This article will guide you on how to downgrade iOS 15 to 14. You are going to explore various methods with their detailed steps to make it easy for you to follow them. We will introduce you to AnyFix, an all-in-one solution for iOS-related issues. Furthermore, you will get to explore the comparison between upgrading and downgrading.
How to downgrade iOS easily and safely? Download AnyFix for free and downgrade your system to unsigned iOS in one click. Without iTunes/without data loss.
Are you unhappy with iOS 15? Does it feel like it’s slowing your phone or causing issues? Many users reported different problems after updating to iOS 15. They noticed faster battery drain, app crashes, WiFi not working, and more. If you are one of them, you might want to go back to iOS 14, which was more stable for some users.This article will guide you on how to downgrade iOS 15 to 14. We will explore various methods and their steps to make the process easy. Are you ready to take your phone back to the more reliable iOS 14? Let’s get started!
Before downgrading iOS 15 to 14, there are a few precautions that you should take. They are given below:
If everything is ok, you can proceed with the downgrading process.
If you want to downgrade your iPhone without iTunes, we have got a perfect solution. Meet “AnyFix,” a reliable and effective tool to help you do the job.The good thing is that this tool is not just limited to downgrading software versions. It has many other useful features to offer. You can use it to fix around 150+ iOS-related issues, including system repair, iTunes repair, and more.
With this tool, you don’t need to go through difficult steps. Its simple and easy-to-use interface is one of the stand-out features of AnyFix. Whether you have tech knowledge or not, you can revert to iOS 14 with just a few clicks.
With AnyFix, you can easily:
Here are the steps for how to downgrade iOS 15 to 14 using AnyFix:
Step 1:First, download and install the AnyFix software on your PC or laptop. Then, launch the app and select “Upgrade/Downgrade iOS” on the homepage.
AnyFix Upgrade/Downgrade iOS Option
Step 2:Connect your iOS device to your computer/laptop via a USB cable. After AnyFix detects and shows the model information, select “1 click to downgrade iOS/iPadOS” and click “Start Now.”
AnyFix Downgrade iOS
Step 3:After clicking Start Now, the firmware packages of your device that are lower than the current one will be shown. Select the one you want to install and click “Download.”
Download Firmware to Downgrade
Step 4:Once the downloading process of the firmware package is finished, click the “Downgrade” button, and the downgrading process will start.
AnyFix is Downgrading the Device
The downgrading process may take some time. Do not disconnect your device until it restarts.
Step 5:When the downgrading process is completed, you will see the interface below. Click “OK” to return to the homepage.
Downgrade Completed Page
That’s all! This is how to downgrade iOS 15 to 14 without iTunes using AnyFix. However, if you are familiar with iTunes and want to try downgrading with it, read the next part.
Using iTunes to downgrade the software version can be tricky. It includes manual downloading or the firmware package. Also, downloading from unofficial platforms can be harmful to your device. So, before you proceed with this method, make sure that you already have a backup of all your essential data.
Here is how to downgrade iOS 15 to 14 using iTunes:
Step 1:Open the browser on your Pc or laptop and visit https://ipsw.me/ to download the official iOS 14 firmware.
IPSW website homepage
Step 2:Next, open the iPhone section and select your device model. Then, select the iOS 14 IPSW file and click “Download” to download it to your PC.
Download the iOS 14 IPSW file
Step 3:Next, connect your iPhone running iOS 15 to your computer. Then, open the latest iTunes on your computer and select your device.
Step 4:Click on “Summary” on the left side. Press the “Shift” key on Windows, then click “Check for Update.”
Step 5:In the pop-up window, select the iOS 14 IPSW file. Click “Open” > “Restore” to start downgrading your device to iOS 14.
Open the firmware package
After the downgrading process is completed, your device will restart. You can set it up and restore your backup (if any).
However, some users find this method daunting, and some cannot find the firmware packages that Apple still signs. In that case, using easy and reliable methods like AnyFix is preferable.
Using recovery mode is another way to downgrade from iOS 15 to 14. It also involves iTunes and will delete everything stored on your device. Therefore, make sure that you already have backed up your essential data. If everything is good to go, you can follow the steps below:
Step 1:First, connect your iPhone to a PC or laptop with the latest iTunes or Finder.
Step 2:Put your iOS device in recovery mode. Then, follow the below instructions according to your device model:
Enter Recovery Mode
Step 3:Once you enter the recovery mode, a pop-up will appear on the iTunes screen. Click the “Restore” button and proceed.
Click Restore
After the restore process is finished, your iPhone will start from the “Hello” screen. Now, set up your iPhone and restore your data.
This is how to downgrade iOS 15 to 14 using recovery mode. However, if you are confused about whether to upgrade or downgrade your device, you must read the next part.
In this section, you will explore the advantages/disadvantages of downgrading and upgrading. This will help you in deciding which option to choose.
Advantages | Disadvantages |
Older iOS versions tend to be more stable. | You cannot access new features and security updates. |
Apps that crash with new iOS may work better on older versions. | Apple may stop signing older iOS, making downgrades impossible. |
Get to explore the latest features and improvements. | New features may cause issues on older devices. |
Benefit from the latest security features to protect your device. | Some updates may introduce bugs or glitches. |
Ensure compatibility with new apps and accessories. | Can lead to slower performance or battery drain on older models. |
Q. How long does the downgrade process take?
The downgrading process usually takes 15- 30 minutes. However, the time may vary according to your internet speed and device model.
Q. How to downgrade iOS 15 to 14 without a computer?
It’s not possible to downgrade iOS 15 to 14 without a computer. Whether you are using iTunes or third-party software like AnyFix, you must have a computer.
Q. Will I lose my data after downgrading to iOS 14?
Yes, the downgrading process erases everything from your device. So, if you don’t have a backup of your essential data, you will most likely lose it.
Wrapping it up! If you are experiencing issues with iOS 15 and prefer iOS 14, downgrading is an option worth considering. Following the steps outlined in this guide, you now know how to downgrade iOS 15 to 14.
Remember to back up your data, check if Apple is still signing iOS 14, and use reliable tools like AnyFix to make the process smooth.
Whether you choose to downgrade for better performance or to fix bugs depends on your personal preferences and needs. Keep your iPhone running smoothly with the best iOS version for you!
