iOS 16 Photo Cutout Not Working? We have concluded the top 8 proven ways of fixing the bug so you can try effortless picture cropping.
iOS 16 for iPhones and iPads has just been released, and users can not stop waxing lyrics about all the new changes. The new iOS is introduced with some jaw-dropping features, including the wildly talked about- Photo Cutout feature. Cropping images has always been a challenge for you? Then Photo cutout is definitely going to be a lifesaver.
Whether you are unaware of this really cool feature or the iOS 16 photo cutout not working on your devices, this article will guide you and offer some quick ways to troubleshoot the problem. So without further ado, let’s dig in!
And here are some other tips about the new iOS you may like:
So if you are illiterate about this impressive feature and haven’t already joined the bandwagon to sing praises about the Photos Cutout, then we bet you will after learning about it.
The iOS 16 Photo Cutout feature allows users to crop a particular object or remove the background from images. Unlike Photoshop, you don’t have to be precise with the borders; instead, tap and press on the object to lift it from the background and share or cut-paste on a new background. The image can be directly shared with any app that supports images (Whatsapp, iMessage, Instagram, etc.). The feature works on all iPhone models from iPhone XS and XR onwards but works better with high-resolution Portrait images.
Doesn’t the Photo Cutout feature make photo cropping and sharing so effortless? However, some users face problems with it and they cannot use it on their devices. In case of iOS 16 photo cutout not working, here are the top 8 handy ways to fix it.
The photo cutout feature in iOS 16 is only compatible with specific file formats, and thus it is crucial to choose the correct one to make it work. Additionally, the feature is only compatible with applications that support images. (i.e., Pictures, Mail, iMessage, Safari, etc.)
If you have been facing an issue, ensure that the feature supports the image format. Here are the file formats compatible with iOS 16 photo cutout:
To check the format, swipe up and view it in the Digital camera data. If you used the wrong format, try the feature with another image. However, if the problem continues, there are other ways to fix the problem.
It might not be very reassuring to hear, but the Photo Cutout feature is not available on all iOS 16 devices. According to Apple’s guide on iOS 16, the feature requires complex AI processing and background images which is only currently possible with devices with an A12 Bionic chip or higher.
This limits the feature to several iPhone models, which include:
Note that although the iPhone 8 and iPhone X do support iOS 16, due to the lack of an A12 bionic chip. If you are using these or any other model that has a chip lower than A12 is the reason why the Photo Cutout feature is not working for you.
Still could not use the Photo cutout feature on your device? A probable reason can be glitches in the software, a botched-up backup, or a bug that obstructs the normal functioning of the iOS 16 features.
Bugs are common in tech devices, and fixing them isn’t so fussy until you have got a great bug-fix app like AnyFix – iOS System Recovery. The application is an all-in-one solution to fix bugs for all Apple devices and restore normal functions without any data loss. Here are some of its amazing features:
What’s more, AnyFix can also help you solve iTunes problems such as iTunes won’t sync with iPhone, iPhone not showing up in iTunes, etc. If you have any problems with your device, just download AnyFix and give it a try.
Here is how to use the application to fix the iOS 16 Photo Cutout Not Working Issue:
Open AnyFix on your PC. Select the System Repair option and connect your iPhone to the computer via a USB cable.
Choose System Repair on the Homepage
Once the device is connected, a new window shows a list of possible problems you might be encountering. Proceed by clicking on 50+ iPhone Problems option and then the Start Now button.
Select iPhone Problems
Currently, the application has three repair modes to offer. To fix our iOS 16 Photo Cutout not working issue select Standard Repair. Follow the instructions on the screen to enter Recovery mode. Check for the device info and click on the Download button to get the firmware.
Choose Standard Repair Mode
Next, click the Fix Now button to repair the problem on your iOS device. Keep the device connected until the repair process runs.
Repair Completed
Repairing and restoring your device’s normal function and enabling the Photo Cutout feature with AnyFix is as effortless as it looks.
The Photo Cutout feature is an extension of the Visual Look Up feature that was introduced in iOS 15. The Visual Look Up feature recognizes objects in pictures and automatically offers information on landmarks. Since Photo cutout is part of the Visual Look Up, the latter must be enabled. Here are steps:
Open the Settings app on your iPhone> Select Siri and Search option> Turn on the following toggles:
Enable Visual LookUp
Now try the Crop feature again, but if it still doesn’t work, then continue with other ways to troubleshoot it.
Sometimes, enabling or disabling a particular setting can make the Photo cutout feature not work. Therefore, we recommend erasing all your settings and setting them again. If anything were bugging the functionality of the feature, resetting would fix it. Here is how to do it.
Step 1. Find and lanuch Settings on your device.
Step 2. Scroll down to choose the General option on the screen. Then, click on Transfer or Reset.
Step 3. You will see Reset option. Choose it and then tap on the Reset All Settings button.
Click on Reset All Settings
This will reset all the phone settings to default. If a certain setting disabled the photo cutout effect, then it will troubleshoot the problem. And don’t forget to set up your iPhone again.
Now, it’s time to take some more extreme measures and reset your entire device to the Factory version. Resetting the phone to default allows it to reconfigure all the settings that might be hindering the Photo cutout feature.
Note that the factory version erases all the data on the device; therefore, we recommend backing up all the data before proceeding. To reset the device to the factory version, follow the steps:
Choose Erase All Content and Settings
Generally, restoring the phone to the Factory helps clear all the bugs, so the phone works smoothly. However, if the issue persists, we still have got some options.
If resetting the phone setting and restoring the factory version did not enable the Photo cutout feature, then a probable cause can be the bug with the iOS 16 software. You can restore your device with an IPSW by entering recovery mode and reinstalling it to fix issues.
IPSW is an iOS file format directly downloaded from Apple that helps you install fresh iOS 16 software on the device. Usually, reinstalling the software fixes issues that may have arisen due to previous backups or syncing with the iCloud.
Once you have reinstalled the software, unlock your phone and try the Cutout feature. If it works perfectly, there was a bug in the software that would have been fixed by reinstalling the iOS 16 software. But if there is still no success, we need to move to our final method!
Don’t know hwo to install IPSW? Just read: How to Install IPSW with/without iTunes >
As the final resort, report the issue to the Apple support team when everything seems to unwork for you. The issue might be more specific to your device, and the Support team will be able to locate and help you fix it. To get in touch with the Apple Support Team, reach out to their website and start a request online or contact them via worldwide support telephone numbers.
Photo Cutout is an incredible cropping feature introduced into iOS 16. If you haven’t already tried out the feature, you must do it and see how it simplifies picture cropping. Some users have reported iOS 16 Photo Cutout not working on their devices, so we have concluded the top 8 handy proven ways of fixing the issue.
Instead of going for complex ways, we recommend you download and use AnyFix, which offers effortless bug fixing in no time at all. It can fix almost all types of iOS-related problems.
