iPad Won’t Download Apps? 8 Methods Here!
“Got an issue with a brand new, out of the box iPad that is running 17.2. When I attempt t download any app from the App Store, I hit get, it asks for my AppleID, I type it in, the circle spins for a second and then turns back to Get and the app didn’t download and install. This is happening for every app I have tried.” – An iPad user posted on Reddit.
Author Avatar Joy Taylor Last Updated: May. 14, 2024
It’s incredibly frustrating when your iPad won’t download apps, leaving you unable to access new tools, games, or updates. Many users have reported issues like “My iPad won’t download apps and just keeps spinning” or “The App Store says I have an update, but nothing happens when I try to download it.” If you’re experiencing similar problems, this guide is here to help. We’ll walk you through the common causes and provide step-by-step solutions to get your iPad downloading apps smoothly again.
Causes for iPad Won’t Download Apps
Several factors can prevent your iPad from downloading apps:
  • Insufficient Storage: New app downloads might be blocked if your iPad is running low on storage space.
  • Network Issues: A poor or unstable internet connection can disrupt app downloads.
  • App Store Server Problems: Sometimes, the issue might be with Apple’s servers rather than your device.
  • Outdated Software: Running an outdated version of iPadOS can cause compatibility issues with the App Store.
  • Payment Method Issues: The App Store requires a valid payment method, even for free apps.
  • System Glitches: Occasionally, minor software glitches can prevent downloads.
8 Ways to Fix iPad Won’t Download Apps
1. Add a Payment Method for App Download
Even if you’re downloading free apps, Apple requires a valid payment method on file. Here’s how to add or update your payment method:
  • Open Settings: Tap on the Settings app on your iPad.
  • Tap on Your Name: This will open your Apple ID settings.
  • Select ‘Payment & Shipping’: Here, you can add or update your payment method.
  • Add Payment Method: Follow the prompts to enter your payment details.
  • Save Changes: Ensure that your payment information is up to date and saved.
This should resolve any issues related to payment method errors preventing app downloads.
2. Spare Saving Storage on Your iPad
Lack of storage space can stop your iPad from downloading apps. To check and manage your storage:
  • Open Settings: Tap the Settings app.
  • Go to ‘General’: Scroll down and tap ‘General.’
  • Select ‘iPad Storage’: Here, you can see a breakdown of your storage usage.
  • Free Up Space: Delete unused apps, old photos, videos, and other large files. You can also offload apps, which keep their data while removing the app itself.
Ensuring you have enough storage space can help resume your app downloads.
3. Check Internet Connection
A stable internet connection is crucial for downloading apps. Here’s how to check your connection:
  • Check Wi-Fi: Ensure your iPad is connected to a Wi-Fi network. You can do this by going to Settings > Wi-Fi.
  • Test the Connection: Open a web browser and try loading a webpage. If it loads slowly or not at all, your connection might be the issue.
  • Switch Networks: If possible, try connecting to a different Wi-Fi network to see if the issue persists.
If your internet connection is stable, you should be able to download apps without any problems.
4. Check App Store Server Status
Sometimes, the issue isn’t with your iPad but with Apple’s servers. You can check the status of the App Store servers:
  • Visit Apple’s System Status Page: Go to Apple’s System Status page in a web browser.
  • Look for App Store: Check if there’s a green dot next to the App Store. A green dot means everything is working fine. If there’s a red or yellow dot, it indicates an issue.
If the App Store is down, you’ll need to wait until Apple resolves the issue.
5. Upgrade iPadOS
Running an outdated version of iPadOS can cause compatibility issues. To update your iPad:
  • Select ‘Software Update’: If an update is available, tap ‘Download and Install.’
  • Updating your iPadOS can resolve bugs and compatibility issues that might be preventing app downloads.
For some iOS update tips, you can refer to the following pages:
Unable to check for iOS update
iPhone stuck on verifying update
How long does it take to update iOS 17
6. Fix iPad System with AnyFix
Your iPad’s failure to download apps can be caused by some system-related problems and you can consider repairing iPadOS in this case. AnyFix iOS system repair is a tool designed to fix various iOS/iPadOS issues. Here’s how to use it:
Download and Install AnyFix on your computer.
Launch AnyFix: Open the tool and select ‘System Repair.’ Then use a USB cable to connect your iPad to your computer.
AnyFix System Repair Option
Follow Prompts: Choose the issue you’re facing and follow the on-screen instructions to fix it.
AnyFix System Repair App Issues
This tool can fix a wide range of system issues that might be preventing app downloads.
AnyFix Standard Repair
7. Download Apps for iPad on Computer
If you are urgent to download apps for iPad, you can also make the downloads on your computer. AnyTrans provides an easy way to download apps for iPhone or iPad on the computer. To download apps for iPad with AnyTrans, you can check the following steps.
Step 1. Download and install AnyTrans on your Windows or Mac computer.
Step 2. Launch AnyTrans and Use a USB cable to connect your iPad.
Step 3. Click App Downloader and download apps on the page.
Choose App Downloader and Search the App You Want
8. Contact Apple Support
If none of the above methods work, it might be time to contact Apple Support:
Visit Apple Support Website: Go to the Apple Support website.
Select Your Device: Choose iPad and describe your issue.
Follow Instructions: You can either chat with a support representative, schedule a call, or make an appointment at the Genius Bar.
Apple Support can provide further assistance and potentially fix any underlying hardware or software issues.
FAQs About iPad Won’t Download Apps
1. How do I fix an app not loading on my iPad?
To fix an app that’s not loading:
Force Quit the App: Swipe up from the bottom of the screen and pause slightly in the middle. Swipe up on the app’s preview to close it.
Restart Your iPad: Press and hold the top button and either volume button until the slider appears. Drag the slider to turn off your iPad. After the device turns off, press and hold the top button until you see the Apple logo.
Reinstall the App: Delete the app and reinstall it from the App Store.
2. Can I download apps on iPad without App Store?
While the App Store is the primary source for apps, there are alternatives:
Third-Party App Stores: Some third-party app stores offer apps not available on the App Store, but they come with security risks.
Enterprise Apps: If your iPad is managed by an organization, they might distribute apps directly.
TestFlight: Developers can distribute beta versions of apps using Apple’s TestFlight.
However, using the official App Store is recommended for security and reliability.
In summary, if your iPad won’t download apps, it could be due to various issues such as insufficient storage, internet connection problems, or software glitches. By following the steps outlined in this guide, including adding a valid payment method, freeing up storage, checking your internet connection, and updating iPadOS, you can resolve most issues. If the problem persists, tools like AnyFix or AnyTrans can provide further assistance. With these solutions, you should be able to download apps on your iPad without any trouble.
