In this article, you are going to explore the reasons for the iOS 17 alarm not working issue. You will also discover various solutions with their step-by-step guides to grasp the concept and perform it. Moreover, to enhance your smartphone experience, we will introduce you to an amazing tool.
iOS 17 Alarm Not Working%? How to Fix? Free download AnyFix to fix iOS 17 Alarm Not Working with 1-click! AnyFix is your one-stop solution to fix various iOS/iPadOS/tvOS/iTunes issues in minutes and bring your Apple devices back to normal without data loss.
Is the iOS 17 alarm playing hide-and-seek with your mornings? Is your trusty iPhone not as reliable as your old-school alarm clock? Well, you are not alone!
Many iPhone users reported the issue related to the iOS 17 alarm not working. Some say it doesn’t ring. Some say it doesn’t go off. While some users say it doesn’t ring again after they press snooze. This can be frustrating, especially if you rely on alarms to get up for work or school. But don’t worry!
This article will walk you through some of the most common fixes for this issue. We will also explore their step-by-step guides.
Also Read: How to Fix iPhone Overheating While Charging
There could be various reasons for your iOS 17 alarm not working. Whenever a new iOS update launches, the bugs it might have can cause problems like this one. Moreover, it can also happen due to software glitches, incorrect settings, and hardware problems. Let’s shed some light on the most common reasons.
iOS Alarm Settings
Now that we know what can be the causes of the iOS 17 alarm not working, let’s dive into their solutions. In the following sections, we will explore various methods to fix this issue.
Before jumping to the real solution, try these regular ways that might fix the iOS 17 alarm not working issue. These methods are easy to follow and can be done by anyone. Let’s explore them together!
The first step in fixing the iOS 17 alarm not working issue is to check your alarm settings. You need to make sure that they are correct. Due to updates in iOS, the alarm settings can be changed or get wrong. It can happen due to software glitches or bugs that come with the launch of a new software version. You can follow the guidelines given below:
iOS Alarm Settings
If you have checked the alarm settings and they are correct, there must be some other issue. You can try the next fix.
Sometimes, the reason behind your iOS 17 alarm not working can be a simple setting that is out of place. So, to solve the issue, you can walk through the relevant settings and ensure that they are correct. Don’t know how? You can follow the instructions given with each setting option.
Ensure the volume is full and the toggle is enabled
Reset the schedule in do not disturb mode
Check alarm type and repeat settings
Select the appropriate sound
By adjusting these settings, you can often resolve the iOS 17 alarm not working issues. However, if you are still facing the issue, don’t worry! We have more solutions to explore in the upcoming sections of this article. Let’s continue!
If your iPhone alarms are still failing to cooperate, maybe it’s time to reset them. Creating new alarms from scratch can often resolve any issues with existing alarms. Here’s how you can create new alarms on your iOS device:
Step 1: Open the “Clock” app on your iOS device.
Step 2: Tap the “Alarm” tab to view your existing alarms.
Step 3: Remove all the existing alarms by tapping “Edit” in the upper left corner. Then, select the red minus button next to each alarm. Confirm the deletion.
Step 4: Once all alarms are deleted, exit the “Clock” app.
Step 5: Open the “Clock” app and tap “Alarm.” Then tap the “+” icon to create a new alarm. Set the time, repeat options, and sound as desired.
Create new alarms
If your alarms still aren’t working as expected, don’t worry. We have a few more tricks to ensure your iPhone alarm is back to being your reliable morning wake-up call.
If you are still facing an iOS 17 alarm not working problem, it’s time to consider an advanced option. Resetting all settings on your iPhone can help address any hidden issues that may be affecting your alarms. But remember, it can revert various settings of your iPhone to default. However, it won’t erase your personal data.
Click transfer or reset iPhone.
Select Reset All Settings
This process will resolve any software glitches or settings issues that are affecting your alarms. However, it’s essential to back up your important data before performing a reset.
If your iPhone alarm problems persist, don’t worry! We have more fixes to explore in the upcoming sections.
Sometimes, a simple restart can clear temporary issues and get your iPhone back on track. It’s a quick and easy fix that’s often overlooked. So, you can also resolve the iOS 17 alarm not working issue by restarting your device. Let’s see how:
If your alarms are still giving you trouble, don’t worry! We have more solutions to explore.
Updating your iPhone’s software can resolve many issues and bugs, including those related to alarms. So, keeping your device up to date ensures that you have the latest fixes and improvements. However, if you don’t know how to update your iPhone’s software, you can follow the below steps:
Step 1: Go to “Settings” on your iPhone. Then, scroll down and “General.”
Step 2: Now click “Software Update” to check for available updates.
Step 3: If an update is available, click “Update Now” and follow the on-screen instructions to download and install it.
Update your iPhone
If, even after updating your device, the iOS 17 alarm not working issue exists, then we have got you the last resort. Let us introduce you to a tool that will fix the issue hassle-free. You can also go for it without performing the above fixes.
Sometimes, a problem in the system software of your Apple device can cause the alarm not to work properly. However, the good news is that you can fix the alarm by fixing the iOS system issues. Wondering how? Well, we have got you an amazing solution –iOS repair utility- AnyFix! It is a reliable and effective tool for all your iOS-related issues.
Now, you don’t have to rely on manual and daunting steps to fix the iOS 17 alarm not working issue. With AnyFix, you can get the job done in just a few clicks. Moreover, you can also solve issues like the iPhone won’t charge, won’t turn on, stuck on the lock screen, and many more. The best part? Its user-friendly interface won’t require any technical skills to use AnyFix.
Step 1. Free get AnyFix and launch it on your PC/Mac. Select the System Repair mode.
Tap on System Repair
Step 2. Connect the faulty iPhone with a reliable USB cable and wait for it to be detected by AnyFix. Click the green Start Now button.
Choose iPhone Problems and Start Now
Step 3. Then, AnyFix will direct you to another interface with three repair modes. Kindly click Standard Repair.
Choose the Standard Repair to Fix QuickStart Not Working via AnyFix
Step 4. AnyFix will provide you with the firmware of your iOS device. Click the “Download” button to download your device’s firmware package.
Download a Matching Firmware for your Device
Step 5. After the firmware package for your iOS device is downloaded successfully, you will see the below interface. Click the “Fix Now” button.
Tap on Fix Now when Firmware Downloaded
Step 6. Now, AnyFix will start repairing your iPhone. It is suggested not to disconnect your iPhone until it restarts. Once the repair process is completed, you will see the below interface.
Repair Completed Page
Did you see it? How easy and efficient it is to use this tool. After fixing the system issues with AnyFix, we are pretty sure that the iOS 17 alarm not working issue will be resolved.
Your iPhone alarm should be your reliable wake-up call, not a source of frustration. However, since iOS 17 launched, it has been acting up, causing troubles in users’ daily routines. Understanding the concern, we have shown you simple fixes to ensure it’s dependable.
In this article, we have explored various methods with their easily-to-follow guides to fix the iOS 17 alarm not working issue. But if you want a convenient way to do it, just free try AnyFix! It is a complete toolkit for all your iOS-related issues. Now, you don’t have to rely on operators. You have the solution at your fingertips.
