“My Iphone 11 has been stuck on this screen for a month now and i cant do anything because of corona virus having everything closed. Ive tried the force restart already multiple times and it did not work for me at all, it just went back to the bootloop. I haven’t even had this phone for a full year and its already acting up. What can i do? ”, a user asked on App Community.
iPhone stuck on Apple logo after the update and don’t know how to get out of that? Free download AnyFix to fix this problem in minutes. No skills are required. Support all iPhone models.
The iPhone 11 series, known for its functionality and popularity, continues to serve many users well into 2024. However, like any smart device, it can encounter issues from time to time. One common problem that has sparked considerable discussion online is iPhone 11 stuck on Apple logo. This frustrating issue has affected numerous Apple users, prompting them to seek effective solutions. In this guide, you will explore the potential causes of this problem and provide practical fixes to help you resolve it and get your iPhone 11 working properly again.
Also read: How to fix iPhone 13 stuck on SOS mode
Usually, several underlying causes are resulting in your iPhone 11 being stuck on the Apple logo. Getting your head around these potential reasons can help you identify the situation of your iPhone and find an effective solution more quickly. Here’s a list of the most common issues:
Software Issues
Hardware Problems
External Factors
By recognizing these causes, you can choose methods to resolve your issue accordingly. Below are five easy ways with specific instructions for you to try.
Can’t wait to know how to fix your iPhone 11 issue? Then follow this guide to apply these practical ways on your iPhone 11.
A malfunctioning battery will cause iPhone 11 stuck on Apple logo in the process of updating the iOS system or something else. So the first step is to check whether there is something wrong with the hardware, follow the steps below to check it:
If there are any hardware issues, you’d better turn to an authorized repair center. If not, you can check the following methods to fix iPhone 11 stuck on Apple logo by yourself.
If there are no hardware issues, maybe the software bugs and glitches are to blame for this issue. You can try to update or restore via iTunes to reinstall the software on your device to recover it. You can do the following:
Tap on Restore to proceed
iPhone Recovery mode allows users to recover some issues that can’t be resolved in other ways. So if all those ways mentioned before don’t work, you can try to enter recovery mode to fix iPhone 11 stuck in Apple logo. Follow the steps below to have a try:
Put iPhone into Recovery Mode
With these three simple steps, you can enter recovery mode easily. If this can’t help, don’t worry, try to perform a hard reset.
Performing a hard reset on your iPhone 11 can resolve the software glitches and bugs in your iOS system. However, you are at risk of losing all your data. So remember to transfer and store your data before you hard reset your iPhone 11. Follow the steps below to have a try:
Hard Reset iPhone 11
Following these steps, you can easily reset your iPhone 11 to factory default. However, if you want a way not to lose data or this way doesn’t work, then keep reading.
You may also like: How to factory reset iPhone without passcode
iPhone 11 still in Apple logo? Can’t bother to recover your data before restoring your iPhone 11? You may think there is no perfect way for you to fix this issue.
But don’t lose heart, a specialized iOS system repair tool can help you. AnyFix is an advanced iOS system repair tool that removes all the issues with your iOS system, such as iPhone stuck on SOS mode,iPhone stuck on lock screen,iPhone black screen spinning wheel, and so on. With the standard repair option, you can fix your iOS system without erasing your data! Interested? Come and experience hassle-free troubleshooting with just a few clicks and get back a nicely working Apple device in minutes.
Let’s see how to use AnyFix to get past the SOS mode malfunction error in several simple steps.
Step 1. First of all, download and install AnyFix on your computer.
Step 2. Launch AnyFix and choose the System Repair mode. Then choose the Device Bug mode and click Start Now to keep on.
Choose System Repair
Step 3. Next, select Standard Repair.
AnyFix Standard Repair
Step 4. Download Firmware Package for your iOS device.
Step 5. Click the Start Standard Repair button to repair your iOS system issues instantly and easily. Now, AnyFix will start repairing your iPhone 11. Don’t disconnect your device until it restarts. Once the repair process is completed, click “OK.”
You’ve seen how simple it is to fix an iOS system using AnyFix. Now, you have grasped several fixes for this issue, and I believe there must be one perfect for your needs.
The post walks you through the possible reasons and fixes for iPhone 11 stuck on Apple logo, from checking the basic hardware issues to an advanced iOS system recovery tool, AnyFix. If you can’t bother to store your data before updating via iTunes or a hard reset or something, then AnyFix is recommended for its versatile function for 150+ iOS system recovery issues without data loss. Go ahead and take action!
