If restore from iCloud backup stuck, you cannot get iCloud backup data back to your iPhone. This post focuses on how you can fix restore in progress iPhone stuck and get your data to be successfully restored on your iOS device.
My iPhone 14 Pro Max is stuck in restore progress: The restore in progress has been taking for 18 hours, stuck on 100 MB, over 30 GB of storage available on my new iPhone 14 Pro Max; how do I get it to finish setting up?
Whenever you got a new iPhone, you need to restore iPhone backup files to finish the setup progress. Usually, you can restore iTunes or Finder backup with a computer, and restore iCloud backup on iPhone. However, you may be stuck on restore in progress iPhone: An estimated [XX GB] will be required to finish restoring your apps and data, or iTunes preparing to restore stuck.
What to do if restore from iCloud stuck? Can you cancel an iPhone restore in progress without data loss? Here, you will get more efficient ways to fix iPhone restore in progress stuck. Support all iPhone models, including iPhone 15.
Restore in progress iPhone stuck error may happen because additional storage is needed, iCloud System Status is not working for iCloud backup and iCloud Account & Sign in, WiFi connection is not stable, etc. And usually, restoring in progress takes an iPhone 20 – 60 minutes according to data size. If restore from iCloud backup stuck, it may take hours and won’t stop.
Read the methods below to fix this issue and stop restore in progress iPhone. We will also introduce alternative ways to restore a backup.
If iPhone won’t restore from iCloud and even gets stuck on this mode, you can first use AnyFix – iOS system recovery to fix this issue. It is a one-stop solution to fix 150+ iOS issues, including iPhone restore from iCloud stuck. No skills are needed to use this tool. Just click the buttons and then you can get out of this issue in 5 minutes. Most importantly, AnyFix supports all iPhone/iPad models and iOS versions, even including iPhone 15 and iOS 17. You can learn more about the main features of AnyFix below.
Go get the latest version of AnyFix and get out of restore in progress iPhone:
Launch it and tap on System Repair panel.
AnyFix System Repair Option
Then you need to connect your device to computer > Choose iOS Mode Stuck from the interface below (Here we take iPhone Problems as an example.) > Tap Start Now button and continue.
AnyFix System Repair iOS Mode Stuck
AnyFix provides you three modes based on different situations. If you need to fix problems but don’t want to lose data, Standard Repair mode is recommended. And Standard Repair supports the most common system issues, like won’t charge, battery drain, etc.
AnyFix Standard Repair
AnyFix will let download a matching firmware for your device. Once the firmware is downloaded, the interface below shows. Tap on Start Standard Repair button.
Then AnyFix will start to repair automatically. Wait a minute and it will show you the Repair Completed page as below.
Repair Is Completed
One of the easiest way to get around a stuck iCloud backup process is to restart the process – Restart the iPhone and Restore Once Again. Or, after restarting iPhone, you can also try other ways to transfer data from the old iPhone to the new iPhone. Here are the steps if you cannot restore backup new iPhone:
Reboot your iPhone so that the current restoration process gets interrupted. You can do this for various iPhone models as follows.
Restart an iPhone
Choose Transfer Directly from iPhone
You can also get out of restore in progress iPhone with PhoneRescue for iOS. It can fix restore from iCloud stuck without data loss. All you need to do is click the buttons. Besides, it allow you to restore iTunes backup or iCloud backup easily and successfully. So, after repairing, your iPhone will reboot normally and then you can choose to view and restore iPhone backup files with PhoneRescue in clicks.
As a professional tool to repair iPhone issues, PhoneRescue for iOS can also repair iPhone or iPad stuck on the Apple logo, stuck in Recovery mode, etc. You can learn more about it below.
Here’s how to fix restore in progress stuck and restore your iPhone from iCloud backup with this tool:
Choose the Repair iOS System Mode
Select the Advanced Mode
Enter Recovery Mode
iOS Repairing Completed
Select Recover from iCloud
Choose Messages to Scan
Also Read: Fix WhatsApp Restoring from iCloud Not Working >
Apple does allow you to stop restoring if new iPhone won’t restore from iCloud or get stuck on this mode. This is a useful option to use when iPhone restore from iCloud stuck somewhere.
The following shows how to stop restore in progress on an iPhone.
Step 1. Launch the Settings app and tap on your name banner at the top.
Step 2. Tap on iCloud followed by iCloud Backup to view your backups.
Access iCloud Backup
Step 3. Select the option that says Stop Restoring iPhone to end the restoration process.
Step 4. Tap on Stop in the prompt as well to stop the process.
Your iCloud backup will no longer be installed on your iPhone.
With the above methods, you may know how to fix new iPhone stuck on restore from iCloud. And if you want to restore photos from iCloud directly, you can use AnyTrans – iPhone Data Manager, which allows you to manage iCloud photos, contacts, notes, etc. without iPhone. You can export iCloud content to your computer with one click. No worry about iCloud restoring stuck. Besides, with AnyTrans, you can migrate data from one iCloud account to another, transferring data between iPhones or from Android to iPhone after setup, etc.
To avoid iCloud restoring stuck happening again and fix iCloud photos restoring stuck, you can download AnyTrans on your computer and restore iCloud photos easily.
Choose iCloud Manager and Log In
iPhone doesn’t provide a data list that has been restored or not yet. So, if you stop the restoring process from iCloud, you will not have any idea as to what was restored or what wasn’t, and sometimes, you may lose data. So you need to note that there’s another iPhone backup on your computer or other external storage. Or you can move to the next method to try to fix iCloud restore stuck with an iOS repair tool.
An iCloud backup restoration process could get stuck for various reasons. Regardless, there are multiple ways to fix the restore in progress iPhone stuck issue. These methods should hopefully fix the issue and let you restore your backup without any problems on your iPhone. And, if you want to solve this problem easily and immediately, just free dwonload AnyFix to try it first. It even fix this issue without data loss. All iPhone models are supported!
