This article provides effective solutions for the iOS 18 stuck on Apple logo issue. It offers various methods like force restarting, using AnyFix, and restoring with iTunes or DFU Mode. It guides you through each step to fix your iPhone and get it back to normal. So, it ensures you can enjoy iOS 18 without any glitches.
Have you ever faced the dreaded iOS 18 stuck on Apple logo issue after an update? It’s a scenario many iPhone users encounter. Imagine eagerly waiting to try out the new features of iOS 18, only to be met with a frozen screen. This article is your guide to tackling this exact problem. We’ll discuss the reasons behind this issue and provide you with several proven fixes.
Whether it’s a quick force restart, using the innovative AnyFix tool, or restoring your device with iTunes or DFU Mode, we’ve got all the solutions lined up for you. Keep reading to learn how to resolve this common yet fixable issue!
iOS 18 getting stuck on the Apple logo can be a frustrating experience. This might happen for several reasons:
In short, these above issues can cause iOS 18 stuck on apple logo. Until now, you know the causes of the issue. Let’s fix this issue in our next discussion!
If your iPhone device gets stuck on the Apple logo during the iOS 18 update, there’s no need to worry. Follow the below practical fixes to resolve this issue.
It is one of the simplest methods to resolve this issue. However, it won’t fix this issue in most cases. If your iOS 18 stuck on Apple logo, try force restarting your iPhone.
Steps to Force Restart iPhone 8 or later:
Steps to Force Restart iPhone 7/7:
Steps to Force Restart iPhone 5/SE/6:
Force Restart iPhone to Fix iPhone Not Responding to Touch or Screen Frozen
To fix the iOS 18 stuck on Apple logo issue without losing data, you can use a smart tool: AnyFix – iOS System Recovery. It is a helpful software tool designed to solve a range of iOS system issues. It works well for 150+ iOS problems like an iOS 18 stuck on the Apple logo, stuck in recovery mode, frozen screen, black screen, etc. This tool is user-friendly and efficient, making it a good choice for those who aren’t tech experts. You can learn more about it below.
Now, download and install AnyFix on your computer. Here’s how to use AnyFix to fix your device:
Step 1. Open AnyFinx on your computer and choose the System Repair mode.
AnyFix System Repair Option
Step 2. Then select Screen Stuck and then click the Start Now Button.
Step 3. You can select a mode to repair your iOS device. We recommend you select the Standard Repair option first.
AnyFix Standard Repair
Step 4. After clicking the standard repair button, you will see the below interface. Click on the Download button.
Step 5. Then, it will start to repair your iOS device. When it is completed, you can see the screen below.
Repair Is Completed
Now, let’s move on to the next solution to address the iOS 18 stuck on Apple logo problem.
If other methods don’t work, try restoring your iPhone with iTunes in Recovery Mode. This is a simple process. Just connect your iPhone to iTunes. Then, iTunes will install the new iOS system on your phone. The below steps will help you restore your iPhone with iTunes in Recovery Mode.
Step 1. Connect your iPhone to your personal computer and open iTunes.
Step 2. Get your iPhone into recovery mode. Check Apple’s support for steps on this.
Step 3. iTunes will ask whether you want to update or restore your iPhone. Choose ‘Restore’.
Tap on Restore to Proceed
Step 4. Follow the steps on your screen to complete the restore process.
Step 5. Once done, set up your iPhone as new or use a backup to restore it.
Remember, use this method only if nothing else works. It will delete all your data. Always back up your iPhone before trying this when dealing with the iOS 18 stuck on Apple logo issue. Let’s try another solution!
Checking the Apple Server Status is a crucial step in resolving the iOS 18 stuck on Apple logo issue. Sometimes, the problem isn’t with your device but with Apple’s servers. During an iOS update, if Apple’s servers are down or overloaded, it can cause issues like your iPhone getting stuck. Follow the below steps to check the Apple server status:
Step 1. Visit the Apple System Status website.
Step 2. Look for any indicators showing issues with iOS updates or related services.
Step 3. If there’s a problem on Apple’s end, wait until it’s resolved before trying the update again.
Check Your Apple Server Status
This step ensures that the issue is not due to external factors beyond your control. And it can save you time in troubleshooting your device.
If Recovery Mode fails, try DFU Mode (Device Firmware Update). It can fix the iPhone stuck on the Apple logo by doing a factory reset. But, like Recovery Mode, DFU Mode might erase your data. Use it if you’re okay with this risk. The following steps will help you to enter into DFU mode effortlessly.
Step 1: Connect Your Computer to iPhone and Open iTunes.
Step 2: Follow the method mentioned below to enter Recovery mode to restore your iPhone by using iTunes. For different iPhone models, here’s how to enter DFU Mode:
Put Different iPhone Model into DFU Mode
Q1. How do I unlock my iPhone if it’s stuck on the Apple logo?
To unlock your iPhone stuck on the Apply logo, you can try different methods. First of all, you can force reset your phone. Secondly, you can use AnyFix to resolve the system issue. Thirdly, you can restore your iPhone with iTunes or enter into DFU mode. Lastly, you can also check the server status to get rid of this issue. All these methods are effective and will help you to regain complete access to your iPhone.
Q2. How long does the iOS 18 update take?
The time to update to iOS 18 can range from 5 to 30 minutes. This duration depends on the update’s size and your internet speed. A slower internet connection might extend the time needed to complete the iOS 18 update.
In summary, if you’re facing the iOS 18 stuck on Apple logo issue, there’s no need to panic. Start with a simple restart of your iPhone. If that doesn’t work, try AnyFix to solve the problem without losing your data. Alternatively, you can restore your iPhone with iTunes or enter DFU Mode for a deeper fix. Remember, backing up your data is important before you begin. These steps are effective and can get your iPhone back to normal. With patience and the right method, you’ll overcome this issue. And enjoy your iPhone’s features again.
