When the keyboard on your iPad stops working, it simply means you can’t connect or share info with your contacts via text. Though this can be frustrating, you can fix it from the comfort of your home without damaging your device. This post will demonstrate the 10 ways to fix iPad keyboard not working issues, kindly check and apply the solution.
Hello, My iPad smart keyboard has been malfunctioning lately. It fails to respond to touch each time I try typing a text. I’ve browsed the internet for the best solution but none of the suggestions have yielded positive results. How do I fix the iPad keyboard not working? Please, help me with the appropriate solutions.
Apple smart phones have one of the best smart keyboards. The keyboards are nicely designed with smooth touch and other incredible functionalities. But recently, some end-users have discovered a number of issues with it. The majority report that the smart keyboard on their iPad isn’t responsive to touch each time they type a text. Other reports show that the iPad smart keyboard fails to connect or doesn’t work at all.
Regardless of how the issue occurred, you can still fix the iPad keyboard not working on your device. Our team in conjunction with other iOS experts have researched the best way to repair your iPad smart keyboard so you can enjoy your keyboard to the fullest. Keep reading, as we discuss the 10 simple techniques to fix iPad keyboard not working issues.
Apple smart devices, including iPad are well designed with all the features in proper order. So when you experience keyboard not working issues, it could likely be for the following reasons:
Broken screen, damaged flex, and unresponsive touchpad are all hardware issues that can cause your iPad smart keyboard to stop working. In this scenario, you have to visit a nearby Apple store to relay your complaint so you can get the best solution.
Do you run your iPhone on an outdated operating system or a beta version OS? If so, it is very much possible you experience iPad keyboard not working issues on your device. The best thing to do to fix your iPad is to install the most recent iOS. Better yet, you can fix your firmware package using a third-party software which will be introduced in the next section of this post.
As confirmed by Apple, the smart keyboard function is only available on specific iPad models. Some of them include:
If your iPad model doesn’t correspond/tally with the ones above, then smart keyboard won’t work. To check your iPad model, kindly follow the instructions below:
Checking for software updates is another handy solution to resolve iPad keyboard not working issues. With this solution, you can easily clear the bugs/temporary glitches distorting the operations of your keypad and also bring in the latest features that come with the update.
Here’s how to check and update your iPad to the most recent iPadOS:
Use Software Update
Are you using an external keyboard with your iPad and experiencing iPad keyboard not working issues? There’s a possibility that the keyboard connection port is faulty or has some strange objects, like dust, debris and more, in it. All you have to do in this scenario is to disconnect the keyboard from your iPad and check the ports for strange objects. Should you find any, please remove and clean the ports.
If your iPad keyboard still fails to work after applying the solutions above, you should try disconnecting, cleaning, and reconnecting the external keyboard again. This solution should help resolve the issue, so your smart keyboard can start functioning well in no time.
Are you still faced with iPad not working issues after implementing the solutions above? AnyFix iPad repair tool is what you need to bring your device back to normal. With this software, you can quickly fix any system related issues that’s causing your iPad to malfunction.
AnyFix handles more than 40+ iPad problems that you may come across on your device, from iPad/iPhone stuck on bootloop screen, to the green lines of death, frozen screen, and more. It’s also suitable for resolving iPad keyboard not working issues.
Step 1. Free download, install, and run AnyFix on your computer. From the home page window, select System Repair.
Tap on System Repair
Step 2. Connect the iPhone to your computer and select the 50+ iPhone Problems from the program window. Then click on the Start Now button to proceed.
Choose the 50+ iPhone Problem to Fix System Issue
Step 3. Choose the Standard Repair option from the program window and follow the screen instructions to put your iPad into recovery mode.
Choose Standard Repair in System Repair
Step 4. Confirm the device information and click on the Download button to download the device firmware package.
Download the Firmware
Step 5. Click on the Fix Now button to start the repair process. Wait till the process finishes and make sure that the device stays connected to your computer.
System Repair Completed
Another stress free solution to fix iPad keyboard not working on your device is a simple restart. When you reboot your iPad, the system automatically refreshes. All the glitches and bugs that are causing the device to malfunction are immediately cleared when you do this.
iPad restart is a very simple solution to execute. Follow these instructions to do this:
Restart Your iPad
Still experiencing keyboard not working issues on your iPad after restarting it? Then it’s time to reset your keyboard default mode. We suggest this solution since alteration in keyboard settings can cause the mentioned problem.
Just before discussing the procedure to follow, keyboard reset clears all the adjustments you’ve made on your device in the past. If you don’t mind losing these changes, follow the steps below to reset your iPad keyboard:
Reset the Keyboard Dictionary
Sometimes third-party keyboards can cause your iPad keyboard to malfunction. Installed keyboards can interfere with the operations of the built-in keyboard you have on your iPad. Deleting the additional keyboard is the only way forward to fix this.
You can use the instructional guide given down here to delete all third-party keyboards on your iPad right away:
Factory reset is another easy peasy solution you can use to resolve iPad keyboard not working on your device. With this solution, you can easily clear wrong settings you’ve made in the past plus delete conflicting apps that are causing your iPad to misbehave.
This solution helps you return your iPad to default mode for proper operation. To reset your iPad to factory/default settings, apply the steps below:
Reset iPad to Factory Settings
If your iPad keyboard still doesn’t work after implementing the aforementioned solutions, then the issue is a complicated one. There’s nothing you can do than visit the nearest Apple store around you to seek a solution.
With the solutions above, you can conveniently fix your iPad smart keyboard to start working. We have 9 basic solutions and the ultimate one- AnyFix. Our best bet is the one involving AnyFix. The software helps you clear iPad keyboard not working without damaging the system. Download, install and try it out. It’s worth your investment.
