If you still feel confused about why your iPad would be stuck on an update screen. You can read this post and get what are the reasons and get out of this issue with ease.
Keeping the iPad up to date ensures the device is functioning normally, and skipping an update may result in different types of software problems.
During the iOS 13 or iOS 14 update your iPad can get stuck at some stage of the process, either while you’re downloading the latest version of the iOS or during the installation. Sometimes being patient is the only thing you have to do, as the device may simply need more time than usual to install the system update.
However, if the iPad is stuck on the update screen for hours, it is a sure sign that something is wrong with it. So, in this article, we are going to help show you how to fix this.
It is vital to backup your data before you start a system update, because you may end up losing some of your files. Most of the time the installation process goes smoothly and quickly, but from time to time iPad can get stuck while updating the system. This can happen while the device is downloading and preparing for the update or during installation.
Apple’s servers can be overwhelmed after the launch of new versions of iOS 14, which is the reason why a download may take longer than expected. Just letting the device run an update at its own pace is the best course of action, and you should react only if your iPad gets stuck on an update screen for an unusually long period of time.
If your iPad is stuck in update mode, you don’t have to panic because there are plenty of simple solutions to this problem that take just a few moments of your time. Rarely, this issue can indicate that the iOS is corrupt, but even then restoring your device to normal shouldn’t be too difficult. Here’s what you can do to get an iPad unstuck from the update mode.
This is the first thing you should do if the device is stuck for too long on one of the system update steps. You can find instructions on how to restart an iPad. Once the device restarts, you should
Monitor closely how the update is progressing and if the iPad seems to be stuck.
You’ll need a stable internet connection to update the iPad’s system, so make sure that your device is connected to the Internet before you start the update. Moreover, it is recommended to use WiFi instead of cellular data because it is both faster and more stable.
Removing the update from the device and downloading it again may resolve the iPad stuck on the update screen problem. Here’s how you can do that.
Step 1: Launch the Settings app, expand the General menu, and tap on iPad storage. Find the update file you want to delete and tap on it.
Step 2: You should then tap on the Delete Update option and proceed to confirm that you want to remove the file from the device.
Step 3: Restart your iPad, return to the Settings app, open the General menu, and start a new system update from the Software Update window.
Alternatively, you can activate the Airplane mode instead of restarting the device, although it is better to reboot your iPad after you delete the system update file.
Mac and PC owners who are using iTunes can use this app to restore your iPad after it gets stuck in update mode. You can find all steps you’ll need to take in order to complete this process at Apple’s customer support.
A system update can take longer than usual if the iPad’s battery is low. So you can either recharge the device before the update or you can connect it to the charger and then run the update. Although this may not resolve more complex issues with the update, it will ensure that the device’s power level is above critical.
Connecting the iPad to the charger is particularly important for large updates that take a long time to complete because it will ensure that the device’s battery is not going to be depleted.
Launching the DFU mode is only necessary if your iPad is stuck in the update mode for more than six hours, which happens rarely. The process is a bit technical and you must connect the device to a Mac computer in order to pull this off.
iPad stuck on an update screen is quite annoying. But you don’t have to panic if you can fix it by the methods mentioned above. Some still stuck on the trouble even have tried all these methods. Here we recommend an extraordinary troubleshooter to help you get out of this issue. AnyFix – iOS System Recovery, as a system recovery tool can help you to return your iPad back to normal in just several easy steps.
Step 1: Download and launch AnyFix on your computer > choose the System Repair option.
How to Fix iOS System Issues with AnyFix
Step 2: Tick 40+ iPad Problems option > click Start Now button.
Choose iPad Problems and Start Now
Step 3: Choose Standard Repair from the three modes AnyFix provides > click Standard Repair button.
Choose Standard Repair Mode
Step 4: Wait for a moment until AnyFix finished its repair journey.
System Repair Completed
After AnyFix completes the system repair process, you should attempt to install the system update again. AnyFix – iOS System Recovery can solve most iPad iPhone system issues. It supports so many professional methods to get off iTunes problems. Also, you can use AnyFix – iOS System Recovery to upgrade or download your iPad to whatever iOS version you want directly. All you need to do is to follow the intuition on the tool to update/downgrade your iPad, even iOS 14 is supported.
Choose Upgrade/Downgrade iOS
Getting to the bottom of the iPad stuck on the update screen issue, doesn’t take a lot of effort, because the problem is most likely caused by an unstable internet connection, depleted battery, or a corrupted system update file. We hope that after reading this article your iPad is no longer stuck on the update screen. Leave a comment and lets us know.
