iPhone Screen Zoomed in Stuck? How to Unzoom iPhone
If iPhone screen zoomed in stuck, how to disable the zoom feature to bring it back to the normal mode? Read this post and try the proven ways to fix this issue and zoom out on iPhone quickly.
Author Avatar Joy Taylor Last Updated: Jul. 25, 2024
Your iPhone comes loaded with many features that you can hardly use all of them. One of these features is zoom. This feature allows you to enlarge the icons and other elements on your iPhone’s screen. If you are someone with vision problems, you might appreciate this feature as it lets you easily read the content on your screen.
Sometimes when you enable the mode, your iPhone gets stuck in the zoom mode. If this is the case with you, you will find that your iPhone’s icons always remain larger than the normal mode. This becomes annoying if you are not used to seeing large icons.
Luckily, there are some ways to fix iPhone screen zoomed in stuck and bring the icons back to their normal size. The following methods will help you do that.
Also Read: What Does Deliver Quietly Mean on iPhone >
Why iPhone Screen Zoomed in Stuck
Why is my iPhone zoomed in and get stuck? This could happen due to various reasons and the following are some of the possible ones.
Reason 1. Zoom Mode is Enabled
One of the reasons why your iPhone shows zoomed icons is that you have the zoom mode feature enabled on your device. If you did not turn it off or if someone else turned it on after you disabled it, this scenario could appear.
Reason 2. Minor Software Glitch
Another possible reason for iPhone zoomed in stuck is that there is a minor glitch in the software of your device. This usually happens when one of the core files is altered.
Reason 3. Issues with the System Software
If your iPhone’s operating system has any issues, that can also cause iPhone screen zoomed in stuck. This is a more serious issue and you need to fix it as soon as you can to avoid any other errors on your phone.
6 Tips for iPhone Screen Zoomed in Stuck
If iPhone zoomed in too much and you cannot tolerate those large icons even for one more second, you will want to disable them and bring your iPhone back to the normal mode. Then, the following methods will help you fix iPhone screen zoomed in stuck.
Tip 1. How to Zoom out in iPhone with Three Fingers
The easiest way to fix the stuck issue on your iPhone is to turn off zoom mode. Once you have disabled this feature on your iPhone, your iPhone will show the normal sized icons. Your icons will no longer be magnified.
The easiest way to exit zoom mode on your iPhone is to use a touch-screen gesture. You basically need to use three of your fingers to get out of zoom mode on your phone.
On your iPhone’s screen, double-tap with three fingers and this will zoom out your screen. Your icons should now be back to the original size.
Tap Three Fingers to Zoom Out
Tip 2. Turn off Zoom on iPhone in Settings
Zoom is actually an accessibility feature on your iPhone and you can enable and disable it at any time from the Settings app. If you do not wish to use the feature because iPhone zoom stuck or if you simply prefer smaller icons, you can head into the settings menu and disable this feature.
If you ever need the feature back on your device, you can do that by enabling the toggle for the feature in the settings menu. Here is how to turn off zoom on iPhone.
Step 1. Launch the Settings app from the springboard on your iPhone.
Step 2. Tap on the option that says General and then select the Accessibility option.
Step 3. You will find several accessibility options on your screen. Tap on the one that says Zoom.
Step 4. Turn off the first toggle that says Zoom to disable the zoom mode on your iPhone.
Disable Zoom on iPhone
Your iPhone will immediately start using the normal icons.
Tip 3. Disable Zoom Mode with iTunes or Finder
If iPhone zoomed in lock screen and iPhone screen is too large to unlock, then you may not access the Settings app to zoom out. Then, you can turn off zoom mode using the Finder or iTunes app as well on your computer. These apps offer you the option to disable the zoom mode feature on your iOS devices right from your computer.
All you basically need to do is plug your iPhone into your computer and change an option in the Finder or iTunes app. It will disable the zoom mode and bring your icons back to their normal size.
Follow the steps below to see how to zoom out on iPhone via iTunes/Finder.
Step 1. Launch either Finder or iTunes on your computer.
Step 2. Connect your iPhone to your computer using the original USB cable.
Step 3. Make sure you are in the General tab. Then, click on the button that says Configure Accessibility to change your iPhone’s accessibility options.
View Accessibility Options in Finder
Step 4. Untick the box for Zoom and then click on the button that says OK.
Disable Zoom Using Finder
Zoom mode should now be disabled on your iPhone.
Tip 4. How to Unzoom iPhone via Reboot
How do I unzoom my iPhone screen? You can fix iPhone screen zoomed in stuck by rebooting the iPhone. Rebooting basically resets the temporary settings and files on your device. If there is a minor glitch in your iPhone’s software, this could fix that for you.
Rebooting all models of the iPhone is pretty easy and you can do that as follows.
Reboot an iPhone X or 11
Step 1. Press and hold down either Volume Up or Volume Down and the Side buttons at the same time.
Restart iPhone X or Later Models
Step 2. Drag the slider and allow your iPhone to turn off.
Step 3. Press and hold down the Side button to turn on your iPhone.
Reboot an iPhone SE (2nd generation), 8, 7, or 6
Step 1. Press and hold down the Side button.
Step 2. Drag the slider to power off your phone.
Step 3. Press and hold down the Side button to power on your iPhone.
Reboot an iPhone SE (1st generation), 5, or earlier
Step 1. Press and hold down the Top button.
Step 2. Drag the slider to turn off your phone.
Step 3. Press and hold the Top button to turn on your phone.
Restart iPhone 8 or Earlier Models
Tip 5. Fix iPhone Screen Zoomed in Stuck when Facing System Errors
As explained earlier, one of the reasons why iPhone screen zoomed in stuck is that there is an issue with your phone’s system. Sometimes the core files in your phone’s operating system get modified and this can cause your phone to malfunction.
One of the ways to get around the issue is to use a tool like AnyFix – iOS System Recovery to fix your device. AnyFix is an app that allows you to fix many issues on your iOS-based devices, like iPhone zoom stuck, stuck in recovery mode, frozen screen, black screen, stuck on Apple logo, etc. It offers you 3 repair modes to choose and you can even fix the system without data loss. All you need to do is click the buttons. No skills are required.
AnyFix now supports all iPhone models and iOS versions, like iPhone 15/14/13, iOS 17/16, etc. So just follow the steps below to fix iPhone screen zoomed in stuck via this tool.
Step 1. Grab the latest version of the AnyFix and install it on your Windows or Mac computer.
Step 2. Connect your iPhone to your computer and click on System Repair in the app.
AnyFix System Repair Option
Step 3. Hit Start Now on the following screen to begin fixing your iPhone.
Step 4. Choose one of the modes to repair your iPhone and continue.
AnyFix Standard Repair
Step 5. Then you need to download a matching firmware. Follow the on-screen instructions and your iPhone will be fixed in no time. You will then see Repair Completed page on your screen.
Repair Is Completed
Repair Is Completed
That is all there is to fixing almost all the issues on your iPhone using a third-party tool.
Tip 6. Fix iPhone Screen Zoomed in Stuck via Resetting All Settings
An improperly configured settings option can also cause iPhone screen zoomed in stuck. To fix this, you can reset all settings on your iPhone.
Step 1. Head to Settings > General > Reset on your iPhone.
Step 2. Select the Reset All Settings option.
Reset All Settings on iPhone
Your iPhone should no longer be stuck on the zoomed-in screen.
If iPhone screen zoomed in stuck and you cannot find a way to fix it, the above guide will help you out. It shows several ways to bring your iPhone’s icons back to the normal size. And if iPhone stuck on zoon mode because of system issues, AnyFix will help you with simple steps. And now you can get the latest version of AnyFix and try these features. Also, if you got any questions, feel free to leave your comments below.
