How to Fix iPhone Stuck in Headphone Mode
“My iPhone is stuck in headphone mode. I hadn’t used the headphones before this happened. I’ve tried cleaning out the jack with a match and plugging the headphones in and out several times whilst watching a video. Neither worked.” An iPhone user posted in the discussion.
Author Avatar Joy Taylor Last Updated: Mar. 13, 2024
AnyFix – Get iPhone Out of Headphone Mode
Download AnyFix to detect and fix iPhone stuck in headphone mode. No data loss. No technical skills required.
If an iPhone stuck in headphone mode, you can’t hear any sound after playing an audio on it. It happens when you connect with your headphones and then disconnect. Your iPhone didn’t run the normal mode without the headphones. Here we are discussing why iPhone stuck in headphone mode and how to fix it in 8 ways.
Why is My iPhone Stuck in Headphone Mode?
Software Glitches: One of the reasons why your iPhone is stuck in headphone mode is because there is an issue with the software of your device. There may be a glitch somewhere in the software that is causing your iPhone to think your headphones are connected to it.
Damaged Headphone Port: Another possible reason could be that your headphone port is full of debris or dust and this is making your iPhone believe your headphones are connected to it.
iOS Mode Stuck: When your iPhone gets iOS system mode stuck, it can be stuck in headphone mode or SOS mode.
Now that you are aware of the possible reasons why your iPhone could get stuck in headphone mode, the following are some of the fixes you can apply to get rid of the issue from your iPhone.
Method 1. Fix iPhone Stuck in Headphone Mode with AnyFix
As we mentioned above, your iPhone may stuck in headphone mode due to iOS system mode stuck. If this is the case, it’s better to fix this issue with an iOS system recovery tool. AnyFix is a powerful program to get your iPhone out of headphone mode quickly and securely. With just easy steps, AnyFix can help check and resolve iPhone stuck in headphone mode.
How to Fix iPhone stuck in headphone mode with AnyFix:
Step 1. Download and install AnyFix on your computer.
Step 2. Launch AnyFix, then select System Repair mode to help you address iPhone-related issues.
AnyFix Main Screen
AnyFix Main Screen
Step 2. Connect your iPhone to the computer and tap on iOS Mode Stuck under the interface of System Repair. You can find that the common iPhone issues are listed on the right side. Then click Start Now to repair your iPhone problem.
AnyFix System Repair iOS Mode Stuck
Step 3. Then you will see three repair modes. Choose Standard mode to get your iPhone repaired. It will not case data loss on your iPhone.
AnyFix Standard Repair
Step 4. Then AnyFix will check your iPhone model and download the firmware.
Step 5. Once the firmware is prepared, you can click Fix Now to get your iPhone out of the dilemma. Then this tool will automatically start repairing as below.
Repairing the System
Step 6. Take a few minutes, you will see the following Completed Page.
System Repair Completed
After repairing, your iPhone is supposed to play audio normally without being stuck in headphone mode.
Method 2. Connect and Disconnect Your Headphones
Besides repairing the iOS system to fix iPhone stuck in headphone mode, there are some other ways you can try to resolve the problem. One of the basic things you can do to fix the issue is to connect your headphones to your iPhone and then quickly disconnect them.
When you connect your headphones, your iPhone will remain in the headphone mode. However, when you disconnect your headphones, you will find that your iPhone now gets out of the headphone mode. This may fix the issue for you.
Method 3. Toggle the Airplane Mode on Your iPhone
Another thing you can do is to enable the airplane mode and then disable it. This should work to fix an iPhone that is stuck in the headphone mode.
Step 1. Swipe up from the bottom of your iPhone to open Control Center.
Step 2. Tap on the icon for airplane mode and the mode will be activated.
Enable Airplane Mode on Your iPhone
Step 3. Wait for about a minute and then disable the airplane mode.
You will find your iPhone is no longer stuck in headphone mode.
Method 4. Restart Your iPhone
Restarting your iPhone can fix many minor issues on it and this is pretty easy to do. Most likely, this should fix the issue for you as rebooting the iPhone refreshes all the audio sources on it.
Step 1. Press the Power button for a few seconds on your iPhone.
Step 2. Drag the slider to turn off your iPhone.
Reboot Your iPhone
Reboot Your iPhone
Step 3. Press the Power button again for a few seconds and your iPhone will turn on.
The headphone mode issue should now be resolved on your device.
Method 5. Clean the Headphone Port to Get Rid of Dust
If your headphone port has not been cleaned for a long time, it is time you clean it as the debris inside may be causing your iPhone to believe your headphones are connected to it.
Get a clean cloth and use it to gently wipe the headphone port on your iPhone.
Method 6. Remove Your iPhone Case
Some of the third-party iPhone cases are not fully compatible with the iPhone. You may want to try removing your case and then see if your iPhone is still in headphone mode.
Remove the Case from Your iPhone
If yours is a cheap case and removing it brings your iPhone out of headphone mode, you need to get rid of that case and get a new and compatible one for your device.
Method 7. Connect to a Bluetooth Speaker
There is a workaround where connecting to a Bluetooth speaker helps fix an iPhone that is stuck in headphone mode. You will need a Bluetooth speaker to do this method.
Step 1. Go to Settings > Bluetooth and connect to your Bluetooth speaker.
Turn on Bluetooth from Settings
Step 2. Play a music file on your iPhone and let the audio come through your Bluetooth speaker.
Step 3. While the music is still playing, disable Bluetooth on your iPhone.
Your iPhone will then come out of headphone mode and your issue should be fixed.
Method 8. Reset Your iPhone Settings
Lastly, you can reset all settings on your iPhone to fix the headphone mode issue. This will then require you to reconfigure the settings on your iPhone.
Step 1. Open the Settings app on your iPhone.
Step 2. Tap on General and then tap on Reset.
Access iPhone Reset Settings
Step 3. Select the Reset All Settings option to reset all settings on your iPhone.
Reset all the settings on the iPhone
When the settings are reset, your iPhone will be out of the headphone mode.
iPhone stuck in headphone mode is not a severe problem, but it can be troublesome when you need to make iPhone audio public. The above parts have listed 8 proven ways to fix iPhone stuck in headphone mode. If the general ways cannot fix the issue on your iPhone, AnyFix is recommended to help you out. It will fix multiple iOS mode stuck issues such as iPhone stuck in lock screen, iPad stuck on update screen, etc. Download AnyFix to get rid of iPhone system issues now.
