easiest measure to take. Here are two simple steps for you to follow:
  • Open Control Center, then drag. up or down.
  • Go to Settings > Display & Brightness, then drag the slider.
Tap on "Display & Brightness."
Tap on “Display & Brightness.”
By following these two simple steps, you can quickly adjust display settings.
Way 2. Reset All Settings
If adjusting display settings doesn’t work, there may be some other potential settings wrongs or software bugs and glitches. In this case, resetting all settings can be taken into consideration. Below are the steps for you to try:
  • Go to Settings > General > Reset > Reset All Settings.
Reset All Settings
Reset All Settings
  • Tap your password if prompted.
  • Then wait for this process to be completed.
Resetting all settings will remove all your preferences for WiFi, Bluetooth, Sounds, etc. Make sure that you record your preference before you do that.
Way 3. Refresh the Back Office
Resetting all settings but in vain?  Sometimes, the busy system may also cause iPhone 14 green screen, so try to refresh your iPhone 14’s back office to remove the apps running simultaneously. Below are the steps:
  •  Hit the home button twice, Then you can see all apps running in the back office.
  • Swipe them up from the bottom.
So far, you have learned how to fix the green screen of iPhone 14 when it still works, maybe you have got your screen back successfully. That’s so great! However, not everyone has the green screen still working, so next, the guide will discuss the ways to recover the green screen iPhone 14 when it can’t work in detail.
Part 3. Recover Green Screen iPhone 14 When it Can’t Work
A common and frustrating situation is that the iPhone 14 screen turns green while it can’t work. And many Apple users have this annoying experience. Today, the guide has collected four effective ways for you to have your iPhone 14 recovered. Let’s check it!
Way 1. One-click Fix via AnyFix without Data Loss
Still stuck in iPhone 14 pro max green screen malfunction? You may think there is no perfect way to fix this issue. But don’t lose heart, a specialized iOS system repair tool can help you.  AnyFix is an advanced iOS system repair tool that removes all the issues with your iOS system, such as iPhone blue screen, iPhone screen not working, iPhone black screen, and so on. With the standard repair option, you can fix your iOS system without erasing your data! Interested? Come and experience hassle-free troubleshooting with just a few clicks and get back a nicely working Apple device in minutes.
Let’s see how to use AnyFix to get past the green screen malfunction error in several simple steps.
Step 1. First of all, download and install AnyFix on your computer.
Step 2. Launch AnyFix and choose the System Repair mode. Then choose the Screen Stuck mode and click Start Now to keep on.
Step 3. Next, select Standard Repair.
AnyFix Standard Repair
Step 4. Download Firmware Package for your iOS device.
Step 5. Click the Start Standard Repair button to repair your iOS system issues instantly and easily. Now, AnyFix will start repairing your iPhone 14 Pro Max. Don’t disconnect your device until it restarts. Once the repair process is completed, click “OK.”
Repair Is Completed
Repair Is Completed
You’ve seen how simple it is to fix an iOS system using AnyFix.
Way 2. Perform a Hard Reset
Performing a hard reset on your iPhone 14 can also resolve the software glitches and bugs in your iOS system. However, you are at risk of losing your data. So remember to transfer and store your data before you force reset your iPhone 14. Follow the steps below to have a try:
  • Press and quickly release the volume up button.
  • Then press and quickly release the volume down button.
  • Press and hold the side button waiting for the Apple logo to appear.
By trying these steps, you can easily reset your iPhone 14 to factory default. However, if this way doesn’t work, then keep reading.
Way 3. Restore iPhone 14 via iTunes
If performing a hard reset on your iPhone 14 can not work, there may still be something wrong with your iOS system. As a last resort, Try to restore iPhone 14 via iTunes, but remember to store your data before you do that for there is a risk of data loss through this way, too. Here are the steps:
  • Connect your device to your computer.
  • In the iTunes app on your PC, click the Device button near the top left of the iTunes window.
  • Click Summary.
  • Click Restore, then follow the onscreen instructions.
With several clicks, you can restore iPhone 14 via iTunes.
Way 4. Turn to Apple Support
If all of the ways before are tried in vain, then you need to turn to Apple Support to get professional suggestions.
Have you had your device repaired? There must be one that is best for your needs. So take it easy and just follow these steps to try on your iPhone 14 pro max, a surprise may wait there!
FAQs About iPhone 14 Pro Max Green Screen
Q1. What to Do if You Drop Your iPhone 14 Pro Max and the Screen Turns Green?
If this happens, first you need to check whether there are any visible signs of damage and cracks on your screen. If yes, it seems like the LCD has been damaged. In this case, you need to replace your LCD at an authorized repair center. If not, it may be the software issues rather than hardware damage. You can turn to a third-party iOS system recovery tool like AnyFix to diagnose and recover your device.
Q2. How to Fix the Green iPhone 14 Pro Max Screen with Water Damage?
Water damage worsens the green iPhone 14 pro max screen, in that it always causes hardware damage like your internal components and display. Once this happens, you must first turn off your iPhone 14 Pro Max. Then try to dry it in a dry environment or using a hair dryer. If all these don’t work, you’d better turn to an authorized repair center.
Now, the guide has come to the end of this guide and I hope you have fixed your iPhone 14 pro max green screen and are enjoying your day. This guide has provided you with detailed information about the potential causes and solutions of this green screen iPhone 14 issue, from some simple settings to an advanced iOS system recovery tool AnyFix. Particularly, if data loss can’t be tolerated, the versatile iOS system recovery tool for 150+ iOS system issues is recommended. Take action and get your green screen iPhone 14 Pro Max recovered!
